22 Pages V  « < 12 13 14 15 16 > »
foo_dumb, experimental new modplugin, by Kode54
kode54
post Aug 7 2012, 05:36
Post #326
Group: Admin
Fixed. Looks like I was a little over zealous when it came to shrunken format parsing. Looks like packed files always have sample headers of 0x28 bytes, and any files that specify sample header sizes smaller than that are lying.
jswagner
post Aug 30 2012, 09:16
Post #327
Possibly a stupid question: I don't care about the unassigned patterns in a module, is there some workaround that will allow me to write APEv2 tags to these files (I'm hoping for a solution other than 'delete the patterns from an editor and save to a new file').
Any possibility of supporting Phoenix's '.GDM', which are just .S3M files with hacked headers, as used in his Whiplash musicdisk?:
http://www.scene.org/file.php?file=/music/...ip&fileinfo
Melchior
post Sep 2 2012, 22:36
Post #328
I wanted to let you know the link to your updated version of
DUMB Module decoder - Download
is redirecting back to the foobar main download page...
I wasn't sure if the file was missing ie not uploaded yet or what.. but I just wanted to let you know(helping out I guess) biggrin.gif
db1989
post Sep 2 2012, 23:30
Post #329
Worked for me.
kode54
post Sep 3 2012, 01:33
Post #330
Group: Admin
You must download within 5-10 minutes of loading the page, or else the links become stale.
Melchior
post Sep 3 2012, 02:46
Post #331
QUOTE (kode54 @ Sep 2 2012, 20:33) *
.... I never am more then a few seconds away from clicking the download button... its working now...
but its weird though as I have never encountered it before....
This post has been edited by Melchior: Sep 3 2012, 02:47
jswagner
post Sep 4 2012, 00:57
Post #332
QUOTE (jswagner @ Aug 30 2012, 09:16) *
Any comment on this?
kode54
post Sep 4 2012, 02:18
Post #333
Group: Admin
I'll get around to supporting a tag database instead of writing tags to files.
k8o
post Sep 4 2012, 20:09
Post #334
Hi, I just wanted to thank you for this plugin, it's very useful to me and your frequent updates are much appreciated. I play back a lot of demoscene music and the integration into foobar using your plugin is really welcome and very well executed, great work!
Melchior
post Sep 4 2012, 20:25
Post #335
QUOTE (k8o @ Sep 4 2012, 15:09) *
I love it as well, some PC Video Games link Uplink use .mod and .s3m files biggrin.gif biggrin.gif
all the frequent updates are much Appreciated biggrin.gif biggrin.gif biggrin.gif biggrin.gif biggrin.gif biggrin.gif
kode54
post Sep 5 2012, 01:14
Post #336
Group: Admin
Tag database implemented, enjoy safely tagging or untagging any module files in your system, compressed or otherwise, without actually affecting the files. All tags will be stored in an index database, with the same retention rules as foo_playcount. Any fields you remove from the meta view will be removed from the tags you reload from the file until you re-add them manually. I may add a system to restore the files' built-in tags, or remove the database tags, but this should be fine for now, since the information removed or added is only stored in an index file.
jswagner
post Sep 6 2012, 23:53
Post #337
QUOTE (kode54 @ Sep 5 2012, 01:14) *
This is incredible! Thank you so much!
deus-ex
post Sep 19 2012, 15:32
Post #338
Foo_DUMB Module decoder 0.9.9.63 crashes trying to load module Tw-Solar.it (included in uploaded archive along with crash report).
I was able to recreate the crash with a vanilla out of the box installation of foobar2000 with foo_dumb being the only additional plugin.
Best regards
deus-ex (MODLAND admin: ftp://modland.ziphoid.com)
kode54
post Sep 20 2012, 04:32
Post #339
Group: Admin
Fixed.
ltrts
post Dec 16 2012, 06:19
Post #340
0.9.9.73 seems to use the wrong samples throughout when playing mptitle.mod.
kode54
post Dec 16 2012, 08:04
Post #341
Group: Admin
That was due to a new pattern counting method, which assumes that there is no extra sample data, and that all of the even multiples of 256 bytes per channel are patterns. I reverted that, and now it only counts patterns from the order list, assuming sample data immediately follows the highest played pattern, and ignores any data past the samples. This breaks olof_gustafsson_-_steelchambers2.mod, but too bad, the opposite breaks a lot more files.
vjacob
post Dec 26 2012, 03:51
Post #342
This is awesome. Thanks a bunch, kode54! Just made my day... and returned(?) a bit of sanity =:)
Observations so far, relative to Schism Tracker (another interesting program):
# Processing files initially takes a fair amount of time using Foobar2000 + foo_dumb.
# The sound appears more raw or less filtered.
# Accuracy seems comparable so far if not just as good.
# Finally, worlds of difference in terms of resources (no actual scientific comparisons done, this is purely subjective).
Cheers man... merry holidays and a happy new year to you and the community!
This post has been edited by vjacob: Dec 26 2012, 03:52
deus-ex
post Dec 29 2012, 12:10
Post #343
Playback of the lead instrument (flute) in you can do it better.it is off, first occurrence at end of pattern 07, again at end of pattern 08.
Tested with foo_dumb v0.9.9.76, used to play fine in older versions.
Best regards
kode54
post Dec 30 2012, 03:10
Post #344
Group: Admin
Actually, that bug has been around for several versions now. Fixed now.
It affected IT fine and extra fine portamento up effect (FFx/FEx) when NNA voices were active on the channel. The bug was due to code applying the effect still referencing the channel's main voice instead of the NNA voices it also iterates over.
What would I ever do without you? Don't ever stop listening to modules with this thing. biggrin.gif
deus-ex
post Dec 30 2012, 12:09
Post #345
QUOTE (kode54 @ Dec 30 2012, 04:10) *
Thank you too for being around and sharing all these great plugins with us. You have build quite an impressive set over the past years.
Best regards
mezenga
post Dec 30 2012, 18:33
Post #346
These ProTracker modules arenīt played correctly with foo_dumb 0.9.9.77 and 0.9.9.66:
They both play fine on foo_dumb 0.9.9.53.
deus-ex
post Dec 30 2012, 19:56
Post #347
Hi mezenga,
I confirm that replay of groovy lemon.mod is quite off, checked with foo_dumb v0.9.9.77.
But I cannot spot any issues with joyride.mod, please elaborate on this one.
Best regards
kode54
post Dec 30 2012, 20:09
Post #348
Group: Admin
Fixed. But I broke PC_BOOK2.MOD in the process, at least in the default mode.
Stefan1200
post Jan 12 2013, 09:18
Post #349
Thanks for this great plugin, it sounds good.
I have some MMD0 files (OctaMed) which can't be played with your plugin. Is it possible to see support for it some day? If you need an example file I can send you one.
deus-ex
post Jan 12 2013, 20:40
Post #350
I just noticed you released another update of foo_dumb. Wouldn't you agree it's about time and very well justified to increase the main version number from 0 to 1? Looking back at my first post in this thread almost eight and a half year have past! smile.gif
Best regards
RSS Lo-Fi Version Time is now: 17th September 2014 - 04:41
