Converting all my Flac files to Aiff...
ryssen
post Jul 6 2011, 04:19
But I`m locking for a converter that preserves the tags and embeded jpg file.I am trying this Audio transcoder,but the tag is npt in the final file.
Do you guys have any suggestions what program to use to get the tags to stay?
Allso I would like suggestion on a tagsoftaware that can take Aiff (Mp3 tag can´t)
A_Man_Eating_Duc...
post Jul 6 2011, 06:24
May I ask the reason why you want to do this?
ryssen
post Jul 6 2011, 08:26
Well I hear (read) that people are saying that Aiff sounds better with Squeeze box...So I thought I give it a try.
But it seems hard to find a converter that keeps both the tags and the picture (jpg) during the convert.
A_Man_Eating_Duc...
post Jul 6 2011, 09:08
Foobar2000 will allow you to convert FLAC to AIFF, it should keep the tags but not the cover art.
There should be no difference in sound quality because both formats are lossless. If i were you i would keep the FLACs and use the HD space you save for more music.
http://wiki.slimdevices.com/index.php/HowtoBestAudioQuality
This post has been edited by A_Man_Eating_Duck: Jul 6 2011, 09:10
DonP
post Jul 6 2011, 11:05
Group: Members (Donating)
QUOTE (ryssen @ Jul 6 2011, 02:26) *
If you follow the link to the squeezebox site given in another post, it says that squeezebox supports flac directly, but not AIFF. That means the server has to translate AIFF to a supported format (likely FLAC) on the fly. So, why is it that AIFF sounds better?
This on-the-fly translation will screw you up if you want to scan forward or back through a song.
probedb
post Jul 6 2011, 11:57
QUOTE (ryssen @ Jul 6 2011, 08:26) *
I very much doubt that. By all means convert a couple of tracks and try it out but FLAC is lossless and is natively decoded by the SB itself. You'll find the same people that say things like that also think spending £200/m on speaker cable is the best upgrade they ever did to their system rolleyes.gif
db1989
post Jul 6 2011, 12:36
Two invaluable hints: don’t believe everything you hear/read, especially if no evidence is provided; and feel free to investigate and conclude for yourself (after all, who else has your ears, and what better way to evaluate any claim?) using a double-blind ABX test. The requirement of evidence for claims is in keeping with #8 of Hydrogenaudio’s Terms of Service.
Jebus
post Jul 6 2011, 16:17
AIFF files basically just contain raw PCM, like WAVE (only in big-endian byte order, which is more efficient on non-intel hardware). FLAC (like most other formats) gets decoded to PCM on playback. The PCM FLAC gets decoded to is bit-by-bit identical to what the AIFF file contains. So unless Squeeze box introduces errors during decoding, there is no technical reason one would sound different from the other. AIFF files are just going to be some 40% larger, and don't have a well-supported means for storing metadata.
This post has been edited by Jebus: Jul 6 2011, 16:18
Wombat
post Jul 6 2011, 16:26
I am around at the Slimdevices forum a while now and this nonsense comes up regulary. As always there is the theoretical explanation that decoding flac in the unit stresses the machine and sounds worse exactly because of this! End of rational discussion smile.gif
When you read on these claims come from the same pinheads that hear a Router sounding different in front of the Squeezebox, Ethernet cables sound different and even Windows7 server sounds better as Linux with delivering the bits to the network over several stations....
So for heavens sake if you really don´t want flac used you may use all advantages but telling Squeezebox Server to transcode flac->wav on playback, so sending decoded PCM to the box.
If you attach a HD directly to the Squeezebox Touch things may be different.
ryssen
post Jul 6 2011, 19:51
I think I´ll do that..I have done a couple of AIFF files I will listen to later.
And it´s alot of work konverting all files to AIFF.
This post has been edited by ryssen: Jul 6 2011, 19:51
db1989
post Jul 6 2011, 20:05
QUOTE (ryssen @ Jul 6 2011, 19:51) *
In some effort to evaluate whether they sonically differ from their losslessly compressed parents? Be sure to use a blind ABX test, as described in the above links, in that case. You could supplement the confidence provided from its inevitable results by comparing both files with a bit-for-bit comparison that will demonstrate their identicality.
KozmoNaut
post Jul 11 2014, 09:11
QUOTE (Wombat @ Jul 6 2011, 16:26) *
That's nothing. On a forum I read from time to time, there's a guy who has moved the wifi module outside the Squeezebox to "reduce interference". Then he covered the entire inside of the device with bitumen and mu-metal. According to himself, the effect was "extreme jet-black background and more air around performers".
Loonies are all around us.
RSS Lo-Fi Version Time is now: 27th May 2015 - 05:34
