IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
Fix cue sheet files to compatible with foobar2000 v9.x, if you failed on open a cue file with foobar2000 v9.x, you should look
fireseed
post May 1 2006, 08:57
Post #1
Group: Members
foobar2000 v9.x can't recognise the cue sheet files if the FILE TYPE data is none of AIFF, WAVE, MP3.
And, if there is a couple of double quotation marks between an other of double quotation marks in a cue sheet file, foobar2000 v9.x will failed when open the cue.
this application will solve these problem by fix cue file.
* Console app, easy for use, just specify a folder include the problem cue file as parameter.
* Auto search all subfolder within you indicated.
* Auto backup original cue sheet file, so you needn't worry about it may damage your files.
* friendly report, and interaction
* All free
download from:
https://sourceforge.net/project/showfiles.p...group_id=140798
Select CueFixer
This post has been edited by fireseed: May 1 2006, 14:08
Go to the top of the page
+Quote Post
fireseed
post May 1 2006, 14:55
Post #2
Group: Members
I have changed the download adress, I upload it to sourceforge, now you can download from there freely
one need it?
This post has been edited by fireseed: May 3 2006, 03:14
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 22nd September 2014 - 13:14
