2 Pages V  < 1 2
foo_playlist_revive, Revive the dead items in playlist
mll
post Oct 17 2011, 21:07
Post #26
QUOTE (O8h7w @ Jan 23 2010, 17:54) *
QUOTE (hakase @ Sep 18 2009, 03:31) *
I am not sure whether that info is helpful to user. I'll consider it.
I'm rather sure it is. I was about to download your plugin just because I've needed it a few times, and will be needing it again and again... but I didn't download. Because I will wait until I need it, sincerely hoping this feature will be there. But just highlighting them seems to me like a rather unpleasant status report...
The more control the better. A report when done, that seems obvious to me. I think it should state which items worked and weren't touched, which items were changed, last but not least any items that were broken but couldn't be found. If it could also show all new filepaths, that would be great. That way I could check that there hasn't been any mixing up of similar songs.
I second this. Moreover, I see cases where the plugin fails to find an alternative (same artist, same title, but different codec).
Anyway, hakase seems to have dropped any development ont theis pretty plugin... Would anyone suggest an alternative ?
TimUK
post Oct 18 2011, 10:10
Post #27
QUOTE (mll @ Oct 17 2011, 20:07) *
I have looked but never found any better playlist fixers other then Hakase's plugin. Perhaps it could be open-sourced?
A change I would like to add would be for it to uniquely id the files based on the audio content portion of the file only. This would make it resistant against ID3 header, filename changes and the like.
You might want to look ats M3U Reviver a standalone by Werner Staudacher but I found it quite a fiddle to use.
Another trick I tried was to use an in-built playlist repair facility of WinAmp but looking at my current version that option seems to be absent?
Perhaps there are other apps, I would be intrigued to know.
This post has been edited by TimUK: Oct 18 2011, 10:50
mll
post Oct 18 2011, 10:33
Post #28
QUOTE (TimUK @ Oct 18 2011, 11:10) *
Yeah, using MusicBrainz'MUSICBRAINZ_TRACKID field would be very cool.
ELITEeNergizer
post Dec 19 2011, 22:14
Post #29
It doesn't seem to work for some of my playlists, I'm trying to fix the location of a file that used to be in C:/Shared but is now in D:/Shared. I see it in my library but it still doesn't work.
Vanav
post Jan 17 2012, 18:17
Post #30
Works perfectly, thank you!
John Doe
post Oct 1 2012, 21:19
Post #31
Not working here.
It shows me the missing tracks but cannot revive them eventhough I definitely have the same file OR the same title in my Media Library.
John Doe
post Oct 12 2012, 10:39
Post #32
Tracks that fail to update due to no or multiple candidates are selected in the playlist. Please make sure your media files have been scanned into the media library.
Any idea on this one?
KLR
post Nov 7 2012, 01:50
Post #33
Great plugin! I've only recently been creating dedicated playlists, had always used the autoplaylists, and have a general Music folder that I just toss new folders into as I obtain them. Problem with playlists of course is when it's time to do some housecleaning the playlists become hopelessly screwed up; but this component fixes things in no time flat. Thanks for your work!
bulletproof2k
post Nov 7 2012, 16:12
Post #34
Very useful plugin, thanks! :]
♪ ♪ ♪ (((d[^_^]b))) ♪ ♪ ♪
Arakura
post Nov 8 2012, 05:55
Post #35
How do you get it to run once you extract it? there is no revive dead files option... or am I just being stupid?
marc2003
post Nov 8 2012, 12:02
Post #36
QUOTE (Arakura @ Nov 8 2012, 05:55) *
it would seem so. from the opening post:
Use main menu -> Edit -> Revive Dead Items to do the job.
edit: just noticed you mentioned extracting. there's no need for that....
http://wiki.hydrogenaudio.org/index.php?ti...all_a_component
This post has been edited by marc2003: Nov 8 2012, 12:03
RonaldDumsfeld
post Nov 8 2012, 13:05
Post #37
Very useful little app. Works like a charm so far.
In theory it's not strictly vital as fileops within Foobar itself keeps playlists up to date but using revive is much more straightforward.
compoopers
post Dec 10 2012, 13:44
Post #38
Brilliant.
OOOOPS
post Feb 26 2013, 15:32
Post #39
Mr Broly
post Mar 14 2013, 10:41
Post #40
bulletproof2k
post Aug 22 2013, 16:54
Post #41
Great Thx.
vogueblackheart
post Sep 28 2013, 00:18
Post #42
Same issue as ELITEeNergizer reported--On a couple different PCs, I've had the plugin fail to find items, usually when I'm porting foobar and my music collection to a new PC with a different combination of drive letters. I'm guessing the problem is related to drive letters, since we're talking the exact same set of MP3s whose paths would previously be updated. I'll test this some more if there's any indication the plugin is still under development.
Hamburger help u...
post Dec 7 2013, 21:17
Post #43
QUOTE (John Doe @ Oct 2 2012, 00:19) *
Not working here.
Have same issue too. Though sometimes.
https://imgur.com/pmeUOjZ
ChronoSphere
post Jan 22 2014, 15:58
Post #44
Doesn't seem like there was any development on this recently, a pity.
QUOTE (hakase @ Aug 14 2009, 10:03) *
This option became meaningless as I modified the matching algorithm in v0.2. Please just ignore it :-)
Basically the mathcing is based on file size and track length. A matching title field is a positive factor but not determinative.
The case this scenario doesn't take into account is when you convert the tracks to a different format (for lossless tracks). Alternatively matching by tags would help with that.
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 18th September 2014 - 19:07
