23 Pages V  « < 12 13 14 15 16 > »
Closed TopicStart new topic
R128GAIN: An EBU R128 compliant loudness scanner
pbelkner
post Jan 6 2012, 17:23
Post #326
QUOTE (gb24 @ Jan 5 2012, 03:12) *
Please forgive me if I missed it, but is there a command line environment variable provided for the actual LUFS value, e.g., %LUFS%?
Version 0.9.3 released:
Home: http://r128gain.sourceforge.net/
Download: http://sourceforge.net/projects/r128gain/files/
What's new?
  • Provided four more environment variables for the command option:
    • %TL%: The track loudness relative to full scale.
    • %TLDB%: The track loudness relative to full scale in dB/LUFS.
    • %AL%: The album loudness relative to full scale.
    • %ALDB%: The album loudness relative to full scale in dB/LUFS.
gb24
post Jan 6 2012, 20:41
Post #327
QUOTE (pbelkner @ Jan 6 2012, 11:23) *
Excellent! Thank you for making this great tool available to the community.
Zao
post Jan 6 2012, 23:50
Post #328
Group: Members (Donating)
You couldn't have chosen something slightly more unique for the environment variables?
At least put a prefix on them or something to avoid collisions.
gb24
post Jan 9 2012, 02:32
Post #329
QUOTE (Zao @ Jan 6 2012, 17:50) *
Is this causing a specific problem which you cannot work around? Is there a reason for your focus on this small detail given all the functionality of this free program?
gb24
post Jan 23 2012, 18:19
Post #330
One more I may have missed: is there a command line environment variable provided for the Loudness Range (LRA) in LU?
With this additional data, the scanner would provide all three measures in R128. For example, for a given track would the following be correct?
    1. "Programme Loudness" in LUFS (%TLDB%)
    2. "Loudness Range" in LU ( ? )
    3. "True Peak Level" in dBTP (%TPDB%)
Thank you.
This post has been edited by gb24: Jan 23 2012, 18:20
pbelkner
post Jan 24 2012, 09:23
Post #331
QUOTE (gb24 @ Jan 23 2012, 18:19) *
There's no range computing in R128GAIN yet, that's not only a matter of an environment variable.
Thank you.
On the other hand there's a LU measure: %TGDB% holds the gain (in dB / LU) you have to apply in order to correct the loundess to -23 LUFS.
gb24
post Jan 25 2012, 16:22
Post #332
Please consider adding Loudness Range (LRA). The scanner would then provide all three R128 descriptors, for example:
- Programme Loudness (%TLDB%)
- Loudness Range ( ? )
- True Peak Level (is this %TPDB%?)
Thank you.
pbelkner
post Jan 25 2012, 18:16
Post #333
QUOTE (gb24 @ Jan 25 2012, 16:22) *
Yep.
But next in the pipeline is a GTK+ GUI for Linux. Here's some preview:
Yes.
gepebril
post Feb 1 2012, 13:46
Post #334
Hi there,
I'm not realy an audio guru, but for a project we have to make audio EBU-R128 compliant.
As I favour Open source solutions I would like to use R128GAIN, what I don't understand from the documentation is:
1) Can R128GAIN process audio so the result is EBU-R128 compliant
2) If so. We have the following specifications, and can they be achieved with R128GAIN
Parameter                      Meterindication  Value
Integrated Loudness            I                 -23 LUFS
Maximum True Peak Level        dBTP              -1 dBTP
Maximum Momentary Loudness     M                 +8 LU
Maximum Short Term Loudness    S                 No limitation
Loudness Range                 LRA               No limitation
3) Can one file be made EBU-R128 complaint, or can it only be as range of files in e.g. a play-out list
4) What file formats can be used as input (format, bitrate, samplerate) and what can be output formats (format, bitrate, samplerate)
Thanks in advance.
Yours sincerely,
Albert
This post has been edited by gepebril: Feb 1 2012, 13:49
pbelkner
post Feb 1 2012, 15:35
Post #335
QUOTE (gepebril @ Feb 1 2012, 13:46) *
In principle yes, but currently not with respect to all measures (cf. answers to the following questions.)
Integrated loudness: Yes, via the command feature and using the default sox-command.
Maximum True Peak: R128GAIN is able to measure true peak but has no build in way to correct it. But most likely in almost all cases you will see that after having normalized to -23 LUFS your true peak requirement is fulfilled.
Maximum Momentary Loudness is not measured yet.
Maximum Short Term Loudness is not measured yet.
Loudness Range is not measured yet but should be available sometimes soon (cf. request by gb24 above.)
You can use it on a file by file basis as well as on a range of files.
After having upgraded to full versions of SoX (http://sox.sourceforge.net/) and FFmpeg (http://ffmpeg.zeranoe.com/builds/win32/shared/) there should be no practical restriction.
pbelkner
post Feb 4 2012, 18:54
Post #336
Version 0.9.4 released:
What's new?
  • Implemented the EBU R128 loudness range (LRA) algorithm (not available for the ReplayGain and BS.1770 sequence algorithms.)
  • Provided four respective environment variables for the command option:
    • %TR%: The track loudness range.
    • %TRDB%: The track loudness range in dB/LU.
    • %AR%: The album loudness range.
    • %ARDB%: The album loudness range in dB/LU.
  • The API of LIB1770 (implementing the loudness range algorithm) has slightly changed in order to allow for providing the length of a block (either 400 ms or 3000 ms.)
Test cases for Loudness Range (tech3342.pdf):
$ r128gain ~/ebu-loudness-test-setv03/*3342*.wav
SoX successfully loaded.
FFmpeg successfully loaded.
analyzing ...
  seq-3341-2011-8_seq-3342-6-24bit-v02.wav (1/6): -23.0 LUFS, 0.0 LU (peak: 0.737823: -2.6 dBFS, range: 15.3 LU)
  seq-3341-7_seq-3342-5-24bit.wav (2/6): -23.0 LUFS, 0.0 LU (peak: 0.358340: -8.9 dBFS, range: 6.3 LU)
  seq-3342-1-16bit.wav (3/6): -23.0 LUFS, 0.0 LU (peak: 0.100088: -20.0 dBFS, range: 10.0 LU)
  seq-3342-2-16bit.wav (4/6): -23.0 LUFS, 0.0 LU (peak: 0.177971: -15.0 dBFS, range: 5.0 LU)
  seq-3342-3-16bit.wav (5/6): -23.0 LUFS, 0.0 LU (peak: 0.100088: -20.0 dBFS, range: 20.0 LU)
  seq-3342-4-16bit.wav (6/6): -23.0 LUFS, 0.0 LU (peak: 0.100073: -20.0 dBFS, range: 15.0 LU)
  ALBUM: -23.0 LUFS, 0.0 LU (peak: 0.737823: -2.6 dBFS, range: 17.1 LU)
This post has been edited by pbelkner: Feb 4 2012, 19:13
gb24
post Feb 6 2012, 19:29
Post #337
Thank you for incorporating LRA, Peter. I think you now have a great tool for batch processing of audio files per EBU R128.
I am not aware of any other free or open source software which provides all this functionality.
This post has been edited by gb24: Feb 6 2012, 19:30
pbelkner
post Feb 7 2012, 19:46
Post #338
Version 0.9.5 (source / win32 binary) released:
What's new?
  • Fixed a bug in 0.9.4 that only either the loudness or the loudness range could be computed but not both together. The result was that in almost all practical cases the loudness defaulted to -23.0 LUFS.
The Linux binary will follow in a few days.
analyzing ...
  seq-3342-1-16bit.wav (3/6): -22.6 LUFS, -0.4 LU (peak: 0.100088: -20.0 dBFS, range: 10.0 LU)
  seq-3342-2-16bit.wav (4/6): -16.8 LUFS, -6.2 LU (peak: 0.177971: -15.0 dBFS, range: 5.0 LU)
  seq-3342-3-16bit.wav (5/6): -20.0 LUFS, -3.0 LU (peak: 0.100088: -20.0 dBFS, range: 20.0 LU)
  seq-3342-4-16bit.wav (6/6): -24.5 LUFS, 1.5 LU (peak: 0.100073: -20.0 dBFS, range: 15.0 LU)
  ALBUM: -21.2 LUFS, -1.8 LU (peak: 0.737823: -2.6 dBFS, range: 17.1 LU)
pbelkner
post Feb 10 2012, 23:20
Post #339
QUOTE (pbelkner @ Feb 7 2012, 19:46) *
The 0.9.5 Linux binary has been published.
pbelkner
post Feb 11 2012, 19:10
Post #340
Version 0.9.6 released:
What's new?
  • According to FFmpeg.org: FFmpeg development has gone into OVERDRIVE. As a consequence R128GAIN wasn't compiling any longer using the latest FFmpeg versions. This release ports R128GAIN to the latest FFmpeg API.
  • Added a command line and GUI option to allow choosing between the EBU R128-2 (current, dating from 2011) and EBU R128-1 (former, dating from 2010) standards.
  • The release requires "avformat-54.dll" and "avcodec-54.dll", and is now again in line with the latest FFmpeg builds from http://ffmpeg.zeranoe.com/builds/win32/shared/.
This post has been edited by pbelkner: Feb 11 2012, 19:57
bacondither
post Feb 13 2012, 22:38
Post #341
With every ogg vorbis file i try to process i get "Application provided invalid, non monotonically increasing dts
to muxer in stream"
An example of a test ogg vorbis file encoded with aotuv 6.03:
SetDlgItemURL successfully loaded.
[ogg @ 02197FE0] Format ogg probed with size=2048 and score=100
[ogg @ 02197FE0] Page at 58 is missing granule
[ogg @ 02197FE0] ti bytes of comment header remain
[ogg @ 02197FE0] All info found
analyzing ...
test.ogg (1/1): -10.3 LUFS,
-12.7 LU (peak: 1.097097: 0.8 dBFS, range: 7.6 LU)
ALBUM: -10.3 LUFS, -12.7 LU (peak: 1.097097: 0.8 dBFS, range: 7.6 LU)
writing ...
test.ogg (1/1) ... [ogg @ 0
220F9A0] Format ogg probed with size=2048 and score=100
[ogg @ 0220F9A0] Page at 58 is missing granule
[ogg @ 0220F9A0] ti bytes of comment header remain
[ogg @ 0220F9A0] All info found
[ogg @ 0220FE80] Application provided invalid, non monotonically increasing dts
to muxer in stream 0: 13760 >= 13760
error.
Done. Hit enter to continue ...
The resulting outputted file from the operation above is a 58 byte .ogg file with this content:
OggS  ±vorbis D
romor
post Feb 13 2012, 23:19
Post #342
Interestingly, I got same errors earlier today while doing DVD (M2V+LPCM) to MKV (x264+OGG) with Avidemux, which was handy at the moment. Result was fine thou, audio seemed fine after I checked, as I was surprised by misleading DTS errors
Seems like some ffmpeg issue
scripts: http://goo.gl/M1qVLQ
pbelkner
post Feb 14 2012, 08:24
Post #343
QUOTE (bacondither @ Feb 13 2012, 22:38) *
to muxer in stream"
analyzing ...
writing ...
error.
This seems to be an FFmpeg error. FFmpeg is currently under heavy development.
A workaround is making FFmpeg unusable by e.g. renaming "avcodec.dll" from the "r128gain-tools" directory to "avcodec.dll.X". In this case R128GAIN will fall back to SoX.
pbelkner
post Feb 15 2012, 21:00
Post #344
to muxer in stream"
I've just uploaded a slightly modified version which should fix the issue (source code and win32 binary): http://sourceforge.net/projects/r128gain/files/
bacondither
post Feb 16 2012, 08:38
Post #345
pbelkner
post Feb 18 2012, 07:18
Post #346
QUOTE (pbelkner @ Feb 15 2012, 21:00) *
QUOTE (bacondither @ Feb 16 2012, 08:38) *
The Linux binary is now available as well.
pbelkner
post Mar 18 2012, 19:35
Post #347
Version 0.9.6-3 released:
What's new?
  • Fixes a bug that under certain circumstances a file was written twice.
  • Upgraded to SoX 14.4.0.
rojgreen
post Mar 28 2012, 18:37
Post #348
HI - new user. I don't mean to sound dumb, but is there a way to offset the resulting gain before it is written to a new file?
The reason I ask, is our company (TV broadcaster) has decided to adopt a reference of -24db based on itu1770 for mixed television programmes, and I was wondering if this tool would be of any use here. -23db is within our delivery spec, but out of curiosity (just me playing around) i wondered if this tool could be used in our commercial suites to make a gain adjusted copy of the final .wav files that will comply with our delivery spec.
rojgreen
post Mar 28 2012, 19:35
Post #349
QUOTE (rojgreen @ Mar 29 2012, 05:37) *
also, (again, newbie question) can I pass the full -sox comand line to the program (through windows .bat file or shortcut)? I tried --command=sox "%TRACK%" "%DN%\%BN%.wav" gain "%TGDB%" but all thouse quotes seem to confuse the .bat file
This post has been edited by rojgreen: Mar 28 2012, 19:36
pbelkner
post Mar 29 2012, 07:05
Post #350
QUOTE (rojgreen @ Mar 28 2012, 18:37) *
There's an undocumented "--preamp=<float>" option. The preamp is in dB relative to -23 LUFS. i.e. in your case -1.0.
QUOTE (rojgreen @ Mar 28 2012, 19:35) *
You should surround it by quotes, i.e. either
'--command=sox "%TRACK%" "%DN%\%BN%.wav" gain "%TGDB%"'
or
"--command=sox '%TRACK%' '%DN%\%BN%.wav' gain '%TGDB%'"
RSS Lo-Fi Version Time is now: 21st September 2014 - 03:06
