8 Pages V  « < 6 7 8
Multiformat Listening Test @ 128 kbps - FINISHED
guruboolez
post Jan 23 2006, 14:52
Post #176
Group: Members (Donating)
QUOTE (QuantumKnot @ Jan 18 2006, 12:50 AM)
I haven't been following developments in aoTuV lately, but has Aoyumi improved the block switching algorithm to reduce smearing on microattacks?  If not, then I might have a look at it again if I have time.  But if it's been fixed, then I won't have to worry. biggrin.gif
There's still headroom for progress I'd say. During my last listening evaluation, Vorbis was still unsharp and noisy on micro-attacks/short-impulses samples. Most often bitrate doesn't go really high on such samples (Vorbis tends to inflate the bitrate when needed - but not here).
kurtnoise
post Feb 16 2006, 08:38
Post #177
Some statistical analysis by AMTuring about this listening test...
@Guru:: very nice your avatar btw... smile.gif
Garf
post Feb 16 2006, 10:04
Post #178
Server Admin
Group: Admin
QUOTE (kurtnoise @ Feb 16 2006, 09:38 AM)
Oh please, can we keep the crackpot science out of this forum? This person wasn't banned here for no reason. Just juggling around scientific words doesn't magically make anything you say sensible, lest alone correct.
It is well known that some songs are more difficult to encode than others, and they result in lower quality encoded files regardless of the encoder used. So the assumption of equal means amongst experiments is violated.
Bzzzt. This was a VBR test. Meaning, although the average was 128kbps (or slightly more), the codecs could spend as much bits as necessary to keep all clips at a constant quality. This means you cannot immediately assume the means aren't equal, in fact it should be the opposite.
So, what happens if we actually look at the data? (note that he provides many graphcs to 'illustrate' his points, except the ones where, well, the data doesn't support his claims anywhere) The variance of the means of the samples is much less than the difference between the codecs themselves. (exluding Shine, which is CBR)
In other words, VBR works. I would have thought that that was "well known" by now.
The following table shows the Tukey HSD applied to the ranks.
Say what? You cannot apply plain Tukey HSD to rank scores, it's a parametric test. Now, I'm willing to argue that we shouldn't use parametric analysis (because the top end of the results clips at 5.0, and you can see this by observing that the lower rated the codec, the higher the variance). However, if anything parametric analysis gives stronger results. If you use rank scores, let's actually use the rank score version of Tukey HSD to analyze the results:
FRIEDMAN version 1.24 (Jan 17, 2002) http://ff123.net/
Nonparametric Tukey HSD analysis
Number of listeners: 18
Critical significance: 0.05
Nonparametric Tukey's HSD: 25.894
Ranksums:
Vorbis iTunes WMA Nero LAME
73.00 62.50 49.50 48.50 36.50
-------------------------- Difference Matrix --------------------------
Vorbis 10.500 23.500 24.500 36.500*
iTunes 13.000 14.000 26.000*
WMA 1.000 13.000
Nero 12.000
Vorbis is better than LAME
iTunes is better than LAME
Gee, where did those "extra" conclusions go?
Let's compare this to the means with parametric Tukey HSD:
Tukey HSD analysis
Tukey's HSD: 0.110
Means:
4.79 4.74 4.70 4.68 4.60
Vorbis 0.049 0.090 0.106 0.193*
iTunes 0.041 0.056 0.143*
WMA 0.016 0.103
Nero 0.087
Coincidence? Hardly. If you derive the rank scores from the means, how can you expect a different conclusion? How would you expect throwing away information to increase the significance? It won't, unless you use a completely wrong analysis method.
This post has been edited by Garf: Feb 16 2006, 10:23
bug80
post Feb 16 2006, 11:00
Post #179
Maybe it is a good idea to post your reply on Doom9 also, Garf.
ff123
post Feb 16 2006, 14:56
Post #180
ABC/HR developer, ff123.net admin
Group: Developer (Donating)
I posted a reply on doom9, suggesting he use bootstrap resampling if he's hard up to analyze the data some more.
ff123
detokaal
post Feb 16 2006, 17:45
Post #181
QUOTE (Garf @ Feb 16 2006, 04:04 AM)
Bzzzt.
torok
post Mar 22 2006, 19:35
Post #182
Did anyone else notice that when you normalize for bitrate, you get this:
iTunes = 4.83
AoTuV = 4.55
lame = 4.5
WMA = 4.84
Which looks like it makes iTunes and WMA tied for first and the rest in second. Now, I'm not sure if it's reasonable to normalize like that (it's asssuming that quality of a codec is directly 1:1 with bitrate), but it's an interesting thought.
http://www.pkulak.com
Busemann
post Mar 22 2006, 19:37
Post #183
QUOTE (torok @ Mar 22 2006, 10:35 AM)
iTunes = 4.83
AoTuV = 4.55
lame = 4.5
WMA = 4.84
The only fair way to test this would be to use CBR.
Mardel
post Sep 24 2011, 22:51
Post #184
Hi!
I look at the 128 kbps listening test on your site, and i cant accept that aoTuV vorbis worse than aac.
And then I realize that vorbis or aac q settings are bad. First thing that is the vorbis use comma and not dot for decimal.
Second thing the ogg file is smaller than aac approx. 0,5 - 0,9 MB lesser.
Then i looked the average bitrates in foobar2000 the ogg's bitrate 20 kbit lesser than the aac.
e.g.: 158 kbps vs 138 kpbs
I encoded same track and another track with vorbis -q 4,99 settings and the bitrate difference was 1-2 kbit and the file size difference was 0-0,1 MB.
Overall your tests doesn't give a direction for which codec is better if the codec settings are wrong.
This post has been edited by db1989: Sep 25 2011, 11:35
Reason for edit: merged in from unrelated thread
Wavpack -hh or TAK -pMax
OggVorbis aoTuVb6.03 -q 4
[JAZ]
post Sep 24 2011, 23:36
Post #185
The vorbis commandline uses comma or dot depending on the localization of the OS where it is running.
As you've found, if the setting being used was wrong, the bitrate would have been much different.
db1989
post Sep 25 2011, 11:30
Post #186
QUOTE (Mardel @ Sep 24 2011, 22:51) *
Given that many modern codecs perform better, or only, in VBR or ABR modes, listening tests reporting a bitrate such as this one are generally based on the principle of tuning the codec settings to obtain that bitrate, or as close as possible to it, as the mean bitrate over the set of audio files being tested. Thus, variation between different encodes of one file are to be expected and do not invalidate the methodology (inasmuch as there doesn’t seem to be another solution; this is as close to fair as is possible).
C.R.Helmrich
post Sep 25 2011, 13:06
Post #187
QUOTE (Mardel @ Sep 24 2011, 23:51) *
Sorry, but which test are we talking about? The test discussed in this thread is MP3 only.
Edit: Thanks lvqcl! Must be http://soundexpert.org/encoders-128-kbps then, which is from mid 2006.
Chris
This post has been edited by C.R.Helmrich: Sep 25 2011, 13:28
lvqcl
post Sep 25 2011, 13:13
Post #188
QUOTE (C.R.Helmrich @ Sep 25 2011, 16:06) *
IIRC that post was moved from http://www.hydrogenaudio.org/forums/index....showtopic=77708 to this thread.
db1989
post Sep 25 2011, 13:31
Post #189
Thanks for pointing out my silly mistake; the irony is not lost on me… blush.gif That’s what I get for barely reading! Re(re)located to the correct thread.
8 Pages V  « < 6 7 8
RSS Lo-Fi Version Time is now: 25th April 2015 - 08:37
