Hotkeys from Logitech mouse Setpoint, are lost if fb2k window is active
balauser
post Oct 14 2012, 08:45
Hello! I admit that this is most likely not a foobar problem, but maybe someone here had this issue..
I got used to control the foobar playback by tilting the logitech mouse wheel left and right.
The only working method for this that I found is to bind a "Keystroke" to this tilt in Logitech Setpoint, Ctrl-Alt-X for example. And after that set a global hotkey Ctrl-Alt-X as pause.
It was working ok before I moved to windows 8. In here it is still working fine "globally" when fb2k is in background. But when fb window is active - it is not working, Setpoint's keystroke is lost somewhere.
I'd blame setpoint or windows 8 first, but I tested those "keystrokes" in notepad active window - and they are working there, something different with foobar window.
Any ideas?
P.S. ..or maybe there is an easier way to do what I want?
Emerelle
post Oct 14 2012, 08:55
You could get a tool called StrokeIt, mouse gestures for any application working with all mice.
balauser
post Oct 14 2012, 11:44
QUOTE (Emerelle @ Oct 14 2012, 08:55) *
Yes, seems good but it supports only LMB and RMB..
Emerelle
post Oct 14 2012, 13:56
And you can bind any sort of shortcut to those 40+ gestures, they are the point, not the mouse buttons themselves. It works flawlessly with many gestures for foobar2000 and my logitech g700.
garbanzo.bean
post Jan 15 2013, 01:29
Old thread but no resolution. I'm having the same problem - foobar does not allow my logitech keyboard or mouse to send hotkeys when the window is active (in Windows 8). Why?
garbanzo.bean
post Jan 18 2013, 04:02
Solved it - foobar2000 was running as administrator. Uncheck that box in properties and hotkeys work once again smile.gif
RSS Lo-Fi Version Time is now: 24th May 2015 - 22:26
