60 Pages V  « < 56 57 58 59 60 >
WSH Panel Mod, foo_uie_wsh_panel_mod
Falstaff
post Oct 20 2012, 15:04
Post #1426
false bug report, to delete.
This post has been edited by Falstaff: Oct 20 2012, 15:46
http://br3tt.online.fr/
Elevory
post Oct 22 2012, 05:46
Post #1427
Is there a way to get a group of items based on a tag? I wrote a script to automatically keep track of album ratings for Columns UI, but it's quite slow. See for yourself:
//Automatic Album Rating by Elevory
function UpdateAlbumRating() {
    var albumTracks = new Array();
    var albumTrackCount = 0;
    var ratingSum = 0;
    items = plman.GetPlaylistItems(plman.PlayingPlaylist);
    for (i = 0; i < items.count; i++) {
        if (g_album.EvalWithMetadb(items.item(i)) == g_album.EvalWithMetadb(g_metadb)) {
           albumTracks.push(items.item(i));
           if (g_tfo.EvalWithMetadb(items.item(i)) > 0) {
              ratingSum = ratingSum + parseInt(g_tfo.EvalWithMetadb(items.item(i)));
              albumTrackCount += 1;
    for (i = 0; i < albumTracks.length; i++) {
        //plman.SetPlaylistSelection(plman.PlaylingPlaylist, albumTracks[i], 0)
        fb.RunContextCommandWithMetadb("Rate Album "+(Math.round(ratingSum / albumTrackCount)), albumTracks[i], 8);
Also, it relies on Custom DB context menu entries. Is it possible to modify a field without having to access the context menu?
I appreciate the help.
Falstaff
post Oct 23 2012, 20:11
Post #1428
Do i miss something or no callback is activated on playlist rename ? souldn't it be on_playlist_changed ?? for now nothing happens sad.gif
i need it and according to me it should be added if not already available ... thanx by advance
EDIT: my bad, i've used "on_playlist_changed()" that doesn't exist instead of "on_playlists_changed()" tongue.gif
This post has been edited by Falstaff: Oct 23 2012, 20:46
neothe0ne
post Oct 30 2012, 08:39
Post #1429
Is it a known bug that the Menu-generating script doesn't always populate all the menu items for "View"? Sometimes I get only "Always on Top / Visualizations > / Popup panels >", other times I get the full list which includes "GEP control / Console / Equalizer / .."etc.
Falstaff
post Nov 13 2012, 21:12
Post #1430
%cpu increase problem with script engine Jscript9 when moving mouse
no problem with script engine set to Jscript, but with Jscript9, %cpu reach abnormal values (between 6 or 15% on my 6 physical core intel recent CPU, instead of 0 ore 1% normally) when i move the move quickly over the panel, even if the on_mouse_move() function is empty !!!
NB: note that if i remove the function on_mouse_move() from the script, the problem disappear.
i use windows 8 x64, i don't know if it happens on windows Seven, but i repeat: it only happens with Jscript9, not with Jscript engine...
could you check that point T.P please ?
Thanx by advance
derty2
post Nov 13 2012, 21:21
Post #1431
Yes I have noticed this behaviour too.
I have WSH buttons for all menu items and when I press "SHIFT"+"Click button: View" , it behaves as you say.
I just click again (and again) until it works.
Falstaff
post Nov 13 2012, 21:35
Post #1432
QUOTE (Falstaff @ Oct 17 2012, 23:06) *
many other weird crash, 2 panels crashed nearly synchronously, the 2 ones on a gdiDrawText method, and that make bad redraw on columnsUI toolbar too, but this time no freeze
Argument ou appel de procÚdure incorrect
File: <main>
Ln: 81, Col: 9
v1.5.6 seems unstable for now ...
HTH
and since (only a few minutes, check my previous today post above) i turned all my WSH panel to engine Jscript instead of JScript9, weird synchronus crashes are back sad.gif
so, please, don"t forget to check the code around your tooltips modifications in v1.5.6 too ... thanks
Falstaff
post Nov 14 2012, 00:45
Post #1433
QUOTE (Falstaff @ Nov 13 2012, 22:12) *
Thanx by advance
tested on windows 7, no problem with Jscript9 engine ... windows 8 issue with Jscript9 ???
Falstaff
post Nov 20 2012, 19:22
Post #1434
Thanx by advance
nobody else has this problem with windows 8 and Jscript9 script engine ?
ExtremeHunter
post Nov 20 2012, 21:06
Post #1435
I can confirm, high cpu usage here too with JScript9 on Windows 8 x64
Falstaff
post Nov 21 2012, 13:07
Post #1436
thanx, let's hope T.P could give an answer about this problem, and hopefully a solution/fix
EDIT: it looks like a repaint was done on every mouse move even if nothing is coded in the on_mouse_move() Callback. It the Callback it no present at all, no problem. Problem not happen on Seven.
This post has been edited by Falstaff: Nov 21 2012, 13:09
extracampine
post Nov 21 2012, 18:28
Post #1437
Will removing the old WSH panel mod and installing the new one (in order to upgrade the version, the old one needs to be removed) mean that my WSH panel mod data is lost?
Falstaff
post Nov 21 2012, 19:25
Post #1438
QUOTE (extracampine @ Nov 21 2012, 19:28) *
no. wsh scripts are stored in the configuration files (folder foobar2000/configuration), replacing the component will not loose data and scripts.
This post has been edited by Falstaff: Nov 21 2012, 19:25
marc2003
post Nov 22 2012, 10:18
Post #1439
QUOTE (extracampine @ Nov 21 2012, 18:28) *
you don't need to remove the old component. just upgrade through file>preferences>components.
IF you start foobar with the component removed, default UI would retain the scripts but columns UI would lose them all. assuming you're creating your own, you'd keep multiple backups anyway...
QUOTE (Falstaff @ Nov 21 2012, 19:25) *
that's not quite right. only the settings from file>preferences>tools>wsh panel mod are stored there. your scripts are in theme.fth (default UI) or the columns ui.cfg file.
http://marc2003.x10host.com/updates
Falstaff
post Nov 22 2012, 18:46
Post #1440
QUOTE (marc2003 @ Nov 22 2012, 11:18) *
...and column ui.cfg is where if not in /configuration folder wink.gif, but right, for DUI, it's not there.
Takaji
post Dec 4 2012, 00:32
Post #1441
I have a playback command toolbar with a seekbar being drawn in the on_paint function. There's a tooltip that shows up when I hover over the seekbar. When it hovers, the seekbar doesn't update until the tooltip disappears (moving the mouse off the toolbar). I've tried hooking into a bunch of callbacks but I couldn't figure out which one was the proper one, so I'm stumped.
Is there a way to keep the seekbar updated while the tooltip is activated?
Link to the toolbar code (I'm not the original author): https://gist.github.com/8f160fdd33c166d306ae
PS - Is there a way I can log to console?
marc2003
post Dec 4 2012, 11:52
Post #1442
i can't tell because tooltips are generally invoked from on_mouse_move and that script doesn't have it so it must be in one of the external files which are imported at the start.
use fb.trace(blah); to output stuff to the console - blah being a variable. you can of course output plain text if you wrap it in quotes.
Takaji
post Dec 4 2012, 23:10
Post #1443
QUOTE (marc2003 @ Dec 4 2012, 05:52) *
I should've included buttons.js: https://gist.github.com/a8d1e1ffe3916411838c
I'll try doing some additional testing and see if I can resolve my issue. Thanks!
Takaji
post Dec 7 2012, 06:03
Post #1444
I tried turning tooltips on, but discovered that whenever a tooltip is shown, nothing else in the WSH panel will update: the progress bar stalls and play/pause doesn't switch icons.
Any suggestions?
Falstaff
post Dec 7 2012, 08:08
Post #1445
QUOTE (Takaji @ Dec 7 2012, 07:03) *
nope, i use tooltip in my playlist script and panel keeps refreshing as well.
Any suggestions?
sorry, no time to help you for the moment.
marc2003
post Dec 7 2012, 10:35
Post #1446
@T.P, i have a couple of feauture requests.
1 - can we have some way to reload a panel through a command. let's say i'm working on a background .js file. at the moment i have to restart foobar or open the editor and close it. it would be nice if i could invoke a command through the context menu or using window.NotifyOthers
2 - a command to clear the window properties would be great as well.
romka18
post Dec 10 2012, 13:57
Post #1447
also to T.P.:
it will be nice to see in next versions some function to add a track to specific playlist by its path
and, still need something to handle dsp and foo_convert with foo_fileop
marc2003
post Dec 12 2012, 11:30
Post #1448
@T.P, i'm having an issue with tracking tooltips. i've based a seekbar on your example and it works fine if on it's own in a panel. but if i want to integrate with something else that uses tooltips and i use the Deactivate() function, the tracking tooltip stops working.
is there some other code i need to use to make it start working again or is it a bug?
Falstaff
post Dec 12 2012, 18:02
Post #1449
bug reminder for T.P Wang
QUOTE (ExtremeHunter @ Nov 20 2012, 22:06) *
on mouse move over a panel although nothing is coded in the on_mouse_move()) callback...
Falstaff
post Jan 16 2013, 20:24
Post #1450
Keep your great work!
RSS Lo-Fi Version Time is now: 31st January 2015 - 01:25
