> foobar2000 Development Forum Rules
This forum is for developer discussions only. If you have a problem / bug report / idea / feature request that isn't related to foobar2000 SDK, post it in an appropiate forum instead - tech support questions go to support forum, everything else goes to general forum.
All non-developer posts on this forum will be removed. Continued abuse of this forum will result in admin actions (warnings, account suspension).
Decode AAC samples
dsh
post Feb 22 2012, 15:48
I trying decode raw AAC frames with my ADTS header (20050Hz, stereo), if I use internal decoder, decoder "run" method raise exception. If I play file with raw frames + my ADTS headers, foobar play file corectly. I don't understand why foobar decoder reject my frames.
kode54
post Feb 22 2012, 21:00
Group: Admin
As far as I know, the internal decoder does not support raw AAC frames, only ADTS.
dsh
post Feb 22 2012, 22:45
Raw AAC frames (44100Hz, stereo) internal decoder decode correctly, but each AAC frame stored in file must always have ADTS header. What decoder library is used in internal decoder?
kode54
post Feb 23 2012, 01:12
Group: Admin
FAAD2.
dsh
post Feb 23 2012, 15:00
Is it possible implement by Foobar devs support RAW AAC 22050Hz? (RAW AAC 44100Hz works fine) FAAD2 decode raw stream (RAW AAC 22050Hz) correctly, but I would like use internal decoder against external libaries.
kode54
post Feb 23 2012, 17:55
Group: Admin
Maybe if you post some test streams?
dsh
post Feb 23 2012, 21:04
Samples:
Files with r1 extensions contains raw AAC frames with frame size.
Samples
Frames:
int32 - frame size
byte[size] - frame data RAW ACC
RSS Lo-Fi Version Time is now: 23rd September 2014 - 04:11
