Playing multiple song files with multiple seekbars?
fohrums
post Feb 10 2013, 04:29
I want to mix for my own personal use to have fun with my library, finally. Is there a way I can mix within Foobar to play multiple songs and since I use waveform to seek my music is it possible to display two seekbars or more? I do'nt think you need to spend money on a mixer when you can just use a few tools that don't cost a damn cent and still produce good stuff.
marc2003
post Feb 11 2013, 10:21
run another instance of foobar (install it in portable mode).
fohrums
post Feb 22 2013, 00:10
QUOTE (marc2003 @ Feb 11 2013, 10:21) *
I can't run multiple versions of Foobar2000. I do have it configured as Portable Installation when I installed it to a custom directory.
could it be a plugin conflict? How can I easily post all my plugins?
This post has been edited by fohrums: Feb 22 2013, 00:11
mudlord
post Feb 22 2013, 02:20
Group: Developer (Donating)
Components > Copy report.
carpman
post Feb 22 2013, 05:01
Just for the sake of clarity when marc2003 says run another instance of foobar2000 he means a completely separate portable install i.e. not the same foobar2000.exe run twice. You probably already knew that, but just in case ...
Example:
C:\Program Files (x86)\foobar2000\1\foobar2000\foobar2000.exe [normal install]
C:\Program Files (x86)\foobar2000\2\foobar2000\foobar2000.exe [portable]
C:\Program Files (x86)\foobar2000\3\foobar2000\foobar2000.exe [portable]
And since it's portable you can just copy and paste from 2 to 3 (keeping all components and settings uniform).
C.
TAK -p4m :: LossyWAV -q 6 | TAK :: Lame 3.98 -V 2
marc2003
post Feb 22 2013, 10:36
not a good idea. a portable install should not be placed inside program files because it needs write access to create all it's config files/playlists/etc. you really shouldn't be running as full admin or disabling UAC to get around this.
dumping the folder in your documents folder or desktop would be much better.
carpman
post Feb 22 2013, 21:45
Oh I forgot about that kind of thing. Thanks for putting me right for OP.
I run as admin with UAC control disabled (by default - so didn't even realise I was getting around anything) since no one else uses this desktop. Will keep in mind for future.
C.
EDIT: That's precisely why I run as admin without UAC. Portable programs should run in program files; they are not documents. To me this is MS trying to cater for everyone to the detriment of their end product.
This post has been edited by carpman: Feb 22 2013, 21:52
RSS Lo-Fi Version Time is now: 26th May 2015 - 08:06
