127 Pages V  « < 2 3 4 5 6 > »
WSH Panel Mod script discussion/help.
marc2003
post Jan 24 2010, 19:18
Post #76
QUOTE (saivert @ Jan 24 2010, 17:25) *
It is buggy.
#EOF gets printed over the text a lot (it's position on a previous artist isn't updated when switching to a new artist)
it can't save text files with special characters in (see this post on how to fix - http://www.hydrogenaudio.org/forums/index....t&p=682074)
text sometimes disappears completely when scrolling.
text doesn't always update when changing tracks with different artists (random)
sometimes can't scroll back to top
edit: try this one (it doesn't support dragging though, only mouse scrolling)
api_key = "";
DT_CENTER = 0x00000001;
DT_VCENTER = 0x00000004;
DT_WORDBREAK = 0x00000010;
DT_CALCRECT = 0x00000400;
DT_NOPREFIX = 0x00000800;
DT_END_ELLIPSIS = 0x00008000;
ColorTypeCUI = {
text: 0,
selection_text: 1,
inactive_selection_text: 2,
background: 3,
selection_background: 4,
inactive_selection_background: 5,
active_item_frame: 6
FontTypeCUI = {
items: 0,
labels: 1
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
FontTypeDUI = {
defaults: 0,
tabs: 1,
lists: 2,
playlists: 3,
statusbar: 4,
console: 5
function RGB(r,g,b) {
return (0xff000000|(r<<16)|(g<<8)|(b));
function get_font() {
if (g_instancetype == 0) {
g_font = window.GetFontCUI(FontTypeCUI.items);
} else if (g_instancetype == 1) {
g_font = window.GetFontDUI(FontTypeDUI.defaults);
function get_colors() {
g_textcolor = window.GetColorCUI(ColorTypeCUI.text);
g_textcolor_hl = window.GetColorCUI(ColorTypeCUI.text);
g_backcolor = window.GetColorCUI(ColorTypeCUI.background);
g_textcolor = window.GetColorDUI(ColorTypeDUI.text);
g_textcolor_hl = window.GetColorDUI(ColorTypeDUI.highlight);
g_backcolor = window.GetColorDUI(ColorTypeDUI.background);
function on_playlist_switch() {
on_item_focus_change();
function on_colors_changed() {
get_colors();
window.Repaint();
function on_font_changed() {
get_font();
window.Repaint();
function on_item_focus_change() {
if (g_metadb) window.UnwatchMetadb();
g_metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
if (g_metadb) {
try { on_metadb_changed(); } catch(e) {}
window.WatchMetadb(g_metadb);
g_instancetype = window.InstanceType;
get_font();
get_colors();
function lastfm(url, user_agent, func, debug) {
xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
xmlhttp.open("GET", url + "&s=" + Math.random(), true);
xmlhttp.setRequestHeader('User-Agent',user_agent);
xmlhttp.send();
xmlhttp.onreadystatechange = function() {
if (xmlhttp.readyState == 4) {
if (xmlhttp.status == 200) {
if(debug) fb.trace(xmlhttp.responsetext);
func();
} else {
g_metadb = fb.GetFocusItem();
var artist = g_text = '';
folder = fb.ProfilePath + "wsh_lastfm";
fso = new ActiveXObject("Scripting.FileSystemObject");
WshShell = new ActiveXObject("WScript.Shell");
if(!fso.FolderExists(folder)) fso.CreateFolder(folder);
String.prototype.count=function(s1) {
return (this.length - this.replace(new RegExp(s1,"g"), '').length) / s1.length;
function get_bio() {
url = "http://ws.audioscrobbler.com/2.0/?method=artist.getinfo&api_key=" + api_key + "&artist=" + encodeURIComponent(artist);
lastfm(url, "foo_wsh_lastfm_bio", function() {save_file();},0);
function save_file() {
xmlDoc = xmlhttp.responseXML;
try {
g_text = xmlDoc.getElementsByTagName("content")[0].childNodes[0].nodeValue;
g_text = g_text.replace(/<\/?[^>]+(>|$)/g, "");
doc = new ActiveXObject("htmlfile");
doc.open();
div = doc.createElement("div");
div.innerHTML = g_text.replace(/\n/g, "<br>");
g_text = div.innerHTML;
g_text = g_text.replace(/<BR>/g,"\n");
g_text = g_text.replace(/&amp;/g,"&");
} catch(e) {
g_text = "This artist does not have a biography page on Last.fm.";
try {
ts = fso.OpenTextFile(filename, 2, true, -1);
ts.WriteLine(g_text);
ts.close();
} catch(e) {
g_text = "Error saving biography for this artist.";
calc();
function on_size() {
ww = window.Width;
wh = window.Height;
calc();
function on_paint(gr) {
gr.FillSolidRect(0, 0, ww, wh, g_backcolor);
if(g_metadb) {
gr.GdiDrawText(g_text, g_font, g_textcolor, 6, offset + 36, ww-16, wh-offset,DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
gr.FillSolidRect(0, 0, ww, 38, g_backcolor);
gr.GdiDrawText(artist, gdi.Font("Segoe UI", 16, 1), g_textcolor_hl, 6, 5, ww-77, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.DrawLine(5, 29, ww-10, 29, 1, RGB(137,140,149));
if(!g_metadb || artist == fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb)) return;
artist = fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb)
filename = folder + "\\" + fb.TitleFormat("$crc32(%artist%).txt").EvalWithMetadb(g_metadb);
if(fso.fileExists(filename)) {
try {
ts = fso.OpenTextFile(filename,1, false, -1);
g_text = ts.ReadAll();
ts.close();
} catch(e) {
g_text = "Error opening file!";
calc();
} else {
get_bio();
function calc() {
temp_bmp = gdi.CreateImage(1, 1);
temp_gr = temp_bmp.GetGraphics();
arr = temp_gr.GdiDrawText(g_text, g_font, g_textcolor, 0, 0, ww, wh,DT_CENTER| DT_WORDBREAK | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX).toArray();
textheight = arr[3] - arr[1] + (wh/2) + (g_text.count("\n") * 3);
temp_bmp.ReleaseGraphics(temp_gr);
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
function on_mouse_rbtn_up(x, y) {
var MF_SEPARATOR = 0x00000800;
var MF_STRING = 0x00000000;
var _menu = window.CreatePopupMenu();
var idx;
_menu.AppendMenuItem(MF_STRING, 1, "Force update");
_menu.AppendMenuItem(MF_SEPARATOR, 0, 0);
_menu.AppendMenuItem(MF_STRING, 2, "Configure...");
idx = _menu.TrackPopupMenu(x, y);
if(idx == 1) get_bio();
if(idx == 2) window.ShowConfigure();
_menu.Dispose();
return true;
function on_mouse_wheel(delta) {
step = g_font.height * 5;
offset += (delta * step);
if(offset > 0 || textheight < wh) {
offset = 0;
} else {
temp = -textheight + wh;
if(offset < temp) offset = Math.round(temp / step) * step;
window.Repaint();
This post has been edited by marc2003: Jan 24 2010, 19:46
saivert
post Jan 25 2010, 02:11
Post #77
Excellent code marc2003! You have simplified a lot. Good idea getting rid of all the "var" stuff. Really not needed with JS being a loosely typed language.
I didn't want to edit too much on the previous code I borrowed from you. I know it still needed a lot of work.
But why not use the preprocessor features and import flags.txt and handlers.txt. I think a standard install of WSH Panels mod should have a scripts directory in foobar2000 folder with those standard includes. This would slim down the scripts even further and makes things really clean.
// ==PREPROCESSOR==
// @import "%fb2k_path%scripts\flags.txt"
// @import "%fb2k_path%scripts\helpers.txt"
// ==/PREPROCESSOR==
This post has been edited by saivert: Jan 25 2010, 02:12
http://foobar2000.saivert.com - foobar2000 component repository
Hitchhiker427
post Jan 25 2010, 02:24
Post #78
QUOTE (marc2003 @ Jan 24 2010, 12:18) *
Oh, I really like this one. The non-scrolling artist header is a cool idea.
T.P Wang
post Jan 25 2010, 03:05
Post #79
But JS has "scope", without "var" it's declared in global scope, and will confuse you if you are constructing a closure and use that variable in and it's hard to locate bugs if all variables are in global scope, eg:
function func1() {
i = 1;
fb.trace('"i" in func1() is :', i); // i = 1
function test2() {
// Call func1() here, and see what happens
i = 2;
func1();
fb.trace('"i" in func2() is :', i); // i = 1 !!!
test2();
saivert
post Jan 25 2010, 03:11
Post #80
doesn't hurt to use var everywhere. but the script mostly avoided "var" on the global variables (outside closures).
marc2003
post Jan 25 2010, 03:52
Post #81
QUOTE (saivert @ Jan 25 2010, 01:11) *
i do already. and stuff like the sample colour/font changing stuff goes into an external file as well. then i have an external last.fm script to store my credentials and xmlhttp function - so i can share it between multiple panels.
i just merged it all into a single script above because i couldn't be bothered to explain myself. tongue.gif
Hitchhiker427
post Jan 25 2010, 07:28
Post #82
Last.fm records the number of times I play a track by a specific artist in order to come up with the "top artists" stats. Is this information available to the API? If so, how would I access this in WSH Panel Mod? Thanks.
Edit: I've got it.
This post has been edited by Hitchhiker427: Jan 25 2010, 08:13
Hitchhiker427
post Jan 25 2010, 09:00
Post #83
In case anyone's interested, I modified marc2003's bio script to create a Windows 7 style bio panel and lyrics panel. Screenshots:
The code for the bio panel:
var username = "";
var api_key = "";
var image_path = fb.FoobarPath + "images\\";
ColorTypeCUI = {
text: 0,
selection_text: 1,
background: 3,
FontTypeCUI = {
items: 0,
labels: 1
ColorTypeDUI = {
text: 0,
background: 1,
highlight: 2,
selection: 3
FontTypeDUI = {
defaults: 0,
tabs: 1,
lists: 2,
playlists: 3,
statusbar: 4,
console: 5
get_colors();
window.Repaint();
get_font();
window.Repaint();
if (g_metadb) {
get_font();
get_colors();
xmlhttp.send();
func();
else {
var artist = g_text = playcount = '';
var g_img = gdi.Image(image_path + "header.png");
get_playcount();
url = "http://ws.audioscrobbler.com/2.0/?method=artist.getinfo&api_key=" + api_key + "&username=" + username + "&artist=" + encodeURIComponent(artist);
function get_playcount() {
lastfm(url, "foo_wsh_lastfm_bio", function() {extract_playcount();},0);
try {
playcount = xmlDoc.getElementsByTagName("userplaycount")[0].childNodes[0].nodeValue;
doc.open();
catch(e) {
playcount = "0";
try {
ts.close();
catch(e) {
calc();
function extract_playcount() {
try {
catch(e) {
playcount = "0";
window.Repaint();
ww = window.Width;
wh = window.Height;
calc();
if(g_metadb) {
gr.GdiDrawText(g_text, g_font, g_textcolor, 21, offset + 60, ww-42, wh-offset,DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
gr.FillSolidRect(0, 0, ww, 55, g_backcolor);
gr.DrawImage(g_img, 0, 0, 830, 55, 0, 0, 830, 55);
gr.FillGradRect(830, 0, ww - 820, 55, 0, RGB(252,252,252), RGB(255,255,255));
gr.GdiDrawText(artist, gdi.Font("Segoe UI", 18, 0), RGB(0, 120, 50), 21, 4, ww-77, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText("Artist Playcount:", gdi.Font("Segoe UI", 13, 0), RGB(90, 103, 121), 21, 29, ww-16, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(playcount, gdi.Font("Segoe UI", 13, 0), RGB(42, 102, 212), 120, 29, ww-16, 24,DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.DrawLine(21, 54, ww-21, 54, 1, RGB(214,229,245));
gr.FillGradRect(6, 54,15, 1, 0, RGB(255,255,255), RGB(214,229,255));
gr.FillGradRect(ww-21, 54,10, 1, 0, RGB(214,229,255),RGB(255,255,255));
get_playcount();
artist = fb.TitleFormat("%artist%").EvalWithMetadb(g_metadb);
try {
ts.close();
catch(e) {
calc();
else {
get_bio();
get_playcount();
function calc() {
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
var idx;
_menu.AppendMenuItem(MF_STRING, 2, "View on Last.fm");
_menu.AppendMenuItem(MF_STRING, 3, "Configure...");
if(idx == 2) WshShell.run("http://www.last.fm/music/" + encodeURIComponent(artist));
if(idx == 3) window.ShowConfigure();
_menu.Dispose();
return true;
offset = 0;
else {
window.Repaint();
The code for the lyrics panel:
var lyrics_tag = "%lyrics%";
if (g_metadb) {
var artist = '';
var title = '';
var lyrics = '';
ww = window.Width;
wh = window.Height;
calc();
gr.FillSolidRect(0, 0, ww, wh, RGB(255,255,255));
if(g_metadb) {
gr.GdiDrawText(lyrics, gdi.Font("Segoe UI", 13, 2), RGB(0, 0, 0), 0, offset + 65, ww-16, wh-offset,DT_CENTER|DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
gr.FillSolidRect(0, 0, ww, 55, RGB(255,255,255));
gr.GdiDrawText(title, gdi.Font("Segoe UI", 18, 0), RGB(0, 120, 50), 0, 4, ww-16, 24,DT_CENTER|DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
gr.GdiDrawText(artist, gdi.Font("Segoe UI", 13, 0), RGB(90, 103, 121), 0, 29, ww-16, 24,DT_CENTER|DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
title = fb.TitleFormat("%title%").EvalWithMetadb(g_metadb);
lyrics = fb.TitleFormat(lyrics_tag).EvalWithMetadb(g_metadb);
if (lyrics == "?") lyrics = "No Lyrics Available";
window.Repaint();
function calc() {
arr = temp_gr.GdiDrawText(lyrics, gdi.Font("Segoe UI", 13, 2), RGB(0, 0, 0), 0, 0, ww, wh,DT_CENTER| DT_WORDBREAK | DT_VCENTER | DT_CALCRECT | DT_NOPREFIX).toArray();
textheight = arr[3] - arr[1] + (wh/2) + (lyrics.count("\n") * 3);
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
var idx;
_menu.AppendMenuItem(MF_STRING, 1, "Refresh");
_menu.AppendMenuItem(MF_STRING, 2, "Edit Lyrics");
if(idx == 1) window.Repaint();
if(idx == 2) fb.RunContextCommandWithMetadb("edit",g_metadb);
_menu.Dispose();
return true;
step = gdi.Font("Segoe UI", 13, 2).height * 5;
offset = 0;
else {
window.Repaint();
The required header image (needs to be named "header.png"):
Finally, in order to get the "edit lyrics" command working, you need this component:
http://www.hydrogenaudio.org/forums/index....showtopic=36598
In order to preserve the Windows 7 styling, these scripts don't really play nice with the CUI/DUI default colors. Hopefully someone finds these useful.
marc2003
post Jan 25 2010, 09:20
Post #84
that needs some serious reworking. you're making 3 requests to last.fm for the same file all at once. wink.gif
edit: and it just caused my foobar to crash when starting..... biggrin.gif
This post has been edited by marc2003: Jan 25 2010, 09:24
Hitchhiker427
post Jan 25 2010, 09:44
Post #85
Ok, this should make fewer calls to Last.fm. Hopefully it also fixes any crashes:
var username = "";
var api_key = "";
if (g_metadb) {
get_bio();
g_font = gdi.Font("Segoe UI", 12, 0);
g_textcolor = RGB(0,0,0);
g_backcolor = RGB(255,255,255);
lastfm(url, "foo_wsh_lastfm_bio", function() {save_file();extract_playcount();},0);
xmlhttp.send();
func();
else {
try {
doc.open();
catch(e) {
playcount = "0";
try {
ts.close();
catch(e) {
calc();
try {
catch(e) {
playcount = "0";
window.Repaint();
ww = window.Width;
wh = window.Height;
calc();
if(g_metadb) {
try {
ts.close();
catch(e) {
calc();
else {
get_bio();
function calc() {
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
var idx;
_menu.Dispose();
return true;
offset = 0;
else {
window.Repaint();
This post has been edited by Hitchhiker427: Jan 25 2010, 09:53
marc2003
post Jan 25 2010, 09:58
Post #86
you should be making one call. it's the same file. why are you fetching it twice?
and you might as well scrap the idea of caching files being as though you're fetching the file on every new track.
Hitchhiker427
post Jan 25 2010, 10:50
Post #87
Ok, so I'm (obviously) new at this. What I was trying to do was always download the xml file on each new track to obtain the artist playcount. However, I wanted to use the cached artist bio if available (as your code does). Yes, I understand that much of the usefulness of the cached data is lost in this implementation, but displaying the bio info itself should still be quick (cached data) and only the playcount itself will always have a slight delay. So, it should have worked like this:
if no bio is cached, it makes 1 request for the xml file and extracts the bio and playcount.
if a bio is cached, it makes 1 request for the xml file and extracts the playcount only.
I made some stupid mistakes in the previous versions, however, I've reworked the code again (last time for the night), and I think this does what I want it to:
var username = "";
var api_key = "";
if (g_metadb) {
var artist = g_text = playcount = url = '';
xmlhttp.send();
func();
else {
try {
doc.open();
catch(e) {
playcount = "0";
try {
ts.close();
catch(e) {
calc();
try {
catch(e) {
playcount = "0";
window.Repaint();
ww = window.Width;
wh = window.Height;
calc();
if(g_metadb) {
playcount = '';
get_playcount();
try {
ts.close();
catch(e) {
calc();
else {
get_bio();
function calc() {
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
offset = 0;
window.Repaint();
var idx;
_menu.Dispose();
return true;
offset = 0;
else {
window.Repaint();
marc2003
post Jan 25 2010, 11:23
Post #88
@carmenm, how did you parse the feeds to get image urls? i'm stuck doing this. rolleyes.gif
carmenm
post Jan 25 2010, 11:54
Post #89
QUOTE (marc2003 @ Jan 25 2010, 11:23) *
Can you wait 1 or 2 days? i am on the verge of releasing the manager that will do all that for you.
This post has been edited by carmenm: Jan 25 2010, 11:54
marc2003
post Jan 25 2010, 11:59
Post #90
i'm only interested in downloading 1 image per artist - the one in the artist.getinfo
  <image size="small">http://userserve-ak.last.fm/serve/34/34848663.png</image>
  <image size="medium">http://userserve-ak.last.fm/serve/64/34848663.png</image>
  <image size="large">http://userserve-ak.last.fm/serve/126/34848663.png</image>
  <image size="extralarge">http://userserve-ak.last.fm/serve/252/34848663.png</image>
  <image size="mega">http://userserve-ak.last.fm/serve/_/34848663/Jem++PNG+6.png</image>
i just want to know how to get the url for the "mega" bit and that is all. i tried that activex thing you posted and that works fine if i put in the url manually so i'm happy using that.
carmenm
post Jan 25 2010, 12:08
Post #91
QUOTE (marc2003 @ Jan 25 2010, 11:59) *
Yes that s exactly what my manager does, i wont spoil all the fun wink.gif I am kidding.
With that line you get all artist tags
var artistsArray = xmlDoc.getElementsByTagName("artist");
then with this one you get the mega picture
var artistpicture = (artistsArray[i].childNodes[7].childNodes[0])?artistsArray[i].childNodes[7].childNodes[0].nodeValue:"";
This post has been edited by carmenm: Jan 25 2010, 12:08
marc2003
post Jan 25 2010, 12:23
Post #92
thanks.
carmenm
post Jan 25 2010, 17:21
Post #93
I finally released my suite.
Enjoy
saivert
post Jan 25 2010, 19:10
Post #94
where is the updated Bios panel without multi last .fm requests. I just want a simple codebase to work from.
no fluff or useless crap. Don't understand why you guys have to go overboard with your scripts. Keep it simple stupid. Less is more, etc... etc..
This post has been edited by saivert: Jan 25 2010, 19:11
marc2003
post Jan 25 2010, 20:16
Post #95
updated biography panel which caches the whole xml repsonse which means you can save/display all data. rather than parse the response, it now parses the cached file if it exists during on_metadb_changed. uses external js files so check those as well.
http://cid-649d3bfeaf541fbb.skydrive.live....astfm%20bio.zip
(it doesn't display any new data but i've put in samples of how to do it)
This post has been edited by marc2003: Jan 25 2010, 20:17
Scidd0w
post Jan 25 2010, 23:50
Post #96
marc2003;
Thank you for the above script. I can't seem to get it working though.
Any idea whats going wrong?
popup:
Scripting Engine Initialization Failed (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82, CODE: 0x80020101)
Check the console for more detailed information (Always caused by unexcepted script error).
console output:
WSH Panel Mod (GUID: DA503407-4725-42B8-B2D7-A823F69425D5): initliased in 0.0000371 s
WSH Panel Mod (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82): Parsing file "C:\Program Files (x86)\foobar2000\scripts\marc2003\fonts_colours_flags.js"
WSH Panel Mod (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82): Parsing file "C:\Program Files (x86)\foobar2000\scripts\marc2003\lastfm.js"
Error: WSH Panel Mod (GUID: F22DD133-CB46-41DF-874E-93B34B56CD82): Microsoft JScript runtime error:
Automation server can't create object
Ln: 8, Col: 1
<source text only available in compile time>
marc2003
post Jan 26 2010, 00:11
Post #97
file>preferences>tools>wsh panel mod>uncheck "safe mode". restart foobar.
Scidd0w
post Jan 26 2010, 00:17
Post #98
Great...
Works now!
icedtea
post Jan 26 2010, 10:03
Post #99
Can some kind soul convert the playback section of this theme (buttons, progress, volume etc) to a script for someone like me who doesn't know even a little but of jscript
http://fanco86.deviantart.com/art/MonoLite-122756120
Scidd0w
post Jan 26 2010, 10:31
Post #100
With some bio's it fetches I see &nbsp; codes in there. Is it easy to replace these with normal spaces via your script? What line should I edit where etc?
QUOTE (marc2003 @ Jan 25 2010, 03:59) *
Are you in the process of writing a new script that fetches the artist images from last.fm? Something in the same manner that the bio plugin does. If so I'm lookig forward to it! smile.gif Now that I think of it a configurable amount of images per artist would be a nice to have too (than it will have all I like from the bio plugin without the overhead).
This post has been edited by Scidd0w: Jan 26 2010, 11:17
RSS Lo-Fi Version Time is now: 2nd October 2014 - 04:17
