> foobar2000 Development Forum Rules
This forum is for developer discussions only. If you have a problem / bug report / idea / feature request that isn't related to foobar2000 SDK, post it in an appropiate forum instead - tech support questions go to support forum, everything else goes to general forum.
All non-developer posts on this forum will be removed. Continued abuse of this forum will result in admin actions (warnings, account suspension).
2 Pages V  < 1 2
Developer Tutorials, for 0.9
Tuzz
post Oct 14 2007, 08:43
Post #26
I managed to compile SDK, and SDK helpers, but i have errors compiling step1:
step1.obj : error LNK2019: symbole externe non résolu __imp__RegisterClassW@4 référencé dans la fonction "public: struct HWND__ * __thiscall window_tutorial1::create(struct HWND__ *)" (?create@window_tutorial1@@QAEPAUHWND__@@PAU2@@Z)
step1.obj : error LNK2019: symbole externe non résolu __imp__LoadCursorW@8 référencé dans la fonction "public: struct HWND__ * __thiscall window_tutorial1::create(struct HWND__ *)" (?create@window_tutorial1@@QAEPAUHWND__@@PAU2@@Z)
foobar2000_sdk_helpers.lib(window_placement_helper.obj) : error LNK2001: symbole externe non résolu __imp__IsWindow@4
foobar2000_sdk_helpers.lib(window_placement_helper.obj) : error LNK2019: symbole externe non résolu __imp__GetWindowPlacement@8 référencé dans la fonction "public: bool __thiscall cfg_window_placement::read_from_window(struct HWND__ *)" (?read_from_window@cfg_window_placement@@QAE_NPAUHWND__@@@Z)
foosion
post Oct 14 2007, 10:05
Post #27
Group: FB2K Moderator (Donating)
The missing functions are from the Win32 API. Do you use Visual C++ 2005 Express? If so, you should check that the Windows SDK (previously called Microsoft Platform SDK) is installed correctly, specifically that the library directory is set up correctly in the IDE.
Tuzz
post Oct 14 2007, 17:57
Post #28
you're right, i've forget to modify a file
foosion
post Sep 4 2008, 22:48
Post #29
I've updated the DSP tutorial. It now compiles with the latest foobar2000 SDK. There is still a warning message about a deprecated dialog helper class from the SDK, I plan to get rid of that in the next version.
mccarver
post Jun 8 2009, 19:38
Post #30
This post has been edited by mccarver: Jun 8 2009, 19:43
grodriguez
post Jun 26 2009, 02:52
Post #31
Hey guys,
Maybe this is a really newbie question but here it goes.
I compiled and tested the tutorial component but is there an easier way of making modifications to it other than:
1. Modify
2. Compile
3. Close foobar
4. Copy .dll to components folder
5. Open foobar
6. Try
Cheers
G
Yirkha
post Jun 26 2009, 10:53
Post #32
Set output target directory to ...\foobar2000\components directly, or add a post-build step to copy it there, and set ...\foobar2000\foobar2000.exe as debugged process in project properties. Just hit F5 (Run) to do everything automagically each time after that.
grodriguez
post Jul 7 2009, 01:33
Post #33
QUOTE (Yirkha @ Jun 26 2009, 06:53) *
Thanks Yirkha, I'll try that ...
G
foosion
post Oct 23 2009, 20:12
Post #34
I've updated the DSP tutorial. There was an old bug in the dsp_tutorial_nopreset::flush() method.
sunshine_fen
post Feb 2 2010, 07:51
Post #35
I'm a new on this part. Recently, I want to have a look of the development process.
I have download and installed,
-VC 2005
-Windows platform SDK
And get SDK-2010-01-19.zip. But when I unzip it, I can not find the "SDK-test" solution file.
Is there anything wrong?
Yirkha
post Feb 14 2010, 16:50
Post #36
No, the .sln file is just not bundled with this version. Create a solution yourself and add all the projects (search for *.vcproj).
sunshine_fen
post Feb 25 2010, 05:07
Post #37
Thanks Yirkha!
I have another problem,
Is there any method to debug the project?
How can I see the value/state of a parameter?
Yirkha
post Mar 1 2010, 15:04
Post #38
Yes, see this (but note it's old, it might fairly outdated in some other regards).
Blood HaZaRd
post Apr 11 2010, 20:56
Post #39
Hi Foobares smile.gif . As i'm new here and really addicted to contribute into the devolepment of foobar, i was wandering if one momber of the commity could tell me what EDI we should install (microsoft visual 6, 2003, 2005 or later ) and others related staff !!
Blood HaZaRd
post Apr 12 2010, 00:21
Post #40
well, i downloaded MVS C++ Express edition 2008. and i tried to compile the foobar project but when compiling it told me to specify the name of the exec to use. COuld some one tell me or give a tuto or a little help to surpass this nooby handicap.
Girid
post Sep 16 2010, 00:13
Post #41
I have been developing a plugin that I finally got to a point where I would like to share it but when I switch the configuration over from debug to release in visual studio 2010, I get numerous errors for my project along the lines of "error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL':". All of the separate components for the SDK compile fine in release mode, it is only when I try to make a component dll that I get these errors. I have tried doing the same for the sample projects mentioned here and I get the same errors. Has anyone seen this before or have any ideas about how I should go about fixing this?
Yirkha
post Sep 16 2010, 00:20
Post #42
You have part of the projects build with debug and part with release configurations. Make sure your Release configuration reference Release .libs of other components, that you don't force /D_DEBUG options for compiler even in Release configuration etc.
Girid
post Sep 16 2010, 18:45
Post #43
Thanks Yirkha. For some reason when I was switching over to release, some of the projects were switching over to the Multi-Thread libraries and some to the Multi-Thread DLL libraries. Just switched them all to the Multi-Thread and it worked fine.
popatr
post Jan 13 2011, 17:54
Post #44
I have seemingly successfully compiled the general component tutorial, and loaded it into foobar:
but when I start foobar (v1.1.1) I can't see the component's main menu item. The component is visible in the components list and can display it's simple about form.
popatr
post Jan 25 2011, 15:56
Post #45
Nevermind my last post, I was incorrectly looking for a preferences dialog, not a link under the view menu where I should have been looking.
Ditchbuster
post Jul 5 2011, 22:26
Post #46
the link seems to be broken to download the General Component Tutorial.
foosion
post Jul 6 2011, 06:14
Post #47
QUOTE (Ditchbuster @ Jul 5 2011, 22:26) *
Fixed. Thanks for noticing.
Ditchbuster
post Jul 6 2011, 16:42
Post #48
QUOTE (foosion @ Jul 5 2011, 22:14) *
Thanks for fixing!
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 22nd November 2014 - 03:53
