IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
Some layout questions
phantomdasilva
post Nov 8 2013, 07:06
Post #1
Group: Members
When I try to move a window (such as a browser or another program) over Foobar it's always goes behind Foobar program and can't see the window and I can't toggle Foobar to go behind the other program.
I can easily get around it with by minimising Foobar but it doesn't seem like there is a need for to always make Foobar in front of the screen (other programs don't have this issue) as normally I choose a song to play and do something else which makes it a bit of an inconvenience to minimise foobar after let say changing a song played.
Also with playlist. I would normally like to order songs in specific order. However if I accidentally click on let say Artist, Title or # column it will reorganise it in a different order. However I don't know how to reset it back to the original playlist order as there is no column for that and hence have to manually reorder it. For me to get around it I always save playlist anytime I made a change in the playlist order so when I do accidentally click on the columns, I'll just load up the earlier playlist. However is there a way to put a column of playlist order as part of the column. Itunes has it part of the column so whenever that happens there, I can easily reset it back to the original playlist.
Anyway it's a pretty great program otherwise and I basically replace iTunes with this program but those are my two niggling complaints and I hope there is a solution to it.
Go to the top of the page
+Quote Post
dhromed
post Nov 8 2013, 11:56
Post #2
Group: Members
You probably accidentally enabled View > Always On Top (Alt+A).
QUOTE
There is Ctrl+Z to undo, next time this happens.
I believe there's also a component to lock the columns, but someone else may know more about that.
+Quote Post
phantomdasilva
post Nov 8 2013, 12:36
Post #3
Group: Members
Thank
I guess that is problem solve
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 22nd August 2014 - 15:22
