14 Pages V  « < 11 12 13 14 >
Album Art Downloader, was CoverDownloader
fuffi
post Sep 8 2007, 17:08
Post #301
2Marc Landis
thank you, this program! works like a charme!
anyway, using it, lets me think, i have some problems with my eyes 8-)
the font, compared to all other windows, seems blurry.
is there a way to disable this?
keep up the good work!
thanks again.
AlexVallat
post Sep 8 2007, 18:52
Post #302
QUOTE (fuffi @ Sep 8 2007, 17:08) *
2Marc Landis
thanks again.
The blurry-fonted one would be my XUI version, I think, not Mark's original! :-) It's called anti-aliasing, is part of how the WPF framework draws itself, and as far as I can tell, there is no way to turn it off, sorry. Anti-aliasing and clear-type seems to be in fashion at the moment, although I've got to say I'm more in agreement with you that font-fuzzing is not the great step forwards it is made out to be.
Alex
fuffi
post Sep 8 2007, 20:06
Post #303
QUOTE (AlexVallat @ Sep 8 2007, 17:52) *
Alex
thanks for that fast response and the clarification :-)
i originally came from a google search for "cover downloader for foobar", landed at the cover downloader-thead here, installed it and tested it, then, at the end of the thread, there was a new topic, which leads me to the album art downloader, which i downloaded and tested as well, and on sourceforge, where i wanted it to download, i saw the XUI version and now i'm totally confused, *but* have a working program for downloading covers *and* a wonderful crew, which helps here in the forum! :-) thanks for that, too!!
cheers,
AlexVallat
post Sep 9 2007, 09:06
Post #304
AlbumArt Downloader XUI v0.9 Released
It's been a while, I know, but I hope you find this latest release to be worth the wait. I've made some major improvements to performance, particularly when dealing with larger numbers of results, and using the Automatic Full-size Image download options.
I've also finally added a Foobar2000 library browser - to use this you will have to have the Foobar2000 COM Automation Server installed, though.
Another new addition is a persistent preview window. If, instead of holding down the mouse on a thumbnail, you right click on it and select "Preview..." then a new window is opened to preview that result, which will only be closed when you close it, and allows you to zoom and pan around the image.
As requested, there is now a command line parameter for sorting:
/sort (name|size|source)[+|-]
              Sets the sorting to use for the (/sort size-)
              results.
              May be abbreviated to /o        (/o size-)
              The first character may be - to
              indicate descending search, or
              + to indicate ascending. If it
              is omitted, ascending is assumed.
              The field to sort by must be one
              of:
               name (may be abbreviated to n) (/o n+)
               size (may be abbreviated to s)
               source (may be abbreviated to o)
Changelog:
  • Added Foobar2000 library browser
  • Added Persistent Preview window (should do the job, dano *)
  • Improved performance of search results thumbnails list (hope this helps, phunkydizco *)
  • Improved handling of larger-than-screen preview popups
  • Fixed Coveralia and Yes24 scripts which had become out of date
  • Updated to version 0.7.5.2 of the MediaInfo tag reading library
  • Added command line parameter for setting the sorting to use for results (as requested, hal9001 *)
  • All sources now limit the results returned to the first 10 by default. Click the ... at the bottom right of a source to adjust or remove this limit for a source
  • Fixed bug where all windows would share a single remembered size, so windows of different types now remember their size independently.
  • Added re-use of existing search window from the command line, if "Open Results in New Window" option is turned off, and there is only one search window currently open, and search terms are passed on the command line. (as requested, hal9001 *)
Download:
I'm moving Album Art Downloader XUI to a new thread. This one is getting a little unwieldy, and not controlling the top post is becoming a hassle (it still links to 0.4!). I hope you'll all join me over here:
Where the first post has, and should always have, download links to the latest version.
Thanks,
Alex
This post has been edited by AlexVallat: Sep 9 2007, 09:07
Synthetic Soul
post Sep 9 2007, 12:40
Post #305
I have inserted a link to the new thread in the first post.
I'm on a horse.
iElectric
post Sep 16 2007, 16:22
Post #306
I get error when processing 157 files in queue:
http://cl1p.net/downloadartalbum/
TedFromAccountin...
post Sep 29 2007, 16:45
Post #307
Has anyone created a script for buy.com yet?
Totyo
post Feb 6 2008, 08:28
Post #308
please create a script for http://www.junodownload.com/
radi0n
post Feb 17 2008, 14:44
Post #309
I pun in Run services (Foobar):
C:\Program Files (x86)\AlbumArtDownloader\AlbumArt.exe "%artist%" "%album%" "$replace(%path%,%filename_ext%,folder.jpg)"
and it dont work.Now i use vista 64bit system. but when i use xp 32bit script works fine.
www.skinnypuppy.eu
Bollerkopp
post Feb 29 2008, 15:13
Post #310
hi,
i tried to use foo_run with this album art downloader: http://sourceforge.net/projects/album-art
but my code doesn't work. when i klick the foo_run-command, but nothing happens sad.gif .NET framework 2.0 is installed.
this is my code:
"D:\Programme\foobar2000\Coverdownloader\albumart.exe" -ar "%artist%" -al "%album%" -p "$replace(%_path%,%_filename_ext%,)" -f "cover.jpg"
any ideas?
This post has been edited by Bollerkopp: Feb 29 2008, 15:26
LXtreme
post Feb 29 2008, 20:49
Post #311
QUOTE (Bollerkopp @ Feb 29 2008, 15:13) *
any ideas?
i use the latest foo_run and the latest AAD...for me the following works...
D:\Programme\foobar2000\Coverdownloader\albumart.exe -ar "%artist%" -al "%album%" -p "$replace(%_path%,%_filename_ext%,)cover.jpg"
thuan
post Mar 1 2008, 01:55
Post #312
I don't know which version you use, but if it is of the XUI branch, you need .NET 3.5 to run its latest version.
sleepy_yellow
post Mar 11 2008, 20:44
Post #313
for some reason i cant see any other posts expect for the first one so i dont know if anybody asked this already.
i was able to figure it out a while back but i used album downloader a while back and awesome application love it.
however i was never able to figure out how to make the images save into the directory, i mean i saw this one scrip for a guy that had it in his theme for got his name he used foo_run and i somehow searched out the artist and title from foobar and then saved it into the location where the file is so i dont have to go look for the directory.
his code didnt work for me.
and if i look at your syntax could i use that like that
filepath[albumart.exe] [-ar %artist%] [-al %album] [-p %path]
is it wrong if i would want it to work with foo_run?
Dreamless
post Mar 21 2008, 04:07
Post #314
sleepy yellow, use -p "$replace(%_path%,%_filename_ext%,)\"
I have a .boo request. Can someone make a amazon.jp version?
poisonborz
post Apr 24 2008, 22:57
Post #315
Hola again, AAD became an even more awesome tool since I've updated it... smile.gif
I have a feature idea: with AAD it was always a bit tricky to manage albums that had more than one Artist (VA albums) Path pattern is one way to overcome this, but here is another idea: in the browser, there could be a new sorting column: Path - this would show the file path of the element. Elements from the same folder would have no thin white margin on top/bottom as they have by default (= or other non highly visible marking)
I know you don't like methods that assume a certain path structure, but this would have little to no impact on the general feel, and is a great help to everyone who stores files in album folders (95% of users smile.gif )
(And please, even if multi-windowed gui is hardcoded, couldn't you make one parent window to hold all the others? 3-4 open windows of the same app is not a good sight even on high resolution)
This post has been edited by poisonborz: Apr 24 2008, 23:08
anonnamiss
post Apr 25 2008, 20:42
Post #316
Does this program allow you to embed art into a file?
d0ng
post Apr 25 2008, 23:14
Post #317
This thread is a bit outdated, might want to check out this thread instead. smile.gif
http://www.hydrogenaudio.org/forums/index....7392&st=320
kopf
post May 16 2008, 19:15
Post #318
just upgraded to the latest version. had to install .net framework 3.5 too.
now, when i try to search something, the program crashes, and the following error report is sent to microsoft:
EventType : clr20r3 P1 : albumart.exe P2 : 0.10.1.0 P3 : 47090190
P4 : mscorlib P5 : 2.0.0.0 P6 : 471ebc5b P7 : 1295 P8 : 25
P9 : system.typeloadexception
http://ventolin.org - sredzkistraße
kanak
post Jun 10 2008, 18:23
Post #319
Hi Alex,
I noticed that the file browser reads "artist" tag instead of "album artist" tag, which makes it difficult to use with various artist albums. Is this a bug?
ladiko
post Jul 11 2008, 07:15
Post #320
works great! do you think you could add a script for last.fm? or another website with a lot of artist images? cause i prefer artist images instead of album covers.
dewey1973
post Jul 11 2008, 08:30
Post #321
Anyone else not getting results from the Album Art Exchange script? I go to the site and the cover is there but the search returns no results in the application.
Funkstar De Luxe
post Jul 26 2008, 17:23
Post #322
QUOTE (radi0n @ Feb 17 2008, 14:44) *
I have the same problem, can't get a script to work under Visya64 at all.
http://www.animarecordings.com/
ladiko
post Jul 26 2008, 20:02
Post #323
AlbumArt.exe works on x64?
what about this script:
would show if the run component works on x64
what about running this from cmd:
"C:\Program Files (x86)\AlbumArtDownloader\AlbumArt.exe"
/ar "Beatles" /al "Help" /p "C:\Program Files (x86)\AlbumArtDownloader\covers\Beatles - Help.jpg"
would show if albumart.exe likes cmd parameters on x64
Funkstar De Luxe
post Jul 26 2008, 22:26
Post #324
QUOTE (ladiko @ Jul 26 2008, 20:02) *
Seems to work perfectly from CMD
dano
post Jul 27 2008, 09:17
Post #325
Group: Members (Donating)
Try '('x86')'
RSS Lo-Fi Version Time is now: 24th September 2014 - 01:55
