Upgrade to latest Opus encoder (1.1a), any chance to encoder setting?
Morality124
post Feb 12 2013, 04:12
I was reading around HA and it seems that the latest alpha version of Opus is a generally good improvement over old versions. I currently have the lastest version of the Foobar Encoder Pack installed, so if I were to replace the existing Opus encoder with the latest alpha, should I be able to use the existing preset Opus settings in Foobar Converter?
Also, as an aside question, is there any particular reason why the Opus codec is set to 128k by default in the the Foobar Converter presets?
EDIT: Apologies for the somewhat unclear title.
This post has been edited by Morality124: Feb 12 2013, 04:13
kode54
post Feb 13 2013, 03:47
Group: Admin
Yes, you may use newer Opus encoders with the current preset.
128kbps is generally considered transparent, although I guess you could lower it to as little as 64kbps if you're feeling like testing what's transparent to you.
Morality124
post Feb 13 2013, 05:27
RSS Lo-Fi Version Time is now: 2nd June 2015 - 17:48
