75 Pages V  < 1 2 3 4 > »
foo_wave_seekbar, pretty accelerated seekbar
wojtek
post Jan 3 2010, 22:30
Post #26
Works beautifully after Direct upgrade.
http://foobar2000.pl/ :: unofficial polish forum
Jack Schmaltz
post Jan 3 2010, 22:39
Post #27
dont know if im missing something here but i can not get this to load.
keep getting this:
Failed to load DLL: foo_wave_seekbar.dll
Reason: Wrong version number; this component appears to have been built with a newer version of the foobar2000 SDK, please download latest version of foobar2000 in order to use it.
i have installed the DirectX August 2009 runtime redistributable & already had the Microsoft Visual C++ 2008 Redistributable Package installed.
running v0.9.6.9 on Vista Ultimate SP2, any ideas? thanks
http://www.discogs.com/user/jackschmaltz
Zao
post Jan 3 2010, 22:49
Post #28
Group: Members (Donating)
I would guess that the SDK most probably has 1.0 as a minimum version by default.
Also, it does not require the VC++ redist as it's statically linked against VC10's CRT.
Jack Schmaltz
post Jan 3 2010, 22:54
Post #29
fair enough, at least i know its not me being a numpty then.
so this is only for v1.0 of foobar then? will it be staying like this or will it be made compatible with the current stable version?
Zao
post Jan 3 2010, 23:16
Post #30
The baseline will most probably be 1.0 as I cannot see any smooth way to support older ones except for modifying the SDK (would probably backfire horribly) or downgrade the SDK (no thanks).
ExtremeHunter
post Jan 3 2010, 23:53
Post #31
Works fine on Windows 7 64bit.
dubpistol
post Jan 3 2010, 23:54
Post #32
Brilliant component.
Thank you!
insnowflakes
post Jan 4 2010, 00:25
Post #33
Great mod, thanks a lot.
mudlord
post Jan 4 2010, 00:32
Post #34
Group: Developer (Donating)
QUOTE (ExtremeHunter @ Jan 3 2010, 17:53) *
Have to echo those sentiments. Works great on 64bit Win7 and with the Direct2D renderer.
Horst Fux
post Jan 4 2010, 00:54
Post #35
Just awesome, works perfect.
But needs a little bit time to analyse the song, though. It's great anyways.
One request:
In the normal seekbar I can abort the seeking by pressing Esc while holding the bar; would it be possible?
It's not like I need this feature everyday but sometimes.
This post has been edited by Horst Fux: Jan 4 2010, 00:58
Zao
post Jan 4 2010, 01:06
Post #36
You can abort seeking by moving your cursor far enough away from the bar while dragging, much like scrollbars in Windows in general.
mudlord
post Jan 4 2010, 02:08
Post #37
Thats expected, as it needs to do a FFT on the stream to get the spectrum readout.
Zao
post Jan 4 2010, 02:19
Post #38
No FFT needed, as it's min/max/rms amplitude over time. I haven't profiled it, but there's not much to improve; most of the cost is in IO, which I guess could be serialized to get sequential disk reads.
It already runs up to three concurrent worker threads for the scan jobs, so it's already taking advantage of multiple cores if available.
randal1013
post Jan 4 2010, 02:50
Post #39
crashes my foobar when i try to place the component.
win7 x64, foobar 1.0 beta6
will directx 9.0c co-exist peacefully with directx 11?
This post has been edited by randal1013: Jan 4 2010, 02:55
Zao
post Jan 4 2010, 03:00
Post #40
Yes, they coexist perfectly fine.
What kind of graphics hardware do you have? The crash is when trying to load the effect. Try 0.1.3.
This post has been edited by Zao: Jan 4 2010, 03:17
NullString
post Jan 4 2010, 03:35
Post #41
works like a charm wink.gif gj
This post has been edited by NullString: Jan 4 2010, 03:38
Zao
post Jan 4 2010, 03:42
Post #42
QUOTE (NullString @ Jan 4 2010, 03:35) *
how does the db cope with moving of files, or tag modifications?
the scanning of tracks is fast and all that, but takes its time when considering lots of albums.
As mentioned in the first post, it doesn't track moved or renamed files. It associates the scanned data with the location (path + subsong) of the track.
Removing dead items and rescanning tends to be feasible, but I realize that things like moving your whole music library to a different drive or portable installs could be painful.
It is possible to change the locations in the storage database, but currently one has to resort to the standalone sqlite3 client as the component does not expose any such functionality yet.
NullString
post Jan 4 2010, 04:50
Post #43
QUOTE (Zao @ Jan 3 2010, 23:42) *
thanks, sounds interesting, maybe to make some reports with the data in the db, I'll give it a look
Snowknight26
post Jan 4 2010, 05:18
Post #44
If only you could replace the toolbar's seekbar with this one..
midkay
post Jan 4 2010, 05:27
Post #45
this is awesome, thanks for the great work!
mudlord
post Jan 4 2010, 07:36
Post #46
QUOTE (Zao @ Jan 3 2010, 20:19) *
Thanks for the correction.
(Sly)
post Jan 4 2010, 08:28
Post #47
Works fine with Windows XP SP3, DirectX 9.0c latest and crappy Intel Mobile 965.
Nice component !!
I have 3 requests:
1. What about decentralized wavecache.db, as is thumbs.db for picture thumbnails. Every folder has it's own Database. Or even to write to ID3 tag in something like WAVEFORM.
2. A scanning engine like replaygain or foo_bpm.
3. For Default UI make it available as toolbar element, too.
This post has been edited by (Sly): Jan 4 2010, 08:33
LAME 3.99.5 -V0
Zao
post Jan 4 2010, 08:46
Post #48
1. Per-folder databases could technically be possible, but they would interfere with things like the renamer deleting/moving old folder contents. As for storing them in tags, it too is technically possible.
2. Elaborate. Are you referring to some kind of progress bar? That is planned eventually.
3. There exists no SDK interface to make non-button toolbar elements.
dubpistol
post Jan 4 2010, 09:35
Post #49
QUOTE (skelly831 @ Jan 3 2010, 22:14) *
I just want to ask for a tooltip that shows the bars' time when I drag it, like the standard seekbar
I follow up this question.
(Sly)
post Jan 4 2010, 10:23
Post #50
2. Yes. And a scan results window showing if some files failed to scan for example.
For big files like comedy shows (60min+) it should display intermediate results of the on-the-fly scanning. like Virtual DJ does.
LAME 3.99.5 -V0
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: DeadSix27
RSS Lo-Fi Version Time is now: 4th August 2015 - 15:26
