IPB
Nero 6 -- SOOO close to great, Improve the Nero ripping UI
magi
post Oct 6 2003, 06:58
Post #1
Group: Members
I've been looking for a good ripping/m4a (mp4/aac) encoding solution and the best I've found so far is Nero. I paid for Nero 5 and actually bought the Nero AAC encoder, and almost loved it but had a couple gripes
- no tagging
- the UI forgets the settings every time you close it
- non-intelligent directory behavior
Basically, it just wasn't quite suitable for bulk encoding projects.
Now they've released Nero 6 and the AAC encoder comes with it, and fixes the tagging problem. But the other problems (UI issues) persist -- I wrote Nero tech support about this months ago and heard nothing, so I'm hoping that by posting here maybe Ivan will notice wink.gif or maybe enough other people will agree to make Ahead take notice.
So in more detail:
- every time I open the Save Tracks dialog, the settings have returned to default. So I have to click Settings, choose the preset I want, click OK. (At least, improved from the previous version, it remembers my custom file naming settings now, BUT doesn't remember THAT I want to use those instead of the default.)
- I want my music organized in folders like so: Artist/Album/Songs. Various other rippers I've used (Audiograbber, EAC, even, gasp, WiMP) can do this; Nero dumps all the files in the exact directory named in the Path field. And doesn't allow directory separators in the "filename". Please add a way to let me specify a directory as well as filename from the artist/album info.
Other wishlist:
- more transparent CDDB behavior; I know CDDB works and I just want Nero to retrieve the disc info without asking me. The "don't show this dialog again" button doesn't help! And if I have turned off automatic query of CDDB, there should be a button in the Save Tracks dialog to manually query.
- ability to rip/encode 2 discs at the same time, since I have 2 drives. I can do this with 2 instances of Nero but it's annoying.
So, the work for me to rip a single cd is:
1) Extras->Save Tracks
2) Select a drive in the Choose Drive dialog, click OK
3) Click "Access Internet Database", then "Selected CD" in the Title and CD Database dialog
4) click Settings, choose preset "VBR/Stereo - audiophile" or otherwise customize these settings, click OK
5) manually create a folder for the new tracks, enter it in the Path field
6) click the dropdown next to File Name Creation Method, choose User Defined, click OK
7) click Go
Really, steps 3, 4, 5 and 6 should be able to be eliminated, because I always do the same thing. And that's a lot of clicking.
Anyone else out there agree? Thx for listening.
Go to the top of the page
+Quote Post
magi
post Oct 6 2003, 07:00
Post #2
Group: Members
Oh. And if they fix all this, I'll pay for the upgrade to Nero 6 B)
+Quote Post
kl33per
post Oct 6 2003, 07:06
Post #3
A/V Moderator
Group: Members
Check out the latest BeSweet or Nencoder (availible at RareWares) which can encode without the Nero app running. You still obviously have to own Nero 6 to use it though (if Nero 5 codec keeps being updated, then it would be fine as well).
www.sessions.com.au - Sessions Entertainment
+Quote Post
JohnV
post Oct 6 2003, 11:23
Post #4
Group: Developer
QUOTE (kl33per @ Oct 6 2003, 09:06 AM)
There's also foo_neromp4.dll plugin, which allows encoding directly from Foobar2000 0.7 (uses Nero6's AAC encoder dlls).
http://www.saunalahti.fi/~cse/foobar2000/f...foo_neromp4.zip
Juha Laaksonheimo
+Quote Post
kritip
post Oct 6 2003, 16:55
Post #5
Group: Members
QUOTE (JohnV @ Oct 6 2003, 11:23 AM)
Sorry to hijack the thread, but i just tried that plugin for foobar and it works ok, but when the file is downmixed to mono using the options, foobar plays it back at half speed so it's length is double, very odd, and im not sure wether its the plugin fault, foobar or what? Does this only occur on my system?
Kristian
+Quote Post
Big_Berny
post Oct 6 2003, 17:14
Post #6
Group: Members
QUOTE (magi @ Oct 5 2003, 09:58 PM)
I hate this two "bugs", too. I capture daily two Simpsons. And everytime I encode the audio, I have to set settings again. It's so difficult to implement this two "features"???
Big_Berny
+Quote Post
Ivan Dimkovic
post Oct 6 2003, 17:17
Post #7
Nero MPEG4 developer
Group: Developer
Actually,
"File / Preferences / Plug-in Lookup / Encoders..."
And then editing the encoder setting will make them default.
+Quote Post
Louie
post Oct 6 2003, 18:33
Post #8
Group: Members
For NEncode and foo_neromp4, which is based off NEncode,
the settings are stored in the following registry branch:
HKEY_CURRENT_USER\Software\Smeshka\Nencode\MPEG-4 Advanced Audio Coding (AAC)
My settings are always saved with no problems.
+Quote Post
magi
post Oct 6 2003, 19:50
Post #9
Group: Members
QUOTE (Ivan Dimkovic @ Oct 6 2003, 08:17 AM)
Thanks! That's totally non-obvious, but it works.
Now if it would just put my files where I want them...
(slight aside, now that some of the individual features like Save Tracks are available separately from StartSmart, it might be time to rethink the configuration UI. I mean, I can get directly at Save Tracks by clicking the "Rip CD Tracks" button in StartSmart, but to edit settings for Save Tracks -- the above Encoder preferences, or creating the user database, etc. -- I have to run "normal" Nero by clicking on one of the data buttons, then use Preferences.
The first time I ran Nero 6, the first thing I wanted to play with was the encoder so I went to Save Tracks, it told me there was no database and offered to create one, and when I gave it a directory, it hung. Tried this 3 times, kept having to kill the nero process. Finally I went in through the "front door", running the normal Nero UI, used Database->Create A New User Database, this of course worked fine, and now if I go straight to "Rip CD Tracks" it works fine from there too.
The point I'm trying to make is StartSmart tries to let you go straight to a bunch of subfeatures without going through the main Nero UI, but it doesn't work all that well.)
+Quote Post
DSPguru
post Oct 7 2003, 00:01
Post #10
BeSweet Developer
Group: Developer
if someone wants to integrate Nero's AAC/MP4 encoder to tools like CDEX, i believe BSN.dll could be very useful.
BSN.dll integrates darp's nencode with Richard's mp4 tagger.
source-code + binary bundle can be found here.
Dg.
edit : typos..
This post has been edited by DSPguru: Oct 7 2003, 00:04
DSPguru's Webpage - home of BeSweet & The OggMachine.
BeSplit - 7kb of A loseless AC3/AAC/MP3/MP2/WAV Cutter :)
+Quote Post
Louie
post Oct 7 2003, 00:37
Post #11
Group: Members
+Quote Post
SoundJudgment
post Oct 7 2003, 04:29
Post #12
Group: Members
Actually,
Also found in the Nero Wave Editor under 'Options, Encoders, Configure Save Options.'
I *always* leave my MP4/AAC options for encoding at TRANSCODING: ULTRA level with VBR and High-Quality Encoding, LC.
It never forgets those.
SJ
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 28th February 2015 - 21:00
