IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
cue files and wav names, newbie doubts
pnpires
post Nov 13 2009, 02:35
Post #1
Group: Members
I'm trying to use foobar as a front and convert all my music to lossless format (ape or flac).
Can anybody explain me why some cue's have the "right" file name inside:
This line
: FILE "CDImage.ape" WAVE
corresponds to the right ape file inside the zip
and some other cue's have this format:
:FILE "Other Stuff.wav" WAVE
correspond to a Other Stuff.wav.ape inside the zip
Of course on the first example foobar can play the tracks from within the zip file (this is neat!!) and on the second example foobar just produces some errors because it can't find the .wav mentioned inside the cue file
I know that if I edit the .cue file and change the .wav to .wav.ape everything will work, but why does this happens? Why are those cue files like this? Is there any other way of doing it or do I have to edit all the cue files?
Sorry for such a lame question but I'm going to start to convert all my music and I need some help to understand the basic stuff.
Go to the top of the page
+Quote Post
shakey_snake
post Nov 13 2009, 04:51
Post #2
Group: FB2K Moderator
Well, lets start with the fact that .wav and .ape are two different file formats.
.wav is microsoft's standard container for PCM data and is an uncompressed file
.ape is a Monkey's Audio file and is a losslessly compressed audio format.
The FILE line of the .cue probably points to the type of file that was outputted when the CD was ripped (by EAC likely). If since then the file has been compressed into a .ape file, then that would explain why the cuesheet point to the wrong file format.
.wav.ape makes no sense, and is most likely just a .ape file with ".wav" as part of the filename. It was likely renamed the way it is because whoever converted it to .ape probably had no idea what their doing.
elevatorladylevitateme
+Quote Post
pnpires
post Nov 13 2009, 11:30
Post #3
Group: Members
Thanks, I got it.
So in those cases I just have to edit the cue file to point to the correct file name, or even better correct both the filename (removing the .wav.) and everything will be as should be.
I going to start making some tests with EAC and my CD's.
Regards
This post has been edited by shakey_snake: Nov 13 2009, 13:30
Reason for edit: Removed full quote of preceding post; don't make us scroll past the same stuff multiple times
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 30th January 2015 - 14:00
