2 Pages V   1 2 >
perfect sound
dr_undecided
post Sep 24 2012, 00:33
Will I get PERFECT sound quality with the following setup?
Lossless music on laptop - connect via HDMI to a perfect receiver which in turn connects to perfect speakers.
What can go wrong?
Satellite_6
post Sep 24 2012, 00:42
Nothing is perfect. Especially the speakers or headphones.
FLAC -> JDS Labs ODAC/O2 -> Sennheiser HD 650
dr_undecided
post Sep 24 2012, 00:51
Or let's assume they are for the sake of the argument. Besides the speakers and the receiver, is there anything in this setup which would prevent me from getting perfect music?
saratoga
post Sep 24 2012, 00:56
QUOTE (dr_undecided @ Sep 23 2012, 19:51) *
Nope. But like pretty much every situation, it'll be the speakers that determine what your hear.
mzil
post Sep 24 2012, 02:07
You also need perfect microphones, perfectly placed, a perfect hall, a perfectly engineered recording, perfect hearing, and those perfect speakers' placement must be perfect (within your room with perfect acoustics).
slks
post Sep 24 2012, 03:35
"Perfect" in this context is really only applicable as long as the signal remains digital. With digital data, it's possible for it to be "bit-perfect", that is, identical. But the signal must be converted to analog at some point to drive the speakers.
Once the signal is analog, there's no such thing as "perfect". At this point we begin talking about "transparent", which means that no audible distortion is introduced into the signal. But once it goes analog, the concept of "perfection" goes out the window; there will always be distortion at some level.
Keeping the signal digital until it gets to the amplifier (by using HDMI or another digital interconnect) is good practice to minimize the places in the signal chain where distortion could creep in.
The #1 determining factor in sound quality is, of course, the speakers. They are what actually converts the electrical signal into sound waves. If you have poor speakers, nothing else in the signal chain matters.
http://last.fm/user/sls
Woodinville
post Sep 24 2012, 06:36
You can't do perfect sound with 2 channels. Next, please?
J. D. (jj) Johnston
dr_undecided
post Sep 24 2012, 07:00
Woodinville, why 2 channels? I think my proposed setup can support up to 8 channels. Please correct me if I'm wrong.
tnargs
post Sep 24 2012, 07:06
This thread is bizarre.
"If I buy a perfect car, will it be perfect?"
Are you actually asking "If I use front end 'X', will its output produce audible inaccuracies?"
EagleScout1998
post Sep 24 2012, 07:14
Things are only "perfect" until the next best thing comes along.
Roseval
post Sep 24 2012, 09:09
HDMI can be pretty high on jitter: http://www.thewelltemperedcomputer.com/HW/...DMI_connect.htm
TheWellTemperedComputer.com
Brand
post Sep 24 2012, 10:16
Room acoustics is an often overlooked factor, but it's probably something that you should spend the most time on, if you're after the "perfect" sound.
All your "perfect" equipment is wasted if you don't take care of that.
dhromed
post Sep 24 2012, 12:53
QUOTE (Brand @ Sep 24 2012, 11:16) *
Yes. Which is weird, since its influence is so immediate and obvious. I guess it's a bikeshedding problem.
Bartholomew MacG...
post Sep 24 2012, 15:02
QUOTE (tnargs @ Sep 24 2012, 08:06) *
That what it sounds like he's asking. I'm still confused as to whether or not sound cards introduce some sorts of inaccuracies and if they differ much.
Arnold B. Kruege...
post Sep 24 2012, 15:26
Post #15
The recording is imperfect. It was made in an imperfect way with imperfect equipment. The mics are the worst part of that end of it.
DVDdoug
post Sep 24 2012, 18:17
Post #16
If you have an 8-channel recording, you should use 8 speakers. wink.gif When you start adding channels (soundfield effects, etc.) to a two-channel recording you are altering the sound, perhaps in a pleasing way, but that makes it "less-perfect", since the sound reporduction does NOT accurately represent the original recording.
They can. Digital-to-analog converts have an (imperfect) analog output. wink.gif However, if you don't hear noise (or some other defect) the soundcard is probably better than human hearing and a "better" soundcard won't improve the sound. With a digital connecton (i.e. HDMI) the D/A converter is in the receiver, so the soundcard doesn't come into the picture. (As far as I know, no properly functioning digital system has any audible jitter.)
greynol
post Sep 24 2012, 19:38
Post #17
QUOTE (Roseval @ Sep 24 2012, 01:09) *
Considering that this forum is particularly interested in things that are audible, please explain how this is of any value.
pisymbol
post Sep 24 2012, 20:51
Post #18
QUOTE (greynol @ Sep 24 2012, 14:38) *
From various research papers, I had always thought that jitter (in the digital domain) at certain thresholdsis most certainly audible and a factor to consider when using unreliable clocks.
I think what he is really asking is the following...
Does HDMI as a bus transport offer certain intrinsic advantages over other tranports such as USB, SDPIF etc. etc.?
greynol
post Sep 24 2012, 20:58
Post #19
Care to cite any studies showing the amount of jitter that needs to present in order to be audible that is also backed with double-blind testing?
Throwing out numbers and saying, "watch out" doesn't exactly make the grade, sorry!
This post has been edited by greynol: Sep 24 2012, 20:59
Batman321
post Sep 25 2012, 00:04
Post #20
And of course you'll need perfect albums made by perfect bands, like the Beatles laugh.gif
greynol
post Sep 25 2012, 00:14
Post #21
eahm
post Sep 25 2012, 00:35
Post #22
QUOTE (greynol @ Sep 24 2012, 16:14) *
I don't think saying this is right either but maybe I didn't get it.
This post has been edited by eahm: Sep 25 2012, 00:36
pisymbol
post Sep 25 2012, 04:00
Post #23
QUOTE (greynol @ Sep 24 2012, 15:58) *
Like you, I will say Google it. There are several on AES's website. I believe it was around >220ps (don't hold me that, its from memory, I may be off).
Clearly there are thresholds of jitter that everyone on this forum could DBT.
I would like to throw in the original posters did not phrase his question perfectly and I am pretty sure the responses thus far aren't perfect either. He is in quite a predicament.
This post has been edited by pisymbol: Sep 25 2012, 04:02
Woodinville
post Sep 25 2012, 04:47
Post #24
QUOTE (dr_undecided @ Sep 23 2012, 23:00) *
Well, that's a matter of dispute. The wavefield synthesis people would say 8 is not enough, probably.
I think one can manage inside of 8, at least for reproducing realistic sensation in the horizontal plane.
But it's not "perfect" it's still a kind of perceptual coding.
J. D. (jj) Johnston
greynol
post Sep 25 2012, 04:50
Post #25
QUOTE (pisymbol @ Sep 24 2012, 20:00) *
don't hold me that, its from memory, I may be off.
How convenient. I'm adamant about this particular point because very little substantiation has been made on this forum about the elusive boogie man that is jitter.
Regarding digging up facts, I do when people ask me after I've made a questionable claim unless I have already done so personally in a previous discussion on this forum, yes. The ball is in your court this time around.
This post has been edited by greynol: Sep 26 2012, 19:09
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 1st August 2015 - 16:12
