18 Pages V  < 1 2 3 4 5 > »
qtaacenc: a command-line QuickTime AAC encoder for Windows
tedgo
post Feb 2 2010, 21:35
Post #51
@punkrockdude
I noticed this too. Also when i encode files in iTunes or with iTunesEncode.
It seems that QuickTime auto-scales the volume down to avoid clipping.
This post has been edited by tedgo: Feb 2 2010, 21:42
b66pak
post Feb 2 2010, 21:38
Post #52
QUOTE (b66pak @ Feb 2 2010, 22:34) *
ok...i have done some tests...here are the results...
the qtaacenc encoder accepts wav's up to 32float (mono or stereo ONLY)...
if found that is limited (an old apple flaw!!!) to maximum 186 minutes for a 32float@48000hz wav or 279 minutes for a 24bit@48000hz wav and 327 minutes for a 16bit@48000hz wav!!!
the 4gb limit is on apple side of the encoder...i test it using the STDIN input by feeding a +8hrs .ac3 file with 16, 24, 32, 32float bits...
_
OT: @nao considering your expertise in windows iTunes libraries do you think a CLI raw (or full) mp4 muxer can be done? (.h264 + .acc + softsubs [apple style] + chapters [apple style])
something like subler for mac...
http://code.google.com/p/subler/
_
using iTunes windows libraries instalation...
_
wkmax
post Feb 2 2010, 22:16
Post #53
QUOTE (tedgo @ Feb 2 2010, 21:35) *
@punkrockdude
If you are right about QuickTime/iTunes behavior, what about ALAC encoding? (for instance, using iTunes Encode for EAC + iTunes full integration)
lvqcl
post Feb 2 2010, 22:40
Post #54
ALAC never clips.
wkmax
post Feb 2 2010, 22:49
Post #55
QUOTE (lvqcl @ Feb 2 2010, 22:40) *
ALAC never clips.
greynol
post Feb 2 2010, 22:59
Post #56
QUOTE (tedgo @ Feb 2 2010, 12:35) *
This is quite trivial to test, so why not test it instead of speculating with words like "seems"???
tedgo
post Feb 2 2010, 23:20
Post #57
What's wrong with the word "seems"?
None of my QuickTime encoded files has a peak above 1.0 and i don't know if QuickTime auto-scales the volume or if its an issue in the encoder...
But since very low volume files aren't effected by this behaviour, i can only guess that its an autoscaling "feature".
This post has been edited by tedgo: Feb 2 2010, 23:31
lvqcl
post Feb 2 2010, 23:53
Post #58
QUOTE (tedgo @ Feb 2 2010, 23:35) *
It looks like limiter really. Something like 'advanced limiter' in foobar2000...
It doesn't change input signal if it is less than -0.5 dBFS (approximately!).
This post has been edited by lvqcl: Feb 2 2010, 23:56
greynol
post Feb 3 2010, 00:07
Post #59
I implicitly trust lvqcl, so I won't continue to make an issue out of this except to say one can easily take a loud and likely "clippressed" track that routinely peaks at full-scale, encode and then decode to see if it has a reduction in level.
Maybe it's unrealistic, but I have an expectation that HA members will invest the very short amount of time it takes to test these kinds of things before making statements about what they only think is going on. If this is a matter of having done this in the past and not being certain of the results then I extend my apologies.
This post has been edited by greynol: Feb 3 2010, 00:08
tedgo
post Feb 3 2010, 00:20
Post #60
QUOTE (greynol @ Feb 3 2010, 00:07) *
How do you think did i noticed it?
And why don't trust "seems" but "looks like"?
greynol
post Feb 3 2010, 00:28
Post #61
You're over-reacting. I already said I apologize if you had tested this previously.
The thing is that lvqcl gave the impression that he actually conducted a test whereas you did not.
singaiya
post Feb 3 2010, 06:57
Post #62
QUOTE (lvqcl @ Feb 1 2010, 07:35) *
Quick test:
lame -V 6.248: 126 kbps
lame -V 6.249: 115 kbps
qtaacenc --tvbr 59: 135 kbps
qtaacenc --tvbr 58: 105 kbps
(and qtaacenc --tvbr 58 --samplerate keep: 114 kbps)
I cannot say that 126 is 'much lower' than 135 kbps.
When talking of "much lower" I was thinking of NeroAAC but said mp3 by mistake. The last encoder I used was Nero 1.1.1.3 (I think that's the version before 1.3.3) at ~104 kbps (Q0.25 -LC) and that encoder/setting does not resample to 32 kHz.
Anyway I found a strange behavior with qtaacenc output and iTunes/iPod. Both iTunes and iPod will stop playback at 71.6% through a file. I tested this on three files and they all skipped at different absolute times, but they were each 71.6% of the way through the total time of the file. This behavior does not happen with foobar, but it does both on iTunes 9.0.1.8 and iPod 160 GB version 2.0.2. My command line is --tvbr 59 --highest %s %d.
EDIT: I'm using qtaacenc 20100107. I'll try it with the latest version tomorrow.
This post has been edited by singaiya: Feb 3 2010, 07:11
lvqcl
post Feb 3 2010, 16:24
Post #63
QUOTE (lvqcl @ Feb 3 2010, 01:53) *
I did more test and found the following:
1) Target level is 0.95 (i.e. -0.446 dBFS);
2) Lookahed time is ~5 ms;
3) Attack time is ~ 3 ms;
4) Release time is 11.5 sec (and, gain value raises linearly from 0.95 to 1).
Added: the above values are valid for --normal and --high settings. For --fast: target level = 0.925, release time ~ 17.5 sec.
This post has been edited by lvqcl: Feb 19 2010, 19:22
singaiya
post Feb 4 2010, 05:10
Post #64
QUOTE (singaiya @ Feb 2 2010, 21:57) *
Update on this: I really don't know what happened with that particular set of three albums I encoded to produce that strange behavior reported earlier. I deleted those QT AAC files and re-encoded from flac, using the exact same method, encoder, and settings, and the files play normally in both iTunes/iPod without skipping to the next song at 71.6% of the current song.
Xire
post Feb 4 2010, 13:56
Post #65
QUOTE (nao @ Jan 22 2010, 13:15) *
Any comments or questions are accepted in this thread.
Maybe a bit off-topic, but would it be possible to add alac 24bit encoding to this tool?
This post has been edited by Xire: Feb 4 2010, 13:57
nao
post Feb 4 2010, 15:41
Post #66
QUOTE (Xire @ Feb 4 2010, 21:56) *
Possible but I have no plan to implement the feature in this tool.
rpp3po
post Feb 4 2010, 17:20
Post #67
I just realized that nao is 'tmkk', the author of XLD! Creator of one of my most used tools.
If you want to support his work, the XLD page has a donation button.
kornchild2002
post Feb 4 2010, 23:08
Post #68
XLD is a nice tool. I have thought about purchasing a Mac Mini just to use Mac OS X, a couple of other programs, and XLD for QuickTime true VBR AAC encoding. Interesting that someone on the Mac OS X side would finally develop a Windows solution.
Is there anymore insight into the issue with QuickTime/foobar2000 scaling the audio? Is it a setting in foobar2000 or was it an issue with QuickTime (can it be disabled)?
tedgo
post Feb 4 2010, 23:51
Post #69
The scaling has nothing to do with foobar2000, must be on QuickTime's side.
I tried it with converting a near full-scaled file using CVBR in iTunes and TVBR with qtaacenc (directly from command prompt).
Original WAV file (peak and gain taken from an WavPack encoded from it)
Peak: 0.999908
Gain: -6.61 dB
qtaacenc file (directly encoded from WAV via command prompt, --tvbr 127 --highest)
Peak: 0.968920
Gain: -6.18 dB
iTunes (directly encoded from WAV in iTunes, 320kbps, CVBR)
Peak: 0.969976
Gain: -6.18 dB
Checked with Nero AAC (in foobar2000, Q1.0)
Peak: 1.020406
Gain: -6.60 dB
As you can see, both QT encodings are slightly scaled down.
I would also like to know if this scaling could be disabled...
This post has been edited by tedgo: Feb 4 2010, 23:53
rpp3po
post Feb 4 2010, 23:58
Post #70
Lossy compression adds energy due to filtering artifacts. So scaling down is the right thing to do for ridiculously high peaking tracks as 0.999908 db, else there would be clipping. And 0.969976 db shows that Quicktime is scaling down in incredibly sensible fashion. It does nothing at all for tracks that wouldn't clip. I don't understand why it is called an "issue" and why anyone would want to disable it (and get guaranteed clipping at these levels). It's not a bug, it's a feature! smile.gif
This post has been edited by rpp3po: Feb 5 2010, 00:16
richard123
post Feb 5 2010, 17:33
Post #71
QUOTE (wkmax @ Jan 24 2010, 06:23) *
Are these bitrates values correct for qtaacenc?:
[i]Target Quality - True VBR AAC (Powered by QuickTime & CoreAudio):
Q50 - Q58 = ~115 kbps
In the listening test thread, two testers got ~128 kbps for Q58
http://www.hydrogenaudio.org/forums/index....st&p=685645
rpp3po
post Feb 5 2010, 17:37
Post #72
QUOTE (richard123 @ Feb 5 2010, 17:33) *
Nope, it was Q59.
richard123
post Feb 5 2010, 19:07
Post #73
QUOTE (rpp3po @ Feb 5 2010, 11:37) *
Nope, it was Q59.
Oops. I used to be able to read.
In that case, your result of 129kbps is close to wkmax's
Q59 - Q68 = ~135 kbps
gaekwad2
post Feb 5 2010, 19:52
Post #74
QUOTE (rpp3po @ Feb 4 2010, 23:58) *
Because, I assume, they use Replaygain which, unlike QuickTime's limiter, will prevent clipping without affecting dynamics (though, whether it makes an audible difference...).
Besides, it's not always strong enough to prevent clipping anyway:
(--tvbr 100 --highest, encoded from FLAC wich has an album gain of -11.36dB)
rpp3po
post Feb 5 2010, 20:27
Post #75
QUOTE (gaekwad2 @ Feb 5 2010, 19:52) *
ReplayGain cannot prevent clipping that has already happened. Or is AAC unclippable if you output to float?
This post has been edited by rpp3po: Feb 5 2010, 20:33
RSS Lo-Fi Version Time is now: 24th May 2015 - 17:35
