Vorbis RC3 quality settings
Jon Ingram
post Dec 22 2001, 15:42
RC3 is almost ready to do, and now has two ways to specify encoding:
1) -m minimum -M -maximum b nominal
2) -q quality
The quality indication goes from 0, which is nominally 64 kpbs, to 10, which is nominally 480kpbs, and is a floating point number.
To get some indication of how bitrate changes as you change the quality setting, take a look here:
http://www.maths.warwick.ac.uk/~jingram/ogg/
I (along with xercist from the #vorbis IRC channel) graphed bitrate-vs-quality for several well known samples, including hard-to-encode ones such as applaud.wav and fatboy.wav. The overall graph is as follows:
http://www.maths.warwick.ac.uk/~jingram/ogg/group.png
The big jump at q=5 is mainly down to the switching to lossless channel coupling. You'll also notice that the bitrate for q=n.99 is generally *larger* than that for q=n+1-- this is because the same settings are used for q in [n, n+1), and they are tuned for the lower end of that range.
Have fun.
john33
post Dec 22 2001, 16:11
xcLame and OggDropXPd Developer
The daily binary at rjamorim's site, has the quality option enabled and works fine. As examples, -q 5 produces an ABR of about 160kbps and -q 6 about 192kbps.
john33
karajan
post Jan 5 2002, 06:48
Just for reference, I measured cut-off frequency(of LPF) at quality setting, by using white noise.
Also, it seems like white noise gives rise to much more bit rate than actual music.
http://www2.ocn.ne.jp/~mp3lab/exp_lab/vorb...vorbis_rc3.html
Jon Ingram
post Jan 6 2002, 04:34
I've updated all the graphs to RC3 (no actual changed in bitrate, given that the encoder on 22/12 basically *was* RC3). I've also added a couple more hard to encode test samples.
In particular, I have a white noise sample. Interestingly, for qualities below 5, encoding this does not expend an enormous amount of bits -- but this soon changes for qualities above 5.5.
RSS Lo-Fi Version Time is now: 28th August 2015 - 09:40
