IPB
Run foobar2k as service
emueyes
post Nov 3 2012, 04:35
Post #1
Group: Members
Let me prefix this by saying that I have searched, looked, read on the topic, to no avail. I'm trying to post questions as a call to the Emergency Dept, not as a walk up Dr to answer my niggling questions. So..
I need to run foobar2k as a service, it seems.
All of my music is on the loungeroom system, which has a good soundcard and amp. The trouble occurs if I use RDP to connect to it for maintenance etc from my other computer; closing the RDP connection leaves me logged into the HTPC, but sitting at the login screen, and fb2k isn't available.
Any solution here would be good, I've tried VNC without much luck, no matter what I do it's slow.
Go to the top of the page
+Quote Post
Andreasvb
post Nov 3 2012, 09:40
Post #2
Group: Members
You could try make it run as a service with http://serviceex.com/
But it won't help to interface with it from the login screen, just to start if it's closed.
I'm using another program and a bat-file to start it.
Sounds like you want it to take commands from wherever you are, then it's not a service you need per se, just something that can tell it to play.
Telnet: foo_controlserver
HTTP: foo_httpcontrol
UPnP: foo_upnp
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.7
+Quote Post
emueyes
post Nov 6 2012, 15:11
Post #3
Group: Members
QUOTE (Andreasvb @ Nov 3 2012, 09:40) *
Yep. The machine is attached to the TV, which is workable as a monitor but not very comfortable. I use an Android tablet and foobarControl or UpnPlay or BubbleUPnP to control fb2k and that then is the interface to the music collection. Neither see foobar unless the machine is logged in. They use either the http or dlna interfaces.
Using Asset on the same machine works, even when not logged in, but I'd rather not have another layer to have to go wrong. Pity Windows is so restrictive in what will run under these circumstances.
+Quote Post
Andreasvb
post Nov 6 2012, 16:51
Post #4
Group: Members
I don't think foobar2000 can run as a background service as it's a program with a window.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 1st February 2015 - 16:26
