results of lossless vs lossy listening test on reddit
krabapple
post Feb 22 2013, 19:29
results out today
http://www.reddit.com/r/audiophile/comment...ssless_results/
db1989
post Feb 22 2013, 19:38
So yes, WE as a people with varying setups and players CAN indeed tell flac from MP3-320, aac192 and MP3-128.
I donít like this.
I had a sinking feeling that the comments would be full of people taking that disingenuous sweeping generalisation and marketing it as a conclusive demolition of all lossy encoders, but I was pleasantly surprised that thereís a good amount of scientific discussion and scepticism there.
Iím sure there are lots of delightful comments there if I were to read far enough, though. I donít really do Reddit. And I try to avoid comment sections in general.
Anyway, Iíll wait with interest to see what other users here think about this.
Kohlrabi
post Feb 22 2013, 20:10
QUOTE (db1989 @ Feb 22 2013, 19:38) *
I donít like this.
3 out of 5 tests showed FLAC at first place, 2 showed 320 kbps CBR MP3. That's a tie to me? Is it possible to run the analysis tools on this usually used on HA ABC/HR listening tests? Garf?
This post has been edited by Kohlrabi: Feb 22 2013, 20:15
krabapple
post Feb 22 2013, 20:14
QUOTE (db1989 @ Feb 22 2013, 13:38) *
I donít like this.
There were some skeptical statistical critique/analyses right at the top of the comments, when I looked there a half hour ago.
edit: btw, it occurs to me that maybe this should have bene in the Listening Tests subforum...sorry, mods, please move as needed.
This post has been edited by krabapple: Feb 22 2013, 20:19
db1989
post Feb 22 2013, 20:42
QUOTE (krabapple @ Feb 22 2013, 19:14) *
Sure, and thatís what I meant:
QUOTE (db1989 @ Feb 22 2013, 18:38) *
I had a sinking feeling [Ö] but I was pleasantly surprised [Ö] Iím sure there are lots of delightful comments there if I were to read far enough, though.
I was referring to the same uppermost comments as you and my reluctance to read much further down. wink.gif
Arnold B. Kruege...
post Feb 25 2013, 14:52
QUOTE (krabapple @ Feb 22 2013, 13:29) *
In as few words as possible - how were the evaluations done? I looked at the site and nothing about that popped out at me.
mjb2006
post Feb 26 2013, 09:01
QUOTE (Arnold B. Krueger @ Feb 25 2013, 06:52) *
See http://www.reddit.com/r/audiophile/comment...st_details_and/
Garf
post Feb 26 2013, 11:19
Server Admin
Group: Admin
QUOTE (Kohlrabi @ Feb 22 2013, 20:10) *
No, the test didn't show that. If you squash all listeners together, and hence pretend only a single person took the test, then yes. You can also squash the samples together, and then say FLAC won only 1 test smile.gif That's not the right way to analyze this.
If we instead consider there are 62 listeners, times 5 samples, each of which did a block of 4 codecs, then we get this:
./bootstrap.py --compare-all --blocked reddit2.csv
bootstrap.py v1.0 2011-02-03
Copyright (C) 2011 Gian-Carlo Pascutto <gcp@sjeng.org>
License Affero GPL version 3 or later <http://www.gnu.org/licenses/agpl.html>
Reading from: reddit2.csv
Read 4 treatments, 310 samples => 6 comparisons
Means:
MP3_320      FLAC   AAC_192   MP3_128
   2.406     2.165     2.694     2.761
Unadjusted p-values:
MP3_320   0.013*    0.005*    0.001*
FLAC      -         0.000*    0.000*
AAC_192   -         -         0.520
FLAC is worse than MP3_320 (p=0.013)
AAC_192 is better than MP3_320 (p=0.005)
AAC_192 is better than FLAC (p=0.000)
MP3_128 is better than MP3_320 (p=0.001)
MP3_128 is better than FLAC (p=0.000)
p-values adjusted for multiple comparison:
MP3_320   0.028*    0.014*    0.004*
AAC_192   -         -         0.521
FLAC is worse than MP3_320 (p=0.028)
AAC_192 is better than MP3_320 (p=0.014)
MP3_128 is better than MP3_320 (p=0.004)
Note that better really means worse here - Reddit had good=1 and bad=4. The test result is basically:
FLAC > MP3_320 > AAC_192 = MP3_128
I'm surprised that they're apparently able to tell 320kbps MP3 from a FLAC, but fail to tell an 192kbps AAC from an 128kbps MP3. (Unless 192kbps iTunes has the same lowpass as 128kbps LAME, of course smile.gif smile.gif)
Garf
post Feb 26 2013, 11:30
Server Admin
Group: Admin
Three of these sections were then re-encoded from that lossless WAV to MP3-320 Joint Stereo, AAC-192 and MP3-128 Non-joint Stereo (via Goldwave) while the last section remains lossless.
What encoders goes Goldwave use? Also why force full stereo on an 128kbps MP3 encode, that does not make sense.
LithosZA
post Feb 26 2013, 11:45
I hope they didn't use something like FAAC for AAC encoding...
I agree, that doesn't make sense at all.
Garf
post Feb 26 2013, 11:56
Server Admin
Group: Admin
QUOTE (LithosZA @ Feb 26 2013, 11:45) *
Seems to be QuickTime (which should be fine?) and some version of LAME (potentially an alpha).
RSS Lo-Fi Version Time is now: 26th November 2014 - 06:47
