DSP plugin that adds white noise or DC offset, if your DAC doesn't like digital silence...
lvqcl
post Jun 28 2009, 18:05
foo_dsp_noise 0.0.4:
This plugin just adds TPDF white noise or constant DC offset.
It should be last in your DSP chain.
Chris Norman
post Jun 30 2009, 22:14
Sorry to ask but, but why would you want to do that, adding white noise?
http://www.vonpell.com
GeSomeone
post Jul 1 2009, 13:50
I have 2 questions,
- couldn't you use foobar dither instead? (well I know it can only be used at 16 bit output)
- What kind of DAC's would not like (digital) silence?
In theory, there is no difference between theory and practice.
Yirkha
post Jul 1 2009, 14:51
Group: FB2K Moderator
See this topic, maybe.
lvqcl
post Jul 1 2009, 15:51
QUOTE (Chris Norman @ Jul 1 2009, 01:14) *
QUOTE (GeSomeone @ Jul 1 2009, 16:50) *
I have 2 questions,
Sorry for (possible) confusion. Yes, Yirkha pointed to the thread where you can see some grounds for this plugin.
And, there was an earlier thread with the same problem.
QUOTE (Audionerd @ May 24 2009, 15:09) *
One possible explanation is that only foobar output is truly all zeros when the signal is silent, but I have no way of proving that right now. Suggestions on how to test this are welcome.
Well, this plugin can help to prove or disprove it.
Chris Norman
post Jul 5 2009, 11:36
QUOTE (Yirkha @ Jul 1 2009, 15:51) *
solomonkane456
post Feb 7 2010, 01:36
This is genius and a great solution for hdmi audio "silent stream" problem. Could you, by any chance
develop this plugin for other players, for instance KMPlayer?
lvqcl
post Feb 7 2010, 12:03
Sorry, I don't plan to do this.
solomonkane456
post Feb 7 2010, 19:05
Thanks anyway:)
amiti
post Oct 2 2012, 15:07
In this plugin one can choose to which bit to add the noise. Should the desired output bit depth influence this decision? If I wanted to mimic TPDF noise what would I choose?
lvqcl
post Oct 2 2012, 15:23
QUOTE (amiti @ Oct 2 2012, 18:07) *
It depends on what you want.
It is always tpdf, just with different level.
amiti
post Oct 2 2012, 18:41
Thank you lvqcl. I was asking what is considered standard or common setting in other software that allow TPDF dither. Would they add the same level of noise to 16 bit and 24 bit target bitdepths? What noise level would be considered normal or common?
amiti
post Oct 10 2012, 20:51
I opened a separate thread to understand the dither and noise terminology a little better.
Now , may I ask , if I wanted to dither to 16 bit output format , using your plugin , would the usual way be to set the noise to the 16th bit? Similarly if the target format is 24 bit should the noise in your plugin be set to the 24th bit?
lvqcl
post Oct 11 2012, 15:23
QUOTE (amiti @ Oct 10 2012, 23:51) *
Yes, that's right
RSS Lo-Fi Version Time is now: 28th January 2015 - 10:39
