AccurateRip confidence - what does it really say?
OliP
post Jan 7 2013, 02:00
I have a CD RIP with EAC V1.0 beta3
Checked with CUETools 2.1.4
CUETools gives me here:
03 [f41e2a14|bc31a59f] (39+08/88) Accurately ripped
So thats means, this track matches with 39 in AR V1 and with 8 in AR V2.
Makes 47 matches alltogether. But there are 88 entries!
Are these 41 other rips, rips with errors? Or maybe different pressings?
Well !
My logical thinking tells me that read errors always occure on different places on CDs right?
So erroneous rips do always have different checksums and none of them matches another, right?
So if I have a confidence 1, its most likely that I have a bit-identical copy. Otherwise me and the other user, we both must have a read error at exactly the same place, so that our checksums are identical, and this is very unlikely right ??
So when I have AR confidence 1 and the database also has many other results I do not match with, its most likely that my rip is correct, and all the others are wrong, (or different pressings) right ???
Iīve never really understood this...
But:
If I have a confidence of only 1, my rip is at 99,9999999999999999999999 % a Bit-identical copy, right?
This post has been edited by OliP: Jan 7 2013, 02:09
spoon
post Jan 7 2013, 09:22
dBpowerAMP developer
Group: Developer (Donating)
The answer is different pressings, also you only need a confidence of 1 (as long as you did not submit this result)
Spoon http://www.dbpoweramp.com
OliP
post Jan 7 2013, 15:12
QUOTE (spoon @ Jan 7 2013, 09:22) *
could also mean, that we both have an erroneus rip!
So is ist it correct, what I assume, that read errors nearly always appear on different places, and thats why erroneus rip checksums as good as always differ each other??
And therefore a match with just one other person means a perfect rip. Notice well, not 100% sure, but with a probability of 99,99999%.
I nowhere found an explanation about that in german language, so now thats just a logical attempt to understand it !
For a match with one person does not automaticaly mean an errorfree rip!
Can someone technical versed, give me a confirmation for my thinking?
This post has been edited by OliP: Jan 7 2013, 15:19
spoon
post Jan 7 2013, 16:07
Anything is possible, even if improbable.
The way AccurateRip works once a disc has been verified by a 2nd person (confidence of 2), then it takes up that 'slot' in the database, to add to this slot (such as a different pressing) requires 2 verifications. That means ripping errors tend to be excluded from the database (as generally speaking ripping errors are unique to your disc + also to some extent your drive).
So this leaves a false negative chance, and the odds against this are quite huge (you have more chance of being struck by lightening), over the years AccurateRip has processed 143M discs, I am sure that possibly one of the tracks on one of those rips had a false positive, but unless you are ripping 143M discs I would not worry about it.
This post has been edited by spoon: Jan 7 2013, 16:16
OliP
post Jan 8 2013, 16:23
QUOTE (spoon @ Jan 7 2013, 16:07) *
I donīt understand this.
Itīs correct that erroneous results (nearly) always differ each other.
So when I have an erroneous rip, I will not match with anyone.
Right?
Thatīs all I wanted to know
This post has been edited by OliP: Jan 8 2013, 16:33
Engelsstaub
post Jan 8 2013, 16:49
Es ist sehr unwahrscheinlich. (It is very unlikely.)
If your rip contains errors it is extremely improbable that another submission will contain those exact same errors.
An exception is this: if you illicitly download someone else's rip and use a program like XLD or CUETools to verify this rip, it can return an AR result of at least 1. This is obviously because that same rip was likely already submitted to the AR database. (We know the moral of that story.)
The Loudness War is over. Now it's a hopeless occupation.
pdq
post Jan 8 2013, 17:03
Another possibility, though I don't know how likely this is: If there is a flaw in the glass master for a CD such that multiple copies have exactly the same incorrect data, then the rips will be verified by AR.
greynol
post Jan 8 2013, 18:23
In addition, defective drives and issues with the ripping software can result and, in all reasonable certainly, have resulted in the population of the AR database with active* hashes for errant rips.
(*) active meaning confidence two or greater; confidence of one if there are no other validated submissions for any particular disc ID.
This post has been edited by greynol: Jan 9 2013, 02:00
DR figures too, of course.
OliP
post Jan 8 2013, 21:13
QUOTE (pdq @ Jan 8 2013, 17:03) *
So thats a production mistake at a certain CD charge, meant so?
But will happen only on rare occassions, right?
Ok, now Iīm going to understand the kidding-like sentence of spoon - "anything is possible"
QUOTE (greynol @ Jan 8 2013, 18:23) *
In addition, defective drives and issues with the ripping software can result and in all reasonable certainly have resulted in the population of the AR database with hashes for errant rips.
yes, but that falls in the category erroneous rips, where itīs so much unlikely to have exactly the same error on another machine, and get a confidence for that.
OK
greynol
post Jan 8 2013, 21:20
You're misunderstanding. By defective I meant a flaw in the design that may affect an entire line of drives sharing common firmware. I hope the software portion of my comment doesn't need similar qualification.
OliP
post Jan 8 2013, 21:22
And - in that case, I would get an AR verification, but have ripped an error, that was now implemented in my wav-file.
So it could be possible hear that clearly in the wav file, but not when playing the CD on a CD-Player that corrects such errors to unsensable!
But my EAC also has an error-correction...
greynol
post Jan 8 2013, 21:26
EAC's "error correction" is only limited to synchronization issues. Otheriwise asking the drive to continually re-read data and pick what comes up most consistently hardly constitutes error correction.
Regarding concealment, (most?) computer drives will handle it the same way as the old stand-alone players. Is there even a difference these days between computer drives and the transports in standalone players?
This post has been edited by greynol: Jan 8 2013, 21:37
OliP
post Jan 8 2013, 21:51
QUOTE (greynol @ Jan 8 2013, 21:20) *
A defective drive charge.
But thatīs also very seldom.
What about the ripping software?
A certain CD ripped by 10 persons with an unprofessional or wrong configured software will give me confidence 10 when I use the verry same software or wrong configuration and the same CD?
OK we donīt have to count beans here.
A confidence of 1 means an errorfree rip for 99,999999999 %, if Iīm sure, that itīs not my own past submission.
greynol
post Jan 8 2013, 22:11
This is an old conversation which I'm really not interested in having yet again. I've analyzed tens of thousands of rips for myself and on the behalf of others and have seen my share of anomalies.
OliP
post Jan 8 2013, 22:52
Post #15
QUOTE (greynol @ Jan 8 2013, 22:11) *
analyzed rips? share of anomalies?
Oh, a german speaker does not understand this sentence.
Well, I also want to close this conversation.
Confidence 1 means a bit identical copy, for 99,99999999 % probability.
Now I just want to have the information of the other thread, if the AR DB can distinguish results.
So then, a confidence of 1 for a seldom/rare CD is OK, when Iīm sure that I was not the person who caused this in the past.
This post has been edited by OliP: Jan 8 2013, 22:53
greynol
post Jan 8 2013, 23:48
Post #16
Something along the lines of this as one of many examples that can be found online:
http://www.digital-inn.de/exact-audio-copy...-related-3.html
Take from it what you will. I'm not going to spend any more time on the matter. smile.gif
This post has been edited by greynol: Jan 9 2013, 01:53
RSS Lo-Fi Version Time is now: 30th January 2015 - 05:26
