16 Pages V  « < 14 15 16
Closed TopicStart new topic
lossyWAV 1.3.0 Development Thread, Added noise WAV bitdepth reduction method.
Nick.C
post Jun 20 2011, 19:35
Post #376
lossyWAV Developer
Thanks very much for that - I am now happy that the adaptive shaping in beta 1.2.3p RC11 is "final" and the rest of the code just needs final polishing before the release of 1.3.0.
Further to RastaMan's comment regarding fixed noise shaping:
1) I have implemented the method by which a 64 tap FIR filter can be used to perform fixed noise shaping using the same bits-to-remove code as for adaptive noise shaping (but obviously with a constant rather than variable filter);
2) I am working on how much of this shaping to apply for each of the quality presets (v1.2.0 used shaping_factor=q/10 for q=0 to 10; shaping_factor was zero for negative quality values on the altpreset scale).
[edit] It is worth noting that the use of an FIR filter for fixed noise shaping (although slow) allows the desired gain curve to be used to create a filter for the same sample-rate as the audio. The old fixed noise shaping only had coefficients for 44.1kHz and 48kHz - it did not work properly for any other sample-rates. [/edit]
This post has been edited by Nick.C: Jun 21 2011, 07:47
lossyWAV -q X -a 4 --feedback 4| FLAC -8 ~= 320kbps
Native_Soulja
post Jun 22 2011, 21:59
Post #377
What settings is everyone using for LossyFLAC? I want to use some non default settings and was wondering what other possible settings are there?
This post has been edited by Native_Soulja: Jun 22 2011, 21:59
Nick.C
post Jun 22 2011, 22:21
Post #378
lossyWAV Developer
Why do you want to use some non-default settings?
There are seven presets and 15001 possible steps on the quality scale....
Use "lossyWAV -L" to display long help.
GeSomeone
post Jun 28 2011, 14:11
Post #379
QUOTE (Native_Soulja @ Jun 22 2011, 22:59) *
I usually choose -q 0 to -q 1 with --limit 15159 added. But that's just a personal preference with no big science behind it and those values seem to match the --altpreset 3 I used with 1.2.0 .
In short, instead of the default (-q 2.5), your best bet is to use the -q (--quality) scale to find bitrates your happy with and check that you don't hear a difference (might depend on what you use the result files for).
Nick.C
post Jul 23 2011, 15:43
Post #380
lossyWAV Developer
Well - nearly 6 weeks since the release of beta 1.2.3p RC11 and no bug reports....
I'll get on with tidying up the code in preparation for release!
Nick.C
post Aug 6 2011, 21:50
Post #381
lossyWAV Developer
lossyWAV 1.3.0 attached to post #1 in this thread.
lvqcl
post Aug 6 2011, 22:29
Post #382
Thanks for the development. BTW, I noticed that both lossyWAV_1.3.0.zip and lossyWAV_Source_20110806_1.3.0.zip contain LossyWAV.exe, and they are different...
(and, if someone doesn't know: FFTW 3.3 was released 2 weeks ago)
Nick.C
post Aug 6 2011, 22:40
Post #383
lossyWAV Developer
Executable replaced in lossyWAV_1.3.0.zip.
Last time I looked, FFTW 3.3 was still in beta - my omission for not checking again. lossyWAV is compatible with FFTW 3.3.
GeSomeone
post Aug 7 2011, 17:32
Post #384
Congrats Nick, for reaching another milestone.
I guess thread should be closed after a while to avoid confusion, bug reports (if any) and test results can be new posts in this forum.
greynol
post Aug 7 2011, 20:01
Post #385
To satisfy the request of the developer, this discussion will now close in order to "encourage discussion regarding the release of 1.3.0 to take place in different threads."
Your eyes cannot hear.
RSS Lo-Fi Version Time is now: 28th November 2014 - 00:29
