Just want to point out flaw in Winamp 2.9x, Why FB2k is better ;)
feces1223
post Apr 19 2003, 17:06
Group: Banned
I want to point out that Winamp 2.9 was flawless with the exception of bad video support, and when you play a game while running it in the background while cause the game to be choppy and the sound to distort.
-----Foobar2k doesn't have this problem and uses the smallest amount of ram i've ever seen for running mp3s.
For Winamp 2.91 which i thought would fix this problem, i didn't check to see if it was resolved because I saw an obvious new flaw. The variable bitrate meter was very innaccurate when looking at aps mp3s.
----Foobar2k is flawless with aps mp3s it doesn't show the bitrate but, thats good. I love Foobar2k over Winamp and its my prodominent player from now on. Although i wish they had proper playback support (fastfordward,rewind, etc.)
I'm very impressed by FB2k wink.gif and Nullsoft's days seem dull and OVER. FB2k will only get better if improved step by step by the same excellent programmers wielding it. Keep upi the good work
This post has been edited by feces1223: Apr 19 2003, 17:07
[JAZ]
post Apr 19 2003, 19:35
Are you pointing out a bug in winamp, or just making propaganda of Foobar, because you like it?
It sounds more like the second.
The video plugin is in developement and actually, it should be much like any directshow player (with it's pros and cons).
I haven't got yet any problem, except that it doesn't size correctly mpeg2 videos (I have the elecard decoder). And I do have, mpeg1, mpeg2, wmv1/3, div3/5 and Xvid videos.
About the thing about the bitrate... seems childish, really... what's the exact meaning of "The variable bitrate meter was very innaccurate " ? maybe that it was showing 128 when it was 320? Or maybe that it was updating faster/slower? I doubt you can be sure of the first, (variable is variable), and I wouldn't call the second really a problem.
So, all in all, keep things separated. If you like foobar, ok. that's fine, but this argument for not using winamp was a bit inmature.
Actually, If foobar is going to continue with this interface, I expect it to be SIMILAR (I don't say the same or better) than apollo (http://www.iki.fi/hy/apollo , for those who don't know. btw, seems it is being discontinued.) THAT's a playlist system, not foobar's. (Not to say that I love the miniwindow mode also.)
Dibrom
post Apr 19 2003, 19:40
Founder
Group: Admin
This thread doesn't belong in the MP3 forum.
Also, I hope that this thread isn't going to turn into another winamp vs foobar2000 player bashing thread...
If you want to point out that you think foobar2000 is a good player, it's better to post that in the hosted foobar2000 forum. You could probably even do so without justifying with fb2k is good because you think winamp isn't... and then saying that Nullsoft is over (which is honestly quite far from the truth, from the looks of things).
And foobar2000 can rewind and fast forward. Use the arrow keys.
RIV@NVX
post Apr 19 2003, 20:19
QUOTE ([JAZ)
,Apr 19 2003 - 08:35 PM] THAT's a playlist system, not foobar's. (Not to say that I love the miniwindow mode also.)
It's a matter of preference. IMHO, foobar2000's title formatting library leaves this playlist design far behind.
Guillaume
post Apr 19 2003, 20:58
QUOTE (RIV@NVX @ Apr 19 2003 - 08:19 PM)
QUOTE ([JAZ)
Apollo's tree structure in the playlist really is a strong advantage...
Listen to Guillaume - EAC/MP3 Guide
I see seven towers, but I only see one way out...
Mgz
post Apr 19 2003, 21:16
I play CS and use CounterAmp to control my player, would foobar can do it
huh.gif . And I never encounter any choppy,etc crap.Maybe you should check your computer.
Another propaganda of Iraqi Information Minister dry.gif with a Winamp brain-washed™ person like me biggrin.gif
still LAME 3.96.1 --preset extreme -q 0 -V 0 -m s at least until 2005.
Delirium
post Apr 19 2003, 21:18
Comedy "I use XMMS (which is basicaly a Winamp clone) 'cause foobar doesn't run on Linux" reply.
Morphix
post Apr 19 2003, 21:21
I agree the cpu consumption is always slight on mp3 decoding with winamp. This is probably your puter cutting into the pagefile. Yet another great pharm post by feces, your posts are great man they never cease to entertain me.
Proud member of the FLAC and MPC evangelism
rjamorim
post Apr 19 2003, 21:24
Rarewares admin
QUOTE (feces1223 @ Apr 19 2003 - 01:06 PM)
Wow. That is so zealotish, it even hurts.
http://www.rarewares.org
p0wder
post Apr 19 2003, 21:32
QUOTE (rjamorim @ Apr 19 2003 - 12:24 PM)
zealotish
Hmm, is the right word "zealotish" or "zealous"?
rjamorim
post Apr 19 2003, 21:37
Rarewares admin
QUOTE (p0wder @ Apr 19 2003 - 05:32 PM)
p0wder
post Apr 19 2003, 21:45
QUOTE (rjamorim @ Apr 19 2003 - 12:37 PM)
Even though I use foobar now, I don't have anything against Winamp. I've used Winamp as my main audio player for a loooong time. I remember when they used to have the "lo-fi" and "hi-fi" switch on the main window. Well, something like that, I have a bad memory. smile.gif
Peter
post Apr 19 2003, 21:46
foobar2000 developer
Group: Admin
rjamorim ist teh anti-zeal0try zeal0t.
feces1223: you might want to try posting this on winamp forums instead, you will annoy more people there.
(ehem, someone move this thread where it belongs ?)
Reiginsei
post Apr 19 2003, 21:49
I noticed the new version of Winamp 2.91 makes Half Life TFC run choppy as well, although at first I thought it was my Radeon drivers. Running Foobar2000 solves the chopiness. For some reason I can't have shuffle and repeat enabled in FB2k though, must be a problem on my side.
Peter
post Apr 19 2003, 22:04
Post #15
Group: Admin
actually, i get weird input freezes in quake2 when running fb2k in background (even when not playing), but i dont even bother researching that (can always run from music from another machine, meh)
Canar
post Apr 19 2003, 23:22
Post #16
QUOTE (p0wder @ Apr 19 2003 - 12:45 PM)
Was that before or during the Nitrane era?
Heh, I remember the "Boost high-frequency" option on the old Nitrane core, back in the days when plugins were new and spiffy. That and the Win32 API playlist and EQ. That piece of software's sure come far, eh?
2. Assume good faith.
kode54
post Apr 20 2003, 13:25
Post #17
Group: Admin
You could try tweaking some PCI latency settings.
[JAZ]
post Apr 20 2003, 13:49
Post #18
QUOTE (Canar @ Apr 19 2003 - 11:22 PM)
I think it was in winamp 1.7 or 1.8.
If I remember well, the "button" was between the "khz" and the "mono/stereo" space.
It turned out 32bit decoding instead of 16bit, but my memory might be wrong here.
Madrigal
post Apr 20 2003, 14:33
Post #19
QUOTE (p0wder @ Apr 19 2003 - 03:32 PM)
zealotish
It is entirely possible to be zealous about something, without being a zealot (i.e. zealous in the extreme). This being so, then even though it is a coined word, "zealotish" seems about as good as any to convey the intended meaning.
For absolute purists, however, there is no need to coin an adjective like zealotish when a noun phrase using zealot will do. Examples:
he is zealotish = he is a zealot
he is so zealotish = he is such a zealot
etc.
Regards,
Madrigal
rjamorim
post Apr 20 2003, 18:42
Post #20
Rarewares admin
QUOTE (Madrigal @ Apr 20 2003 - 10:33 AM)
etc.
Regards,
Madrigal
Interesting. Thanks for clarifying it.
Seems I need to leard a lot until I can consider myself fluent in English. smile.gif
NeoRenegade
post Apr 21 2003, 16:58
Post #21
Ugh, no "zealoutish" is not real word; it's the product of a weak mind to wrapped up in its own delusion to use the proper word, "zealous".
RSS Lo-Fi Version Time is now: 2nd July 2015 - 14:02
