IPB
> foobar2000 Tech Support Forum Rules
Please read foobar2000 Tech Support Forum Rules before posting and comply with all the points.
Failure to provide all the information pointed out in the above document in your post is considered wasting other people's time and in extreme cases will lead to your topic getting locked without a reply.
See also: Hydrogenaudio Terms of Service.
app crash switching to 'Preferences:Output'
gpbeta
post Sep 23 2012, 13:27
Post #1
Group: Members
hi, im new here but made use of foobar for over 6 years... & this is my first bug report XD
this issue only occurs if i have chosen a device which doesn't exist any more(when fb was ran in another system) & open the 'Output' page again...
then app crash.
However, fb will show the output page will device not found warring, but i'm not able to choose from the device list because it crash immediately...
to solve this problems, i have to del the Core.cfg int the configuration folder, setting up again all the lost preferences, and fb work again.... but this is really not convienced sad.gif
i'm using fb2k v1.1.13 & this issuse happens to me in the recent versions
i have a x-fi extreme music, using ks/asio/wsapi output, crash both on 2k3 & win7 (both 64bit)
many thanks
Go to the top of the page
+Quote Post
Apesbrain
post Sep 23 2012, 15:48
Post #2
Group: Members
For now, after you've configured your settings the way you want set your output device to a safe setting such as "Null Output", close foobar2000, and make a copy of CORE.CFG so you have it to restore in the future.
+Quote Post
gpbeta
post Sep 24 2012, 03:23
Post #3
Group: Members
QUOTE (Apesbrain @ Sep 23 2012, 15:48) *
thank you for your suggestion, it is really also a good solution :-)
however i still hope this could be fixed in the latest update… because i believe that invalid devices handling was designed but just not work property now.
+Quote Post
Kohlrabi
post Sep 24 2012, 07:36
Post #4
Group: Super Moderator
Did you try the latest version of foobar2000? And did you send in crash reports?
+Quote Post
Peter
post Sep 24 2012, 10:24
Post #5
foobar2000 developer
Group: Admin
Thank you for the bug report.
I presume that "Intel® Xeon® CPU 3060 @ 2.40GHz" machine is yours. Is this your only machine? I see only one relevant crash report logged, from Windows 2003. Can you please autosubmit crash reports from Windows 7 ?
Finally, please update WASAPI & ASIO components to their latest versions, you're using outdated versions that are known to be prone to system-specific crashes.
+Quote Post
gpbeta
post Sep 24 2012, 11:38
Post #6
Group: Members
QUOTE (Peter @ Sep 24 2012, 10:24) *
thank you for your replay & suggestion very very much!
i guess that was exactly my machine too XD
after updating asio & wasapi components to the latest vers(&i don't know there were updates for these components until you tell me ..lol), fb does not crash any more on win 7...
but still crash on 2k3.
however, i'm not sure whether the updates take effects, because i didn't test it on win7 yesterday but remember it was so on my previous win7 crying.gif
i just updated my hardwares on this computer for few weeks, but my previous device(P4 631, audigy 2 zs etc. but still 2k3 & win7 64bit) had the same problem
+Quote Post
gpbeta
post Sep 24 2012, 11:41
Post #7
Group: Members
QUOTE (Kohlrabi @ Sep 24 2012, 07:36) *
thanks for replay
yes, i've sent an auto report and i will try about the latest version smile.gif
+Quote Post
Peter
post Sep 24 2012, 13:42
Post #8
Group: Admin
I've seen reports of such crash before (preferences page crash after "invalid output device") but it appears to be strictly isolated to Windows 2003; I don't believe my code is the direct cause of this.
Maybe I can specifically code around it so the output device picker doesn't auto drop down on Windows 2003 when opening the dialog, since this is what triggers the crash.
+Quote Post
gpbeta
post Sep 25 2012, 06:20
Post #9
Group: Members
QUOTE (Peter @ Sep 24 2012, 13:42) *
uhh, maybe you're right!
i copy fb to my friend's xp and it does not crash as how fb behaves on win7...
+Quote Post
Peter
post Sep 27 2012, 10:00
Post #10
Group: Admin
For anyone else having this issue: problem has been worked around for the next foobar2000 version: the output device list doesn't auto drop down anymore on Windows 2003 (5.2 build 3790) which seems to remedy it. Any further insight on why exactly that crashes is welcome.
+Quote Post
gpbeta
post Oct 2 2012, 08:18
Post #11
Group: Members
QUOTE (Peter @ Sep 27 2012, 11:00) *
cheer laugh.gif & i wonder why XD
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 1st August 2015 - 11:18
