Can I use the speakers with this amplifier?, Speakers from broken Micro Hi-Fi System
larswes
post Oct 19 2012, 17:12
My Philips MCM7 amplifier is broken (bought it 5-6 years ago).
But i think the speakers from the system is still ok.
I consider to buy a new amplifier for the speakers and i found this compact design Dynavoice D-amp.
Do you think this could be a good combination, for music and tv or other source?
From the MCM7 specs:
• Output Power [of my broken amplifier]:
2 x 50 watts RMS, 100 watts total power
• Main speakers [still ok]:
3-Way Bass Reflex
6 ohm impedance
6.5" aluminium con woofer, 2" Tweeter
Dynavoice D-amp
Specifications:
Nominal Power Output (Left & Right Channel (4Ω): 25W + 25W
Nominal Load Impedance (8Ω): 15W + 15W
Main channel: 4Ω - 8Ω
Input Sensitivity: 300 mV
Overload source emf: ≥2V
Frequency Response: 20 Hz – 20 kHz
THD: ≤1%
S/N: ≥95dB
Channel separating degree: ≥70dB
More info about the Dynavoice (sorry only in swedish): http://www.dynavoice.se/dynavoice-d-amp/63/
This post has been edited by larswes: Oct 19 2012, 17:12
pdq
post Oct 19 2012, 18:15
You won't be able to drive it quite as loud, but otherwise it should work OK.
J.Philippe
post Oct 19 2012, 18:18
I don't see any reason why it wouldn't work. Mini system speakers are usually 6 or 8 Ohm, and the amplifier is rated 4-8 Ohm. You'll probably get somewhere around 20 W ouput (at 6 Ohm).
This post has been edited by J.Philippe: Oct 19 2012, 18:19
larswes
post Oct 19 2012, 18:38
Thanks for advise. I will consider this compact type of amp. I will continue googling for similar alternatives. Found this much cheaper (more powerful?) but ugly design: http://www.tradera.com/12-v-forstarkare-mi...70613_166584511
This post has been edited by larswes: Oct 19 2012, 18:39
Porcus
post Oct 19 2012, 19:19
QUOTE (larswes @ Oct 19 2012, 19:38) *
With a PSU that cannot deliver more than 24 watts? That's likely not more powerful. If I were you, I would check the 2nd-hand classifieds. True, capacitors don't always live forever, and the volume controls will wear, but you can get very reasonable two-channel amps for cheap.
Arnold B. Kruege...
post Oct 19 2012, 21:36
QUOTE (Porcus @ Oct 19 2012, 14:19) *
Good point. Even if we grant 100% efficiency to the class D amplifier, it nets out to no more than 12 actual real world WPC. This is over 6 dB less than the original electronics package (50 wpc) which represents a potentially significant loss of audio.
http://download.p4c.philips.com/files/m/mc..._37_dfu_aen.pdf
larswes
post Oct 19 2012, 22:37
Thanks again! All the numbers i had didn't say me much, now i know more and i continue search.
Fedot L
post Oct 20 2012, 00:00
QUOTE (larswes @ Oct 19 2012, 17:12) *
I consider to buy a new amplifier for the speakers…
“• Output Power [of my broken amplifier]:
3-Way Bass Reflex
6 ohm impedance
6.5" aluminium con woofer, 2" Tweeter”
…i found this compact design Dynavoice D-amp.
“Specifications:
THD: ≤1%
S/N: ≥95dB
Channel separating degree: ≥70dB”?
These Dynavoice D-amp Specifications are from the:
http://translate.google.com/translate?js=y...history_state0=
And
is another amplifier.
And
“* Specifikationer:
* Output Power: 180W + 180W
* RMS Power Output: 30W
* Peak Maximum Power Output (PMPO): 180W
* Input Power: 12V 6A DC”
How can an amplifier fed by a “12V 6A DC” (i.e. 72 VA) power supply, be “Output Power: 180W + 180W” (360 W!)?
“* Min. THD: <0.005%”
“Min. THD: <0.005%” is an absurdity as an amp’s THD characteristic. Then MAX THD may be 10%, or more?..
And between THD “≤1%” and “<0.005%” (200 times difference between two very similar devices), do you believe it’s realist? Which of the two may be real?
Why do you wish to buy a 13 V amplifier? Or I’ve misunderstood something? A 13 V amplifier for a home system?
With “THD: ≤1%”? To me, strange for a modern transistor amp.
Why not to buy one of well-known ≈50 W/channel 220 V 50 Hz integrated amplifiers, with a remote control and developed features? And 100 times better THD… There are very moderately priced ones rating 0,01-0,02% THD 20…20000 Hz on the market…
larswes
post Oct 21 2012, 08:49
QUOTE (Fedot L @ Oct 20 2012, 01:00) *
As I said "now i know more" and that was what I was after when i posted here. I will try to find something not to expensive to replace the Philips amp.
QUOTE (Fedot L)
So far i've not found any amp with these spec within my budget. But i found a piece with RMS 2 * 25 W / 220 V that maybe can be ok?
Fedot L
post Oct 21 2012, 12:06
QUOTE (larswes @ Oct 21 2012, 08:49) *
QUOTE (Fedot L)
In this aspect, what would you say about these budget ones:
YAMAHA A-S300:
Minimum RMS output power
(8 Ω, 20 Hz to 20 kHz, 0.019% THD)
[A-S300] ................................................................ 60 W + 60 W
(6 Ω, 20 Hz to 20 kHz, 0.038% THD) [Except for Asia model]
[A-S300] ................................................................ 70 W + 70 W
6 inputs, a “Phones” output. Has no monitoring function.
http://se.yamaha.com/sv/products/audio-vis...__g/?mode=model
or
NAD C316BEE: Continuous output power 40W/channel; 0,01% THD 20 Hz-20 kHz. 7 inputs, a “Phones” output. Has no monitoring function.
http://nadelectronics.com/products/hifi-am...ading-downloads
(there is Swedish manual on the page too).
or
NAD C326BEE: Continuous output power >50W/channel; <0,009 % THD 20 Hz-20 kHz. 7 inputs, a “Phones” output. Some more expensive, but has the monitoring function.
Porcus
post Oct 21 2012, 15:28
QUOTE (larswes @ Oct 21 2012, 09:49) *
Wattage on cheap amps are sometimes like selling rubber bands by the meter, so ... hard to tell. You would be surprised to see how much less they deliver when you feed them actual music – then OTOH you would also be surprised to see how little average power you actually play at.
Often the two best indicators of power for a cheaper amp, are (1) weight! At least if it is a good'old fashioned PSU. Switch mode supplies may be much lighter. Then (2) the power consumption (and the maybe the fuse, although that is rarely an indicator for the very small amps). On the back plate you will often see a power consumption rating.
Arnold B. Kruege...
post Oct 22 2012, 16:08
QUOTE (Porcus @ Oct 21 2012, 10:28) *
I've done some analysis and some casual experiments in this area.
Theory says that steady multitones with equal size components often if not always have peak values that are 8-10 dB higher than their average. In this context a worst case model of music seems like it should fall within this range. IOW a 100+ watt amp (needed to handle the peak voltages) may not clip playing music (even heavily compressed) when powered by a 15-20 watt power supply, given that the power supply puts out enough voltage.
I've found that if you put a fairly big storage cap (e.g. 40,000 uF) across the power supply, you can run 100 watt rms (not PMPO) car audio amps into clipping with speaker loads and music playing, from laptop power supplies putting out maybe a couple of amps at 15-16 volts. (got to be careful to not trip the over voltage protection in the car amp). The cap sorta bridges the gap between peak and average.
larswes
post Nov 6 2012, 00:05
I decided to buy this compact amp:
http://monacor.co.uk/products/prosound-amplifier/vnr/254120/
Got it home today, first impression good. A have piece to unpack, looks feather light but isn't. Matches size of my speakers. Sounds good to me, have to use it for a while before i can say i am happy or not with my choice.
RSS Lo-Fi Version Time is now: 31st January 2015 - 10:50
