Question on playback queue
buffalo_guy
post Jan 20 2013, 05:16
I am new to Foobar 2000. I see that I can right click and select a number of files to play. Is there a way to have these selected files play ONLY? What is happening is that when the last selected song plays the very next item in the list then plays. Often, rather than create multiple lists, I will select a handful of songs from a master list and just play those. Thanks
romor
post Jan 20 2013, 05:29
I had same problem. Luckily someone made such component: http://www.saunalahti.fi/cse/foobar2000/
After installing, you can set it through menu > playback > stop after queue
scripts: http://goo.gl/M1qVLQ
db1989
post Jan 20 2013, 05:41
QUOTE (buffalo_guy @ Jan 20 2013, 04:16) *
That is the exact purpose of the playback queue: to insert some songs between the flow of the current playlist. It is not designed for building a now-playing list. The feature seems like an afterthought to me, and sometimes I think it might be better if it did not exist due to the confusion it causes. wink.gif
Then maintain a ‘playlist on the go’ in addition to whichever list(s)/categories you already have set up as separate playlists. Send songs from your ‘normal’ playlists to that, and keep it playing.
Sure, there are workarounds, but the best solution is to understand the different behaviours and purposes of playlists vs. the playback queue within foobar2000, without reference to how they might work in other applications such as Winamp. If you are interested, these subjects have been discussed many times before in past threads that should be easy to find on a search.
This post has been edited by db1989: Jan 20 2013, 05:43
buffalo_guy
post Jan 20 2013, 18:51
QUOTE (romor @ Jan 20 2013, 05:29) *
RSS Lo-Fi Version Time is now: 27th May 2015 - 14:58
