IPB
> foobar2000 General Forum Rules
This is NOT a tech support forum.
Tech support questions go to foobar2000 Tech Support forum instead.
See also: Hydrogenaudio Terms of Service.
Make GRADO SR60i sound better in foobar2000, using a vst eq to create a flat response for the SR60i
l-nick
post Nov 26 2011, 22:37
Post #1
Group: Members
Hi! I will show you how to make Grado SR60i sound much better by using an equlizer to try to produce a flat response. My eq preset is based on the graph from headphone.com link.
The end result is based mostly on the accuracy of this graph an the quality of your sound card (mine ASUS XONAR-DX).
You will need:
- foobar2000 link
- foo_vst.dll link
- EasyQ VST link
- EasyQ preset created by me download
This can be done with other set of headphones/speakers if you have the frequency reponse.
Happy listening!
This post has been edited by l-nick: Nov 26 2011, 22:52
Go to the top of the page
+Quote Post
kontra303
post Mar 21 2013, 23:48
Post #2
Group: Members
Please re-up EasyQ preset.
+Quote Post
Propheticus
post Mar 22 2013, 01:30
Post #3
Group: Members
A flat response from your headphone is not always desirable. For instance you can see dips in the response ~7KHz and ~11KHz regions. These are the exact areas where resonance tends to occur in your ear canals. To equalize a headphone so the perceived response is flat you actually need to compensate for your ear's own resonance. The grado's might actually sound more pleasant with these dips than without them.
See this tutorial to EQ your headphone to your head. The technique the OP provided may provide a good starting point though. The grado's response is rather jagged and might prove hard to EQ when doing it by hearing alone.
This post has been edited by Propheticus: Mar 22 2013, 01:31
+Quote Post
markanini
post Mar 22 2013, 06:14
Post #4
Group: Members
Theres no such thing as a flat responce when it comes to headphones. The goal is rather to match the eardrum responce to that of speakers in a room. Such a responce differs wildly for each person so manufacturers deal with averages. Here's two such curves overlayed:
You best bet is taking a raw manikin measurement (here's one)and matching it to the above curves.
This post has been edited by markanini: Mar 22 2013, 06:49
+Quote Post
kontra303
post Apr 4 2013, 18:11
Post #5
Group: Members
up
EasyQ preset re up please
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 18th April 2015 - 10:47
