IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
Saving the relative path in a playlist, How to save a relative path for using playlist in hardware players
dobo
post Mar 23 2013, 19:05
Post #1
Group: Members
I use foobar to manage my music and create playlists for use on different machines and hardware players. When i save playlists in m3u format which is what my hardware player supports (mede8er600x3d) foobar 2000 saves them with the drive letter which does not work in mede8er.
Here is an example, both playlists play in foobar 2000
This works in mede8er
../../mp3/Electronic/Nightmares on Wax/Mind Elevation CD1 (2002)/12. Mirrorball.mp3
../../mp3/Electronic/Anubian Lights/Let Not The Flame Die Out (1998)/04. One Eye To The Sky.mp3
This does not work in mede8er and is what i get when foobar saves a playlist.
Z:\music\mp3\Electronic\Nightmares on Wax\Mind Elevation CD1 (2002)\12. Mirrorball.mp3
Z:\music\mp3\Electronic\Anubian Lights\Let Not The Flame Die Out (1998)\04. One Eye To The Sky.mp3
How do i get foobar to save my playlists as in the first example?
For information my playlists are all stored in the following path
Z:\music\playlists\M3U
Go to the top of the page
+Quote Post
marc2003
post Mar 23 2013, 19:44
Post #2
Group: Members
install foo_utils > http://foosion.foobar2000.org/components/?id=utils
file>preferences>tools>text tools. leave the header and footer blank. in the body put...
CODE
$replace(%path%,Z:\music,../..,\,/)$crlf()
now add all tracks to playlist, hit ctrl-a to highlight all files. now right click and select legacy commands (unsorted)>save text. when the save text dialog pops make sure you select all files from the save as type drop down box. you can now save where you like.
+Quote Post
Robertina
post Mar 23 2013, 21:32
Post #3
Group: Members
QUOTE (marc2003 @ Mar 23 2013, 07:44) *
...and also in the M3U format by putting the desired filename plus extension into quotation marks:
CODE
"Electronic.m3u"
+Quote Post
dobo
post Mar 23 2013, 21:45
Post #4
Group: Members
marc2003, this works perfectly, thank you very much. should be in a faq or wiki or something.
i wonder why this hasnt been worked into the way foobar saves its playlists.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 20th August 2014 - 14:06
