57 Pages V  < 1 2 3 4 5 > »
foo_uie_lyrics3, An update of foo_uie_lyrics2
Falstaff
post Aug 20 2011, 23:23
Post #51
happens on mousewheel scroll too ...
http://br3tt.online.fr/
Falstaff
post Aug 21 2011, 09:05
Post #52
hmm, no more glitches this morning, can't reproduce it ... weird, i keep testing, but this morning, it looks perfect smile.gif
EDIT: @#!¨!!! glitches are back (i've just modded background from plain to transparent and ...)
aera in the red rectangle. Glitches appears on track change, mouse move on the top left corner (this area) ...
This post has been edited by Falstaff: Aug 21 2011, 09:21
The vern
post Aug 21 2011, 11:00
Post #53
QUOTE (Falstaff @ Aug 21 2011, 09:05) *
Does it just happen with a transparent background? Any other type of bg? Can you check if it happens with a very simple CUI/DUI layout?
Can anyone else confirm this? I can't reproduce it at all.
Falstaff
post Aug 21 2011, 15:59
Post #54
QUOTE (The vern @ Aug 21 2011, 11:00) *
Sorry, my bad ! the problem was not with your plugin ^^ all is fine now, i've found what's wrong with my config by following your advise and testing on a simple CUI config
The vern
post Aug 21 2011, 16:12
Post #55
QUOTE (Falstaff @ Aug 21 2011, 15:59) *
No worries. Your queries made me solve some flickering on scrolling anyway!
I've made some progress with the crashes I think, I managed to reproduce them, and I think I've solved them (still testing...)
The saving of the lyric offset has also been reinstated.
Will be releasing soon providing all is working!
This post has been edited by The vern: Aug 21 2011, 16:44
The vern
post Aug 21 2011, 17:47
Post #56
Version 0.1.4 uploaded.
Changes:
- Crash fixes on track change.
- Reinstated saving of the timestamp offset.
- Fixed flickering whilst scrolling lyrics in transparent mode.
- Grayed out 'Save' context menu item when save method is 'Don't save'.
To the one person that downloaded 0.1.4 before I posted here - I've made some more changes, so you need to re-download.
This post has been edited by The vern: Aug 21 2011, 18:28
Ran Sagy
post Aug 21 2011, 17:49
Post #57
Thanks for the updates. One suggestion on the archive format - Could you put the files in a components/ directory inside it?
This way foobar2000's component install option works with it.
tpijag
post Aug 21 2011, 17:54
Post #58
Works fine here as is. Foobar2000 1.1.8 b4
Jny
post Aug 21 2011, 20:28
Post #59
finally! thanks
what about new databases? lyricsplugin.com plyrics.com darklyrics.com
Andu
post Aug 21 2011, 21:27
Post #60
QUOTE (godrick @ Aug 20 2011, 02:24) *
This works very well so far - thanks very much!
If I may humbly offer a feature suggestion - I find that available lyrics are continually getting better and better, but I struggle to upgrade saved "bad" rated lyrics to "medium" or better. Any way to automatically search for lyrics and download and overwite existing lyrics in cases where something with a higher rating is found? thanks
I second this request.
Also thanks a lot for taking up this project and doing a fine job so far. smile.gif
tpijag
post Aug 21 2011, 22:01
Post #61
Edge case bug.
I've a number of track titles associated with live shows that may carry a slightly different name. For example Saint of Circumstance vs Saint of Circumstance >. The > denoting that it leads into a following track as part of a medley. I save all lyrics to a single user defined folder. Over time, this folder will have lyrics saved twice. One under the simple track name and one under trackname_.txt. The _ being windows automatic change of the > character.
This has not caused any issue with previous versions of lyric show but now there is an issue. Lyrics3 is not picking up that the tracks ending with a > already have a local lyric file and will go to the internet. Regardless of the 'save' setting. If I delete the file name lyric file of the medley track, lyrics3 will save the track lyric_.txt file appropriately. With a subsequent playing of the track, the lyric file with the _ .txt name will again not be found and lyrics3 will go to the net.
EDIT: In working through this I have been able to generate a couple of Foobar2000 crashes. One of the crash reports is below.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C918FEAh
Access violation, operation: write, address: 00000010h
Last win32 error: 6
Call path:
lyric_searcher::SearchProc=>lyric_loader::ReadThread
Code bytes (7C918FEAh):
7C918FAAh: 0B 64 A1 18 00 00 00 0F B6 4D 0B 89 88 84 0F 00
7C918FBAh: 00 38 1D 30 C0 97 7C 0F 85 CC 04 00 00 A0 48 C1
7C918FCAh: 97 7C F6 D8 57 1B C0 F7 D0 25 40 C1 97 7C 8B F8
7C918FDAh: 8B 46 10 3B C3 89 45 FC 0F 84 9E 00 00 00 8B 06
7C918FEAh: FF 40 10 8B 45 FC 83 E0 01 89 45 E8 8B 06 FF 40
7C918FFAh: 14 F6 05 F0 02 FE 7F 01 0F 85 E6 92 02 00 39 5D
7C91900Ah: E8 57 53 0F 85 AC DE 01 00 FF 75 FC E8 99 59 FF
7C91901Ah: FF 3D 02 01 00 00 0F 84 53 93 02 00 3B C3 0F 8C
Stack (05ABFD98h):
05ABFD78h: 00000000 00000000 00000000 00000000
05ABFD88h: 00000000 00000000 00000000 00000000
05ABFD98h: 00000001 01DCEF50 7C901005 05ABFD90
05ABFDA8h: 05ABFF34 01D5F770 FFFFFFFF 05ABFDD8
05ABFDB8h: 01CF96C0 00000001 05ABFE10 00000001
05ABFDC8h: 00000001 00000000 05ABFE00 01CF9D74
05ABFDD8h: 05ABFE00 01CF9DDD 00000000 01DCE758
05ABFDE8h: 01DCE758 01CF9DEA 01D98018 FFFFFFFF
05ABFDF8h: 00000000 D12BBA70 05ABFE18 00000000
05ABFE08h: 000005A8 05ABFE34 7C90104B 00DCF020
05ABFE18h: 01D044E1 01DCF020 00000001 01DCEF50
05ABFE28h: 01D9802C 01DCF020 01D9C280 05ABFF40
05ABFE38h: 01D04C21 01DCEF50 3F088801 D12BBB30
05ABFE48h: 003D0000 01DCF7D8 06140710 00000001
05ABFE58h: 0000001A 01D9C280 FFC00000 3F088801
05ABFE68h: 00000001 000000BC 01000001 F1B55B6C
05ABFE78h: 85BBF100 8054AB38 05ABFE90 00000000
05ABFE88h: 7C9105C8 06140708 05ABFF5C 7C910551
05ABFE98h: 01DC1348 7C91056D 01D9AAE8 06140710
05ABFEA8h: 06140710 00000000 F1B55BAC 804E46B5
Registers:
EAX: 00000000, EBX: 00000000, ECX: 000005A8, EDX: 01DCF030
ESI: 01DCF020, EDI: 00000000, EBP: 05ABFE0C, ESP: 05ABFD98
Crash location:
Module: ntdll
Offset: 18FEAh
Symbol: "RtlpWaitForCriticalSection" (+5Bh)
Loaded modules:
foobar2000 loaded at 00400000h - 005F3000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F5000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F02000h
Secur32 loaded at 77FE0000h - 77FF1000h
GDI32 loaded at 77F10000h - 77F57000h
USER32 loaded at 7E410000h - 7E4A0000h
SHLWAPI loaded at 77F60000h - 77FD6000h
DSOUND loaded at 73F10000h - 73F6C000h
ole32 loaded at 774E0000h - 7761D000h
WINMM loaded at 76B40000h - 76B6D000h
VERSION loaded at 77C00000h - 77C08000h
UxTheme loaded at 5AD70000h - 5ADA8000h
dbghelp loaded at 59A60000h - 59B01000h
SHELL32 loaded at 7C9C0000h - 7D1D5000h
zlib1 loaded at 5A4C0000h - 5A4D4000h
shared loaded at 10000000h - 1002B000h
imagehlp loaded at 76C90000h - 76CB8000h
COMDLG32 loaded at 763B0000h - 763F9000h
CRYPT32 loaded at 77A80000h - 77B14000h
MSASN1 loaded at 77B20000h - 77B32000h
gdiplus loaded at 4EC50000h - 4EDF3000h
MSCTF loaded at 74720000h - 7476B000h
WINTRUST loaded at 76C30000h - 76C5E000h
wdmaud loaded at 72D20000h - 72D29000h
msacm32 loaded at 72D10000h - 72D18000h
MSACM32 loaded at 77BE0000h - 77BF5000h
midimap loaded at 77BD0000h - 77BD7000h
mslbui loaded at 605D0000h - 605D9000h
OLEAUT32 loaded at 77120000h - 771AB000h
foo_skip loaded at 00FB0000h - 00FDD000h
foo_autoupdate loaded at 00FF0000h - 01030000h
POWRPROF loaded at 74AD0000h - 74AD8000h
foo_dsp_delta loaded at 01040000h - 0105F000h
foo_fileops loaded at 01080000h - 010C7000h
foo_run loaded at 010F0000h - 0114F000h
foo_dynfil loaded at 01170000h - 01197000h
foo_input_std loaded at 012C0000h - 01429000h
foo_facets loaded at 01450000h - 01605000h
MSIMG32 loaded at 76380000h - 76385000h
foo_playlist_manager loaded at 01630000h - 01674000h
foo_queuecontents loaded at 016A0000h - 0170D000h
foo_whatsnew loaded at 01730000h - 01770000h
foo_dbsearch loaded at 01790000h - 01800000h
foo_scheduler loaded at 01820000h - 018FC000h
foo_rgscan loaded at 01920000h - 0196B000h
foo_uie_tagger_mod loaded at 01990000h - 019DE000h
foo_cdda loaded at 01A00000h - 01A4E000h
foo_utils loaded at 01A70000h - 01AB4000h
foo_random_pools loaded at 01AE0000h - 01B0F000h
foo_preview loaded at 01B30000h - 01B52000h
foo_quicksearch loaded at 01B70000h - 01BC7000h
WindowsCodecs loaded at 53000000h - 530B4000h
foo_dsp_xgeq loaded at 01BF0000h - 01C1D000h
foo_verifier loaded at 01C40000h - 01C83000h
foo_uie_lyrics3 loaded at 01CB0000h - 01DB0000h
WININET loaded at 771B0000h - 77256000h
foo_simplaylist loaded at 01E80000h - 01FCC000h
foo_playcount loaded at 01DF0000h - 01E2E000h
foo_albumlist loaded at 01FD0000h - 0202D000h
foo_texttools loaded at 02030000h - 02064000h
foo_osd loaded at 02090000h - 020C1000h
foo_simplaylist_manager loaded at 020F0000h - 021C8000h
foo_jesus loaded at 021F0000h - 0220A000h
foo_dsp_std loaded at 02220000h - 02268000h
foo_abx loaded at 02290000h - 022C2000h
foo_converter loaded at 022F0000h - 0236B000h
foo_playlists_sort loaded at 02390000h - 023A0000h
MSVCR90 loaded at 78520000h - 785C3000h
foo_masstag loaded at 023C0000h - 02414000h
foo_playlist_attributes loaded at 02440000h - 02494000h
foo_ui_columns loaded at 024C0000h - 02650000h
urlmon loaded at 7E1E0000h - 7E280000h
USP10 loaded at 74D90000h - 74DFB000h
foo_ui_std loaded at 02720000h - 02839000h
foo_textdisplay loaded at 026B0000h - 026FB000h
CLBCATQ loaded at 76FD0000h - 7704F000h
COMRes loaded at 77050000h - 77115000h
browseui loaded at 75F80000h - 7607D000h
xpsp2res loaded at 20000000h - 202C5000h
KsUser loaded at 73EE0000h - 73EE4000h
wsock32 loaded at 71AD0000h - 71AD9000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
RASAPI32 loaded at 76EE0000h - 76F1C000h
rasman loaded at 76E90000h - 76EA2000h
NETAPI32 loaded at 5B860000h - 5B8B4000h
TAPI32 loaded at 76EB0000h - 76EDF000h
rtutils loaded at 76E80000h - 76E8E000h
sensapi loaded at 722B0000h - 722B5000h
USERENV loaded at 769C0000h - 76A73000h
mswsock loaded at 71A50000h - 71A8F000h
hnetcfg loaded at 662B0000h - 66308000h
wship6 loaded at 58D40000h - 58D47000h
DNSAPI loaded at 76F20000h - 76F47000h
iphlpapi loaded at 76D60000h - 76D79000h
winrnr loaded at 76FB0000h - 76FB8000h
WLDAP32 loaded at 76F60000h - 76F8C000h
wshtcpip loaded at 71A90000h - 71A98000h
rasadhlp loaded at 76FC0000h - 76FC6000h
Stack dump analysis:
Address: 7C901005h (ntdll+1005h), symbol: "RtlEnterCriticalSection" (+0h)
Address: 01D5F770h (foo_uie_lyrics3+AF770h)
Address: 01CF96C0h (foo_uie_lyrics3+496C0h)
Address: 01CF9D74h (foo_uie_lyrics3+49D74h)
Address: 01CF9DDDh (foo_uie_lyrics3+49DDDh)
Address: 01CF9DEAh (foo_uie_lyrics3+49DEAh)
Address: 01D98018h (foo_uie_lyrics3+E8018h)
Address: 7C90104Bh (ntdll+104Bh), symbol: "RtlEnterCriticalSection" (+46h)
Address: 01D044E1h (foo_uie_lyrics3+544E1h)
Address: 01D9802Ch (foo_uie_lyrics3+E802Ch)
Address: 01D9C280h (foo_uie_lyrics3+EC280h)
Address: 01D04C21h (foo_uie_lyrics3+54C21h)
Address: 01000001h (foo_autoupdate+10001h)
Address: 7C9105C8h (ntdll+105C8h), symbol: "RtlFreeHeap" (+18Bh)
Address: 7C910551h (ntdll+10551h), symbol: "RtlFreeHeap" (+114h)
Address: 7C91056Dh (ntdll+1056Dh), symbol: "RtlFreeHeap" (+130h)
Address: 01D9AAE8h (foo_uie_lyrics3+EAAE8h)
Address: 100027D8h (shared+27D8h), symbol: "uPrintCrashInfo_OnEvent" (+B1h)
Address: 01D71750h (foo_uie_lyrics3+C1750h)
Address: 01D60DDCh (foo_uie_lyrics3+B0DDCh)
Address: 01D04CE6h (foo_uie_lyrics3+54CE6h)
Address: 01D60E19h (foo_uie_lyrics3+B0E19h)
Address: 01D36362h (foo_uie_lyrics3+86362h)
Address: 01D3E7B0h (foo_uie_lyrics3+8E7B0h)
Address: 01D363ECh (foo_uie_lyrics3+863ECh)
Address: 7C80B683h (kernel32+B683h), symbol: "GetModuleFileNameA" (+1B4h)
Address: 7C839AA8h (kernel32+39AA8h), symbol: "ValidateLocale" (+2B0h)
Address: 7C80B690h (kernel32+B690h), symbol: "GetModuleFileNameA" (+1C1h)
Address: 01D36388h (foo_uie_lyrics3+86388h)
Environment:
App: foobar2000 v1.1.8 beta 4
OS: Windows 5.1.2600 Service Pack 2 x86
CPU: Intel« Celeron« CPU 2.50GHz, features: MMX SSE SSE2
Audio: Realtek AC97 Audio
UI: Default User Interface 0.9.5
Components:
Core (2011-08-07 07:01:02 UTC)
foobar2000 core 1.1.8 beta 4
foo_abx.dll (2009-06-07 12:25:26 UTC)
ABX Comparator 1.3.4
foo_albumlist.dll (2011-08-07 06:59:30 UTC)
Album List 4.5
foo_autoupdate.dll (2010-09-23 09:03:58 UTC)
Automatic Updater 2 beta
foo_cdda.dll (2011-08-07 06:59:24 UTC)
CD Audio Decoder 3.0
foo_converter.dll (2011-08-07 06:59:08 UTC)
Converter 1.5
foo_dbsearch.dll (2007-01-26 03:58:48 UTC)
Database Search 1.4
foo_dsp_delta.dll (2008-10-24 20:57:16 UTC)
Noise Sharpening DSP 1.0.0
foo_dsp_std.dll (2011-08-07 06:59:34 UTC)
Standard DSP Array 1.0
foo_dsp_xgeq.dll (2011-05-07 23:10:35 UTC)
Graphic Equalizer 0.1.0
foo_dynfil.dll (2011-02-20 23:34:15 UTC)
Dynamic Fields 1 beta 4
foo_facets.dll (2011-08-18 18:56:32 UTC)
Facets 1.0
foo_fileops.dll (2011-08-07 06:58:34 UTC)
File Operations 2.1.3
foo_input_std.dll (2011-08-07 06:59:14 UTC)
Standard Input Array 1.0
foo_jesus.dll (2010-09-23 09:53:56 UTC)
Autosave & Autobackup 10
foo_masstag.dll (2009-09-18 15:01:36 UTC)
Masstagger 1.8.4
foo_osd.dll (2010-11-26 16:23:54 UTC)
On-Screen Display GDI+ 1.68
foo_playcount.dll (2011-07-13 21:03:45 UTC)
Playback Statistics 3.0.2
foo_playlist_attributes.dll (2010-05-23 19:22:21 UTC)
Playlist Attributes 0.3.0
foo_playlist_manager.dll (2011-05-23 13:28:55 UTC)
Playlist Manager 1.0.2
foo_playlists_sort.dll (2009-06-13 21:57:33 UTC)
Playlist Sorter 0.1.9
foo_preview.dll (2011-07-14 16:25:57 UTC)
Preview 1.4
foo_queuecontents.dll (2011-08-10 12:28:15 UTC)
Queue Contents Editor 0.4.4
foo_quicksearch.dll (2011-05-29 16:35:49 UTC)
Quick Search Toolbar 3.2
foo_random_pools.dll (2011-03-28 19:56:44 UTC)
Random Pools 0.0.2.3
foo_rgscan.dll (2011-08-07 06:59:14 UTC)
ReplayGain Scanner 2.1.2
foo_run.dll (2009-06-07 21:15:18 UTC)
Run services 0.3.7
foo_scheduler.dll (2011-08-21 20:16:35 UTC)
Scheduler 4.07
foo_simplaylist.dll (2011-08-18 18:56:32 UTC)
SimPlaylist 1.0
foo_simplaylist_manager.dll (2011-08-18 18:56:32 UTC)
SimPlaylist Manager 1.0
foo_skip.dll (2011-07-04 20:13:53 UTC)
Skip Track 1.7.4
foo_textdisplay.dll (2011-05-29 16:35:39 UTC)
Text Display UI Element 1.1 beta 1
foo_texttools.dll (2011-03-30 02:55:47 UTC)
Text Tools 1.0.5
foo_ui_columns.dll (2011-04-26 21:39:17 UTC)
Columns UI 0.3.8.8
foo_ui_std.dll (2011-08-07 06:59:36 UTC)
foo_uie_lyrics3.dll (2011-08-21 20:46:34 UTC)
Lyric Show Panel 3 0.1.2
foo_uie_tagger_mod.dll (2010-11-19 21:33:08 UTC)
Tagger Panel 1.2.4
foo_utils.dll (2008-02-09 04:26:58 UTC)
Playlist Tools 0.6.2 beta 6
foo_verifier.dll (2009-10-05 17:39:20 UTC)
File Integrity Verifier 1.1
foo_whatsnew.dll (2008-08-30 20:45:00 UTC)
Feature Watcher 1.0.6
Recent events:
"*X Played" : 0:00.505493
"*XD XRate" : 0:00.274692
"Recent" : 0:00.698217
Startup time : 0:10.193112
Opening track for playback: "T:\@Music\Dead\1982-04-06 The Spectrum\203-Saint Of Circumstance-.mp3"
[foo_dynfil] Calculation took 26.01835 s
Opening track for playback: "T:\@Music\Dead\1982-04-06 The Spectrum\304-Sugar Magnolia.mp3"
Opening track for playback: "T:\@Music\Dead\1982-04-06 The Spectrum\202-Lost Sailor-.mp3"
This post has been edited by tpijag: Aug 21 2011, 22:07
hejiamei
post Aug 21 2011, 22:37
Post #62
QUOTE (The vern @ Aug 21 2011, 18:47) *
Changes:
I am very happy of your work.
I have a suggestion, why won't you add " drag lrc to control playing progress" capability
http://cid-7c6fa1eb8fb8f2b7.skydrive.live....bd%e5%90%8d.png
another saying : "Drag lyric of a song controlling the playing progress of a song"
if you know chinese,I will say "拖动歌词控制播放进度"
kode54
post Aug 21 2011, 23:25
Post #63
Group: Admin
QUOTE (Ran Sagy @ Aug 21 2011, 09:49) *
That is not necessary for the component install system to work. The only issue that may come up, as another developer discovered, is that some ZIP software may unnecessarily create ZIP64 files, which foobar2000 does not support. I don't think there are any such problems here, though.
free30
post Aug 22 2011, 06:15
Post #64
I just wanted to login a say "thank you".
Everybody needs somebody as useful as you! (lickass)
Hawk
post Aug 22 2011, 10:00
Post #65
QUOTE (Jny @ Aug 21 2011, 21:28) *
finally! thanks
I second this request. When you listen to metal 'darklyrics.com' is a must.
Peti
post Aug 22 2011, 14:20
Post #66
Hello,
thanks for great component. But I'm missing one thing from the v2. I'm saving my lyrics as %filename%, and there is no field for custom lyric name in the local file search, only directory.
Dexter_prog
post Aug 22 2011, 15:54
Post #67
I can't believe I missed this. Finally someone trying to make a decent lyrics plugin. I am gonna try it now.
Edit: good! it doesn't produced cpu spikes like lyrics show 2.
QUOTE (YoPen @ Aug 22 2011, 12:01) *
QUOTE (Hawk @ Aug 22 2011, 03:00) *
finally! thanks
+1
Thanks !
+1
+ wikilyrics smile.gif I've added some lyrics to wikilyrics that are not in darklyrics (e.g.: In Vain's songs that are in Norwegian)
This post has been edited by Dexter_prog: Aug 22 2011, 16:03
YoPen
post Aug 22 2011, 16:01
Post #68
finally! thanks
+1
Thanks !
tpijag
post Aug 22 2011, 16:17
Post #69
Yes, everyone is real excited. Can we stop the bumping the thread with nothing other than zero content +1 posts?
What is the point of a +1 post quoting a quote of a +1 post.
This post has been edited by tpijag: Aug 22 2011, 16:19
Dexter_prog
post Aug 22 2011, 16:25
Post #70
QUOTE (tpijag @ Aug 22 2011, 12:17) *
11.
holyrevenger
post Aug 23 2011, 06:28
Post #71
QUOTE (Peti @ Aug 22 2011, 21:20) *
Hello,
Did you try fill title field with %filename% only but leave artist field blank?
Peti
post Aug 23 2011, 06:52
Post #72
QUOTE (holyrevenger @ Aug 23 2011, 07:28) *
Hello,
Didn't work, and I also don't want to break the online search.
gxavz1
post Aug 23 2011, 21:53
Post #73
スラッシュ
post Aug 24 2011, 07:42
Post #74
Thanks for picking this up! So far it seems like it's stable, very nice!
I have a couple of requests...
- When switching codepage, it doesn't seem to remember this. So the next time you load the song, the text is garbled and you have to select the codepage again.
- Currently my work around for this is to choose the codepage, copy the lyrics with timestamp, and open the lyrics in an external editor and paste->save. If saving the codepage is impossible, that process could be automated, at least.
- If I have multiple copies of lyrics files, I can't seem to choose a preferred one. For example if I have one in native language and one translated. It seems to default to whichever was saved first? Also, relatedly, it'd be nice if I could save multiple instances of lyrics... Maybe in the search dialog you should be allowed to give a custom filename?
- A "reload lyrics" button would be useful in case of editing. It seems like Next Lyric does the job too, but it's not that clear and you have to go through the alternatives (if any).
Anyway, those are all minor points, not very important at all. Biggest point is that this is working and seems crash free! Thanks again!
Shemuel
post Aug 24 2011, 10:58
Post #75
Cheers Vern! This is an aspect of foobar that has been conspicuous in its non-usability until now. Certainly will better my current stopgap of lyrics_grabber2 with item_details!
4 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
RSS Lo-Fi Version Time is now: 1st October 2014 - 22:07
