IPB
low bitrates in APX
chriszarate
post Jul 26 2002, 20:45
Post #1
Group: Members
I recently encoded Atari Teenage Riot's album "Burn, Berlin, Burn!" with Lame 3.90.2 and --alt-preset extreme. Many of the tracks ended up with curiously low bitrates, including one at 143. Is this something to be worried about? I haven't been able to test yet on good equipment, but can APX produce bitrates that low without compromising quality?
Go to the top of the page
+Quote Post
ty1er
post Jul 26 2002, 21:21
Post #2
Group: Members
which program are you using to find out the average bitrate?
I know that EncStop by default only scan the first 1000 frames of an mp3 file. Maybe if there is a lot of silence/easily encoded music in the beginning of the song that could be the reason of a reported low bitrate. If you are using encspot do a full scan of the files.
if your not using encspot, disreguard my pointless post.
-ty1er
+Quote Post
[JAZ]
post Jul 26 2002, 21:31
Post #3
Group: Members
I wonder how people can't understand what VBR is.
If it was to have the same bitrate it would be called CBR, if it was to have an average bitrate of X, it would be ABR x.
But it is none of them, it's VBR.
Of course there could be a potential problem where it would fail, but just seeing a low average bitrate should give you more glory than worry (more space for you to be used).
Again, aps is said to create files about 200kbps. Sometimes, it creates files up to 260kbps or even more. At the same time, files with lower bitrate are perfectly understandable, because if not, how would 200kbps be the average?
+Quote Post
chriszarate
post Jul 26 2002, 21:39
Post #4
Group: Members
QUOTE
APX typically produces bitrates ~250 so 143 is WELL below that range. No need to be a jackass. I was just wondering if it was possible that APX could be failing or is 148 within the realm of possibility on a song with no silence?
+Quote Post
chriszarate
post Jul 26 2002, 21:45
Post #5
Group: Members
QUOTE
Full scan reveals 144 for that particular song (51% 128, 43% 160, 4% 192).
It just struck me as odd because the previous song (which sounds similar, at least to my human ear) was 268. Reencoding produces same results.
+Quote Post
maciey
post Jul 26 2002, 21:51
Post #6
Group: Members
can You check whether the tracks aren't MONO or almost-MONO ? You know - ATR may have used very "special" techniques during recording - so this may be the case smile.gif
+Quote Post
john33
post Jul 26 2002, 21:56
Post #7
xcLame and OggDropXPd Developer
Group: Developer
An upper bitrate of 192 is certainly far lower than would be expected.
John
My compiles and utilities are at http://www.rarewares.org/
+Quote Post
chriszarate
post Jul 26 2002, 22:15
Post #8
Group: Members
QUOTE
I don't have EncSpot Pro so I can't tell exactly how many frames, but there are some 224, 256, 320; just not many.
[b]maciey
, the files are not mono, so do you mean if the two tracks match up exactly? Will EAC let me do a compare like this on the original WAV?
Now that I look at it, on the tracks where bitrate is low, EncSpot shows 99.X% ms-type Joint Stereo. On tracks where bitrate is higher, it is more evenly distributed between ms-type and ss-type. Could this because of what maciey is saying?
+Quote Post
JohnV
post Jul 27 2002, 00:23
Post #9
Group: Developer
Try adding -Z switch if you want somewhat higher bitrates.
IMO APX should anyway use only noiseshaping-type 1 by default just like insane in order to guarantee max quality.
Yes, joint-stereo saves quite a lot of bits, if it's used as much as it is in that case.
Juha Laaksonheimo
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 6th March 2015 - 01:36
