CPU hit 100% at the beginning of the track
urdman
post Dec 5 2008, 06:22
foobar hits 100% of CPU load while moving to the next track for 3 to 7 seconds every time. Then it comes down to normal(5~10%).
APE, FLAC, WV, ogg... regardless of file type.
Is it normal?
Please let me know if I can prevent this.
Foobar 0.9.5.5
No DSP
This post has been edited by urdman: Dec 5 2008, 10:36
Yirkha
post Dec 5 2008, 14:20
Group: FB2K Moderator
Post list of all loaded components.
urdman
post Dec 5 2008, 18:49
QUOTE (Yirkha @ Dec 5 2008, 22:20) *
List of the Components:
Core (2008-08-04 07:16:48)
foobar2000 core 0.9.5.5
foo_abx.dll (2008-05-25 00:23:50)
ABX Comparator 1.3.3
foo_albumlist.dll (2008-08-04 07:04:30)
Album List 4.3
foo_bitcompare.dll (2006-08-04 21:56:50)
Binary Comparator 1.1
foo_bubble_coverflow.dll (2008-09-14 16:20:19)
Cover Flow 0.19
foo_burninate.dll (2006-08-04 21:56:44)
Audio CD Writer 2.0.1
foo_cdda.dll (2008-06-26 02:18:24)
CD Audio Decoder 2.1.3
foo_converter.dll (2008-08-04 07:04:34)
Converter 1.1.2
foo_dbsearch.dll (2007-01-25 21:58:48)
Database Search 1.4
foo_dbsearch_api_demo.dll (2007-01-22 13:01:38)
Database Search Toolbar Demo 1.0
foo_discogs.dll (2008-11-08 11:30:06)
Discogs Tagger 1.14
foo_dockable_panels.dll (2007-03-28 09:19:02)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]
foo_dsp_delta.dll (2006-03-21 18:16:22)
LPCM <--> delta-PCM converter 0.1.1
foo_dsp_src9.dll (2006-06-05 20:48:38)
Resampler (Secret Rabbit Code) 1.03
foo_dsp_std.dll (2008-08-04 07:10:54)
Standard DSP Array 1.0
foo_facets.dll (2008-01-07 15:33:13)
Facets 2008-01-04
foo_fileops.dll (2008-06-08 04:14:56)
File Operations 2.1
foo_freedb2.dll (2008-06-08 04:15:10)
freedb Tagger 0.6
foo_history.dll (2006-03-31 11:50:34)
History 0.2
foo_input_alac.dll (2008-06-04 20:29:06)
ALAC Decoder 1.0.1
foo_input_monkey.dll (2008-05-31 22:39:34)
Monkey's Audio Decoder 2.1.3
foo_input_std.dll (2008-08-04 07:04:56)
Standard Input Array 1.0
foo_input_tak.dll (2008-04-08 12:16:06)
TAK Decoder 0.4.2
foo_masstag.dll (2008-11-02 22:01:02)
Masstagger 1.7
foo_navigator.dll (2008-09-07 15:25:23)
Navigator 0.63
foo_out_asio.dll (2008-02-09 14:52:42)
ASIO support 1.2.6
foo_out_ks.dll (2006-08-04 21:54:58)
Kernel Streaming Output 1.2.2
foo_playback_custom.dll (2008-11-13 10:09:14)
Playback Statistics Custom 1.4.3
foo_playcount.dll (2008-10-29 13:26:22)
Playback Statistics 2.1.6
foo_playlist_manager.dll (2007-01-22 13:05:12)
Playlist Manager 1.0.2
foo_playlist_tree.dll (2008-02-18 08:30:36)
Playlist Tree Panel 3.0.5 [Feb 18 2008 - 08:29:56]
foo_pqview.dll (2007-01-22 13:02:24)
foo_quicktag.dll (2007-10-16 17:46:18)
Quick Tagger 1.0
foo_rgscan.dll (2008-06-12 03:30:18)
ReplayGain Scanner 2.0.8
foo_run.dll (2008-01-17 20:32:42)
Run services 0.3.4
foo_texttools.dll (2008-06-19 20:53:52)
Text Tools 1.0.1
foo_ui_columns.dll (2008-09-07 09:31:33)
Columns UI 0.3.4.1
foo_ui_std.dll (2008-08-04 21:09:14)
Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-16 00:22:24)
Album Art Panel 0.2.7.1
foo_uie_albumlist.dll (2006-11-22 21:57:39)
Album list panel 0.2.1
foo_uie_graphical_browser.dll (2008-09-14 16:16:57)
Graphical Browser rev009
foo_uie_queuemanager.dll (2006-12-17 03:21:36)
Queue manager panel 0.2.3
foo_uie_tabs.dll (2006-10-17 22:54:32)
Tabbed panel modified 0.2.5
foo_uie_trackinfo_mod.dll (2007-01-05 13:36:20)
Track info panel mod 0.8.0 beta [Jan 5 2007 - 13:36:12]
foo_uie_vis_channel_spectrum.dll (2008-05-18 03:02:12)
Channel Spectrum panel 0.17.2
foo_unpack.dll (2008-08-04 07:04:20)
RAR reader 1.1
ZIP/GZIP reader 1.0
many of them are not in use.
should I unload them to relieve CPU loads?
Yirkha
post Dec 5 2008, 22:24
Perhaps. Updating to the latest version and trying it only with components you really need would be a good idea.
RSS Lo-Fi Version Time is now: 20th September 2014 - 12:48
