EAC rejects AutoFlac setup, Please help me to set up Exact Audio Copy for Auto Flac
danielbdavis
post Jun 23 2012, 07:20
In configuring Exact Auto Copy so that Auto Flac may drive it, there is a substantial sheet of settings in the README. Several are rejected by EAC when I enter them into the appropriate subsection of settings:
1. Under Filename:
. -> Set "Naming scheme" to: %I\%A\%C\%N-%T
. Enable "Use various artist naming scheme"
. Set various artist naming scheme to: %I\Various Artists\%C\%N-%A - %T
. Both the %I\%A\%C\%N-%T and the %I\Various Artists\%C\%N-%A - %T are rejected with the message "Invalid Filename!" whether tried together or separately.
2. Under Compression Options:
. -> External Compression
. -> Enable "Use external program for compression".
. Set "Parameter passing scheme" to: User Defined Encoder
. Set "Use file extension" to: .flac
. Set "Program used for compression" to the full path for flac.exe
. Set "Additional command line options to: --best -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" -T "GENRE=%m" %s
. Disable "Add ID3 tag"
. The "--best -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" -T" are rejected by EAC with the message "Invalid replacement tag found!"
I have tried many of the other settings, and they seem to complete OK, but there is no telling what might happen after all get entered together. Elsewhere, I noticed that an example showed the replacements with two % marks, so I also tried that. No joy.
All help gratefully received.
Thank you.
db1989
post Jun 23 2012, 09:10
How about this?
http://wiki.hydrogenaudio.org/index.php?ti...AC_placeholders
danielbdavis
post Jun 25 2012, 06:06
QUOTE (db1989 @ Jun 23 2012, 04:10) *
Thank you. After looking at the reference, it looks to be spot-on. I'll get back after trying it. And many many thanks.
danielbdavis
post Jun 26 2012, 04:06
QUOTE (danielbdavis @ Jun 25 2012, 01:06) *
Well, now I've tried it, and things have moved forward from the original issue. While EAC starts, there is an error on each track. It claims that it cannot execute the Flac.exe path I gave it, although the path was given by navigating to it by 'browse'. I will approach that as a new thread. Thanks again for the help!
RSS Lo-Fi Version Time is now: 28th August 2014 - 05:14
