Distortions in AAC file purchased on iTunes
msvadi
post May 21 2012, 03:13
Hi all,
I've noticed a couple of audible distortions in an AAC track I bought on iTunes. I uploaded a small fragment of the track with distortions here: 53 FRAGMENT Sonata in A Minor, D. 821, 'Arpeggione '_ I. Allegro moderato.m4a. I wonder if these are compression artifacts or they were caused by something else?
I appreciate your help with this.
eahm
post May 21 2012, 03:46
"Our service is currently unavailable in your country.
Sorry about that."
This post has been edited by eahm: May 21 2012, 03:46
msvadi
post May 21 2012, 04:19
QUOTE (eahm @ May 20 2012, 19:46) *
Sorry about that."
Sorry about that. I uploaded the same fragment also to Mediafire. I think it should work in the US too:
http://www.mediafire.com/?l8lip63v28y7r1c
eahm
post May 21 2012, 06:52
It seems an audio problem but I am not expert enough of that particular track and I can't for sure say it's not a key vibration sound.
This post has been edited by eahm: May 21 2012, 06:52
Nessuno
post May 21 2012, 08:30
Of course the only way to be sure would be a comparison with the lossless version, but to me it doesn't seem a compression artefact. It seems more an imperfection in the recording, or some kind of "mechanical" noise from the bow strokes, maybe the microphones were placed a little too near.
In my experience, trying to spot artefacts to ABX on AAC @256Kbps has instead leaded me to find a lot of similar imperfections in the original recordings!
... I live by long distance.
msvadi
post May 21 2012, 17:02
I see. Thanks for your replies!
Wombat
post May 21 2012, 19:08
To me it simply sounds like a string loosened on the Cello or whatever the bigger stringed instrument is.
eahm
post May 21 2012, 20:42
The original one has the same sound as well, as I supposed it's just a key vibration sound.
http://dropcanvas.com/pnvin
EAC Log:
Exact Audio Copy V0.99 prebeta 5 from 4. May 2009
EAC extraction logfile from 6. January 2011, 1:50
Andras Schiff, Yuuko Shiokawa, Miklos Perenyi / Andras Schiff - Concertos & Chamber  Music - CD7 - Schubert
Used drive  : HL-DT-STDVDRAM GSA-4083N   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 667
Overread into Lead-In and Lead-Out          : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : No
Used interface                              : Native Win32 interface for Win NT & 2000
Used output format              : User Defined Encoder
Selected bitrate                : 768 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -6 -V -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" -T "GENRE=%m" -T "COMMENT=%e" %s -o %d
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 | 11:19.55 |         0    |    50979
        2  | 11:19.55 |  4:18.52 |     50980    |    70381
        3  | 15:38.32 |  9:15.08 |     70382    |   112014
        4  | 24:53.40 | 15:07.15 |    112015    |   180054
        5  | 40:00.55 |  9:56.65 |    180055    |   224819
        6  | 49:57.45 |  6:40.05 |    224820    |   254824
        7  | 56:37.50 |  9:04.25 |    254825    |   295649
Range status and errors
Selected range
     Filename F:\Music\Schiff - Concertos & Chamber Music\Schiff - Concertos & Chamber  Music - CD7.wav
     Peak level 98.8 %
     Range quality 100.0 %
     Copy CRC CC05314A
     Copy OK
No errors occurred
End of status report
This post has been edited by eahm: May 21 2012, 20:58
msvadi
post May 21 2012, 21:15
QUOTE (eahm @ May 21 2012, 12:42) *
Thank you very much! This is very helpful. I was considering contacting iTunes and asking them to fix the issue. Now I see that it's not their fault.
Kees de Visser
post May 21 2012, 22:47
QUOTE (Wombat @ May 21 2012, 20:08) *
Agreed. It's Miklos Perenyi playing the cello. A great artist.
RSS Lo-Fi Version Time is now: 28th July 2015 - 08:19
