> Upload forum rules
jLossyWav, implementation of lossyWav in Java
[JAZ]
post Dec 1 2008, 23:44
This is the initial implementation of the lossyWav algorithm in Java.
It is based on the C# port, and doesn't provide yet most of the parameters ( it only accepts the -q parameter).
To execute it: java -jar jLossyWav.jar -q 5.0 inputFile.wav.
The sources are included inside the .jar file. They can be seen with 7-Zip or be imported directly into Eclipse IDE.
[Current posted version: 0.5.1]
This post has been edited by greynol: Jul 6 2009, 20:54
Reason for edit: Updated current version number
Attached File(s)
jido
post Jan 24 2009, 01:32
I had to recompile because of this error:
Exception in thread "main" java.lang.UnsupportedClassVersionError: Bad version number in .class file
    at java.lang.ClassLoader.defineClass1(Native Method)
    at java.lang.ClassLoader.defineClass(ClassLoader.java:675)
    at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:124)
    at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
    at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
    at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:316)
    at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:280)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
    at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:374)
    at org.lossywav.dsp.InplaceFFT.<clinit>(InplaceFFT.java:48)
    at org.lossywav.algorithm.Analyzer.<init>(Analyzer.java:103)
    at org.lossywav.algorithm.LossyWav.<init>(LossyWav.java:53)
    at org.lossywav.frontend.jLossyWavConsole.main(jLossyWavConsole.java:60)
I had to remove the invalid @Override in ComplexArrayBuffer.java and DoubleArrayBuffer.java for compiling too.
Bugs found: does not accept mono files. Does not work properly with the following file (sample rate 22kHz)-
[JAZ]
post Jan 24 2009, 17:31
QUOTE (jido @ Jan 24 2009, 01:32) *
Which java version are you using? This has been compiled with java 1.6.0r10
@Override is a valid annotation. Requires java 5.
I'll check why mono doesn't work. there shouldn't be a problem. about samplerate of 22Khz, the ported code may not cope with it, but i'll take a look too.
Edit:it
The problems with mono and other sampling rates were pretty trivial. It was all due to fixed values when creating the writer. I've replaced those to use the values from the .wav file.
Uploaded a version with those changed.
This post has been edited by [JAZ]: Jan 24 2009, 18:39
jido
post Jan 24 2009, 21:26
' date='Jan 24 2009, 08:31' post='611054']
Yeah that is the problem, I still have Java 5 (1.5.0_16).
You should not use @Override when the method does not exist in the superclass (here the superclass is Object), should you?
Edit:it
Great, thanks!
[JAZ]
post Feb 7 2009, 19:59
Uploaded a new version which now trully works (when testing another file, i realized that the FFT analisys was using one bit too much, which implied that it was using erroneous information).
It still doesn't produce the same output than lossywav 1.1.1 but it is pretty close now.
monoton
post Mar 18 2009, 23:56
Hey there...
I tried to convert a track with "-q -4" as quality settings as could be done with the original lossyWav 1.1.0e, but it didn't accept the settings.
Thanks tho very much for your effort and hard work to port it to Java! When I get the chance, I'll have a look or two over the source code smile.gif
All the best,
monoton
This post has been edited by monoton: Mar 18 2009, 23:56
[JAZ]
post Mar 19 2009, 20:08
Yes, I know.
My initial implementation just provides a conversion of the algorithm in an informative way, and i left the options a bit on the side.
I plan to upgrade it for 1.2.0, although i don't have a timeline for that set up yet.
The source code is separated in classes and methods that should represent the process itself, and have some javadoc in them trying to describe what everything does.
I hope to improve those comments and source separation further with the new release too, but sure a look from other people could help to find out if i'm on the good path smile.gif
[JAZ]
post Jul 5 2009, 21:59
I've got a freshly new version of jLossyWav ready. I've labeled it 0.5.0 .
This one is a big improvement over the older.
- Uses an intermediate buffer for file IO. This has increased the speed considerably (obviously, slower than LossyWav, but not by a mile now)
- It implements most of the console switches that LossyWav supports (important ones still missing are stdin/out and --merge )
- The algorithm is updated to LossyWav 1.1.4c
- Several things have been changed to conform better with the official one.
This release is bit-perfect with the default settings (and the single file I've tried) compared to the official.
As always, the .jar contains the sources so anyone can look and either help or learn.
Also, you would like to know that Nick and I are in contact about the sources and we will attempt to make both easier to understand and manage (Comparing the Delphi to the Java implementation is not an easy task right now tongue.gif).
Expect more versions to follow due to these changes.
Attached File(s)
Nick.C
post Jul 5 2009, 22:05
lossyWAV Developer
As discussed, I'm working on making my Delphi easier to read and am currently creating more units to split the code up into functional chunks.
Nick.
jido
post Jul 6 2009, 12:45
Error with this version...
Exception in thread "main" java.lang.NoClassDefFoundError: org/lossywav/frontend/jLossyWavConsole
This command works:
java -cp jLossyWav.jar org.lossywav.frontend.JLossyWavConsole
(note that it is a capital J. The normal command may work on Windows though)
After that jLossyWav seems to work fine.
[JAZ]
post Jul 6 2009, 18:41
Ops!
I decided to change the class name, since usually in Java every class starts with a capital letter smile.gif
I've also took the opportunity to fix the -o option. It was failing if the input file already contained a path.
This post has been edited by [JAZ]: Jul 6 2009, 18:59
Attached File(s)
RSS Lo-Fi Version Time is now: 5th March 2015 - 13:37
