Wrong cover art
tweeg
post Jan 10 2013, 18:32
I have some albums with not only the cover but also the inlay etc.
The search patters are like this:
*front.*
*front.*
*cover.*
$replace(%path%,%filename_ext%,)*.*
But now on some albums, it displays the inlay instead of the cover (i think because of the $replace(%path%,%filename_ext%,)*.*) . I use that pattern so if there is only 1 image in the folder (usually the cover) it will use that one. But in the above situation it doesnt work the way i want.
is there some way to avoid this? Or to like prioritize patterns?
marc2003
post Jan 11 2013, 10:22
that is done in the order they appear. assuming you're using the default UI artwork panel, double click it and that will locate the file in windows explorer. that might help you pinpoint your issue.
also, that $replace isn't needed. simply use
This post has been edited by marc2003: Jan 11 2013, 10:23
tweeg
post Jan 11 2013, 13:24
Thanks for the assistance. I replaced the $replace with *.* now.
Still some albums have issues. My Pink Floyd: Dark Side of The Moon has all the art in the same folder as the music. (Front, back, inlay, cover) And still it displays the back instead of the cover. Any ideas why this is happening?
This post has been edited by db1989: Jan 13 2013, 15:19
Reason for edit: deleting unnecessary full quote
marc2003
post Jan 11 2013, 13:31
maybe the art is embedded in the file? right click the file>tagging>manage attached pictures.
or you have some hidden files inside your music folders. check windows explorer options to show hidden and system files.
tweeg
post Jan 11 2013, 13:53
QUOTE (marc2003 @ Jan 11 2013, 13:31) *
There is no art embedded in the file and no hidden files in the folder :/ Thanks for the hint though.
edit: i have found another album where this happens. This album does have a picture embedded in the file (the cover) and multiple files in the folder but still it displays the inside instead of the cover. Weird.
This post has been edited by tweeg: Jan 11 2013, 13:55
vanderzee
post Jan 13 2013, 01:10
even if the file has no embebbed picture, right click the file>tagging>manage attached pictures - REMOVE all attached....
also remember to rename the pictures according to your tags - sometimes the name has misspelling and it get's shown wrong.
and sometimes the name/album/info tagging is wrong and gets foobar to show the incorret picture.
at my foobar i use only :
so it ALWAYS dusplay the main/front cover as album art (and of course the files are named name of albumFRONT.jpg / albumBACK.jpg)
Erich_2
post Jan 13 2013, 12:13
Put these rows in a batch-file, f.e. "show.bat"
@echo off
cd %1
attrib -h -s *.* /s
echo.
echo.
echo.
echo.
pause
Copy the batch-file in the folder and start it. Look at the outcoming window.
This post has been edited by Erich_2: Jan 13 2013, 12:14
junglistric
post Mar 3 2013, 12:53
QUOTE (Erich_2 @ Jan 13 2013, 03:13) *
@echo off
cd %1
attrib -h -s *.* /s
echo.
echo.
echo.
echo.
pause
thank you!
RSS Lo-Fi Version Time is now: 24th July 2014 - 18:00
