"iFi iUSBPower"- USB cable alternatives
o-l-a-v
post Feb 27 2013, 23:21
Hi
For using the iUSBPower from iFi:
http://ifi-audio.com/en/iUSB.html
You will need one dual headed usb cable to send the signal to the DAC. This cable must join two usb cables into one. One source contains power only, the other contains the data stream.
iFi has a cable for this, "ifi gemini dual headed usb cable".
The only problem is: This cable alone costs about the same as the iFi iDac = Redicolous ammount of money.
Do you guys know of a cheaper, but good alternative? Not a regular taiwan-tech usb cable.
But more like the Supra USB cable: Good quality and affordable (http://www.whathifi.com/review/supra-usb-20)
Olav
Canar
post Feb 28 2013, 00:00
I got one of those bundled with my USB DVD burner.
http://www.ebay.ca/itm/USB-2-0-2-A-Male-to...=item23262b0dfa or similar?
The company's claims are, I'm going to bet, total snake oil. I wouldn't worry much about cable quality for this application.
This post has been edited by Canar: Feb 28 2013, 00:03
You cannot ABX the rustling of jimmies.
No mouse? No problem.
mixminus1
post Feb 28 2013, 00:18
If interference from the +5VDC power conductors into the data conductors was an issue, USB wouldn't work - at all.
If you/a manufacturer is at all concerned about the quality of the power being supplied from a USB port, the much, much simpler and reasonable solution is to just use an external power supply.
o-l-a-v
post Feb 28 2013, 01:48
QUOTE (mixminus1 @ Feb 28 2013, 00:18) *
Like this one?
http://www.aqvox.de/usb-power_en.html
RSS Lo-Fi Version Time is now: 25th December 2014 - 09:11
