2 Pages V   1 2 >
Winamp 5.3 Released
DJ-Egg
post Sep 27 2006, 12:20
Winamp 5.3
Winamp 5.3 Full
Winamp 5.3 Pro (asks for key during install)
Winamp 5.3 Standard (no media library or vis plugins)
Winamp 5.3 Lite
Full Changelog (108 lines) & More Info
http://forums.winamp.com/showthread.php?threadid=256207
Gabriel
post Sep 27 2006, 13:35
LAME developer
Wow, Lame 3.97 release is included! It seems that you are very fast regarding QA tests...
More seriously, will Winamp include an mp3 encoder configuration box similar to this one day?:
http://lame.sourceforge.net/lame_ui_example.php
It seems way more easier to grasp for newcomers than the preset selection drop-down box.
Fandango
post Sep 27 2006, 14:49
QUOTE (Gabriel @ Sep 27 2006, 14:35) *
On a sidenote: do you know of any stand-alone LAME front-end with that kind of interface? I'm looking for one.
Gabriel
post Sep 27 2006, 15:08
LAME developer
QUOTE (Fandango @ Sep 27 2006, 15:49) *
BeSweet
LameDropXp
Omni Encoder
This post has been edited by Gabriel: Sep 27 2006, 15:16
Maurits
post Sep 27 2006, 15:14
* iTunes-compatible gapless playback (MP3/M4A) and encoding (M4A)
Wow, they must have discovered the meaning of all that Hex mystery iTunes puts in the metadata to pull this one off.
rajas
post Sep 27 2006, 15:59
From the changelog
* New: Replaygain support for MP3, AAC, Vorbis, M4A and WMA
Awesome! Someone finally listened!!!
Edit: Here's a screenshot
This post has been edited by rajas: Sep 27 2006, 16:06
kwanbis
post Sep 27 2006, 16:19
Group: Developer (Donating)
QUOTE (Gabriel @ Sep 27 2006, 12:35) *
MAREO: http://www.webearce.com.ar
amano
post Sep 27 2006, 17:03
for those who do not know: lame b3 was tested in the winamp beta builds. Maybe only the string was updated. cool.gif
Gabriel
post Sep 27 2006, 17:13
LAME developer
QUOTE (kwanbis @ Sep 27 2006, 17:19) *
Good point
DrO
post Sep 27 2006, 18:28
seeing as the understanding was that 3.97final is just a recompiled 3.97b3 it was felt more sensible to ship a version not marked as 'beta' (i remember the talks about 3.97b2 when that became the recommended HA version to use and we had a nice talk over n00bs confusion of a beta being the recommended version against an earlier full release wink.gif ). also i believe that the mp3 encoder just pulls the lame version from lame (putting 3.97b3 would then reflect that appropriately)
as for the changing over to the 'recommended' layout, i can't really comment on that though i know it has been mentioned but it's a matter of if it's decided on to be done or just getting the time to do it (as with anything heh)
-daz
enry2k
post Sep 27 2006, 22:53
I report a bug: Mp3 files wrapped in a wav file with Riff header seem not to be playable in Winamp 5.3. Even file info is not available. mad.gif
Regards
Enrico
This post has been edited by enry2k: Sep 27 2006, 22:58
DrO
post Sep 27 2006, 22:58
have a look at this which explains how to get support for such files again...
-daz
rudefyet
post Sep 28 2006, 00:22
how do I control replaygain support for MP3/AAC?
I see no way to select track or album gain
This post has been edited by rudefyet: Sep 28 2006, 00:23
ilikedirtthe2nd
post Sep 28 2006, 00:28
QUOTE (rudefyet @ Sep 27 2006, 23:22) *
There is a global control for all input plugins supporting it in preferces > general > playback
Analog
post Sep 28 2006, 01:56
Post #15
There is a small bug in FLAC decoder v1.1.2b included in Winamp Essentials: option 'show average bitrate while playing' gives oposite results.
bidz
post Sep 28 2006, 02:46
Post #16
Adding LAME 3.97 - good.
Not updating the presets for ages - not good.
Alt-presets has been outdated for a while, no? It uses the old vbr engine which is not recommended?
The -Vx presets should be added.
Otherwise a very nice release!
myspace.com/borgei - last.fm/user/borgei
QHOBBES 2.0
post Sep 28 2006, 09:44
Post #17
DrO, you should have pointed out that * means that it is fixed in latest internal builds and should be in the next release, 5.31. Also whenever I update Winamp my default vis. always goes back to AVS. But besides that it's good to see that Winamp will be adding native FLAC support, hopefully FLAC encoder too for ripping (just to spread the FLACness, we all know sonic engine is no EAC)
"We will restore chaos"-Bush on Iraq
Junon
post Sep 28 2006, 10:12
Post #18
Does anyone know whether the Winamp team's planning to add APE tagging capabilities to in_mp3.dll sometime in the future? I'm used to tag my MP3 files with both ID3v1 for portable players and APEv2 for PC playback, mainly because of annoying compatibility issues I had with ID3v2.4 in the past. Using Winamp, I'm forced to rely on alternative MP3 input plugins as a workaround for this problem at the moment. Of course, I know I could simply convert the APE tags to ID3v2.3 using MP3tag or foobar2000, but meanwhile I clearly prefer the APE tagging format to ID3v2.
Edit: Typo.
This post has been edited by Junon: Sep 28 2006, 10:17
gaekwad2
post Sep 28 2006, 11:23
Post #19
QUOTE (bidz @ Sep 28 2006, 03:46) *
The -Vx presets can be used by choosing Quality: Normal, Mode: VBR (new or old) and setting VBR Quality to the desired value.
Alt-presets use the same vbr engine btw.
DARcode
post Sep 28 2006, 11:47
Post #20
Group: Members (Donating)
QUOTE (Junon @ Sep 28 2006, 11:12) *
Edit: Typo.
I second that!
http://www.hydrogenaudio.org/forums/index....st&p=416561
http://www.hydrogenaudio.org/forums/index....mp;#entry418790
WavPack 4.75.0 -b384hx6cmv/qaac 2.49 -V 100
Maurits
post Sep 28 2006, 13:00
Post #21
QUOTE (Junon @ Sep 28 2006, 10:12) *
As far as I know there have been numerous fixes regarding ID3v2.4 in Winamp 5.3. They were mentioned in the beta build changelogs although they seem to have vanished in the definitive changelog.
Maybe a Winamp dev can enlighten us?
benski
post Sep 28 2006, 13:24
Post #22
Winamp Developer
QUOTE (Junon @ Sep 28 2006, 05:12) *
It's on my todo list, but I have no timeline as to when it's going to appear.
benski
post Sep 28 2006, 15:55
Post #23
Winamp Developer
For those interested, the LGPL source for the replaygain analysis code is here: http://forums.winamp.com/showthread.php?s=...threadid=256408
Main change from the MP3Gain-sourced code is the ability to run multiple instances simultaneously (via a context pointer)
Gabriel
post Sep 28 2006, 16:10
Post #24
LAME developer
QUOTE (benski @ Sep 28 2006, 16:55) *
I'd suggest you to also apply the fix for denormals:
http://lame.cvs.sourceforge.net/lame/lame/...p;diff_format=l
enry2k
post Sep 28 2006, 17:14
Post #25
QUOTE (DrO @ Sep 27 2006, 13:58) *
-daz
I see, Thank you
Enrico
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 1st September 2015 - 11:48
