Topic: [DOUBLE-POSTING] XLD refuses to generate rip logs (Read 1202 times) previous topic - next topic
So, I've trashed the XLD preferences file and started over (same problem as below) and even trashed XLD and re-installed it (same problem as below).
XLD will not generate or autosave a log after ripping a CD!
Any suggestions? does it stop generating logs until you make a donation?
  • Version 20080926 (93.3)
  • system configuration:
    • iMac 2.16 HGz Intel Core 2 Duo
    • 10.4.11
    • Intel
    • MATSHITA DVD-R  UJ-85J (revision FCQA)
    • 1 GB 667 MJz DDR2 SDRAM
  • Preferences General: output format: WAV - output directory: specified to working folder for rip - filename: %n - %t - max threads: 2 - remaining selections only automatically add tags if possible
  • Preferences CD rip: following selected: rip as accurate as possible - max retry 100 - read sample offset 102 -  set automatically - query AR DB - automatically save log file always - verify suspicious sectors
Using XLD for one day. First rip of silver CD bootleg went fine and log file appeared at completion of rip. On subsequent attempt to rip again three tracks from the same disc that had slight atom jitter errors, this time with "test before copy checked," XLD will NOT produce any logs for any rip. I've tried several times, searched with finder for any .log file and the only ones that show up are the ones from the first rip.
I'm probably missing something obvious but I can't figure this out.
thanks
