Force "Normally start"
D3smo
post Oct 19 2010, 14:53
Sometimes my foobar (wich start at PC starts), shows a windows that said "Foobar did not terminate normally, do you want start in safe mode or normal mode".
When i choose normal mode, it's always work fine, so i want to force foobar to start in normall mode all time, maybe using argument in launching parameters, but i don't know how to do any help ?
My main issu is not having this window on startup and just foobar starting in normal mode.
Thanks for help
tpijag
post Oct 19 2010, 15:11
I am not sure that is possible. Someone else may have more knowledge.
That said, it is my experience that Foobar never gets in this state on it's own. It is most likely caused by a component that hangs a touch when windows goes through it's shut down routine. I continue to use such a component so I will occasionally get this same situation. One way to avoid the problem is to close out foobar before shutting down Windows. Not a full solution for you...but I thought I would mention it as it does seem to eliminate the startup error dialog.
terry
This post has been edited by tpijag: Oct 19 2010, 15:12
Robertina
post Oct 20 2010, 04:12
Group: Banned
If foobar2000 is unable to delete the file "running" (no extension) during its exit process it thinks that it has been abnormally ended if it discovers that file when it is launched the next time and it will present to you the error message you cited.
It is possible theoretically to delete that file e.g. on each Windows (re)start but this would impede the intended purpose of that file.
shakey_snake
post Oct 20 2010, 04:58
Group: FB2K Moderator
Perhaps you should follow the instructions of this forum's Sticky thread to see if you have any problematic components.
elevatorladylevitateme
D3smo
post Oct 20 2010, 13:00
QUOTE (shakey_snake @ Oct 20 2010, 05:58) *
Could you give me the link
tpijag
post Oct 20 2010, 13:21
Threads that are persistent [sticky or pinned] are always at the beginning of a forum.
Pretty standard across all forum software. Just scroll up and click the forum title.
terry
D3smo
post Oct 21 2010, 14:43
Here is the list of my components, is there one with known trouble when crashes ?
tpijag
post Oct 21 2010, 14:51
Help>Online Troubleshooter
D3smo
post Oct 8 2012, 12:49
Two year after submitting the issue i finally find a way to solve it
http://www.hydrogenaudio.org/forums/index....showtopic=84950
tpijag
post Oct 8 2012, 14:00
Do you have a point or are just letting everyone know about the value of search? wink.gif This 'fix' came within a couple of weeks, not 2 years.
This post has been edited by tpijag: Oct 8 2012, 14:01
NEMO7538
post Oct 8 2012, 16:18
QUOTE (D3smo @ Oct 21 2010, 15:43) *
foo_uie_quicksearch is outdated (two years old), use foo_quicksearch instead.
RSS Lo-Fi Version Time is now: 31st July 2015 - 04:09
