I am trying to break down some MPC using the supplied CUE
Marc
post Aug 7 2008, 21:57
but when I split the files there is a terrible noise at the beginning of each track/or several seconds of silence before the music starts. On some there is also a lot up to 7 seconds of silence at the end of some tracks. The MPC plays fine before it's split . Any suggestions?
Marc
r2d
post Aug 9 2008, 19:37
Musepack Developer
You can convert your file to sv8 (it's lossless) and then use the mpccut utility to split your file. There is no correct way to cut a sv7 file.
Marc
post Aug 9 2008, 19:43
Thanks I ended up converting them to wav rewriting the cues and going from there is worked fine. I didn't even think of up convwering them to SV8. I'll remeber that.
Marc
QUOTE (r2d @ Aug 9 2008, 14:37) *
drumliner
post Sep 11 2008, 21:11
I would also like to cut an mpc image of a cd into separate tracks. I tried converting it to SV8 and the resulting file is 2mb smaller (106mb SV8 vs 108mb SV7). Is that normal? Seems like a relatively large reduction in size for a simple lossless conversion between the 2 variants.
Also is there an automated way to cut the resulting mpc SV8 image using a cue file? Manually using the mpccut and entering start/end samples for each track would be quite the proverbial pita.
One last thing... is there a winamp plugin for the sv8?
Antonski
post Sep 30 2008, 16:49
QUOTE (drumliner @ Sep 11 2008, 23:11) *
The new entropy coding of the stream gives about 2% smaller files and faster decoding.
Yes, if you don't want to compile by yourself, you can find one in that package.
Well, I might think about some simple tool. I have to prepare an mpc image + cue file first. And to find some free time smile.gif
RSS Lo-Fi Version Time is now: 2nd August 2015 - 23:28
