2 Pages V   1 2 >
WMA 192 kbps vs WMA VBR 240-355 kbps
JasonWilley
post Oct 12 2010, 23:16
besides the obvious file size differences, what will be the differences in sound quality and performance when ripping music with windows media player 12?
will the sound be the best lossy file at the highest vbr settings compaired to wma 192
cheers
This post has been edited by greynol: Oct 13 2010, 00:45
Reason for edit: Standard font, please.
pdq
post Oct 12 2010, 23:32
While the higher bitrate should theoretically be of higher quality, for most people and most music the difference will probably be inaudible.
Having said that, VBR is almost always the most efficient way to get the highest quality.
Beyond that you would need to do your own testing to see how they sound to you on your own equipment.
This post has been edited by greynol: Oct 13 2010, 00:44
Reason for edit: Removed unnecessary quotation of the initial post.
Juha
post Oct 13 2010, 04:39
WMA 192kbps ... what 'bout it as WMA Pro 24-bit resolution.
Juha
JasonWilley
post Oct 13 2010, 11:26
i always thought wma pro was 16 bit
pdq
post Oct 13 2010, 12:49
QUOTE (JasonWilley @ Oct 13 2010, 06:26) *
And I always thought that lossy encodings had no bit depth?
lvqcl
post Oct 13 2010, 15:54
I wonder why WMA STD encoder cannot correctly encode 60.wv in VBR mode...
JasonWilley
post Oct 13 2010, 23:24
i cant hear any obvious differences so would i be better of with normal wma 192
pdq
post Oct 13 2010, 23:41
QUOTE (JasonWilley @ Oct 13 2010, 18:24) *
If you are asking between WMA standard vs. WMA pro, WMA standard has much more universal support.
JasonWilley
post Oct 14 2010, 08:55
i know but am asking interms of pure sound quality between wma and wma vbr at highest settings
greynol
post Oct 14 2010, 09:00
If you cannot ABX then there is no difference in terms of "pure sound quality."
Placebophiles: put up or shut up!
JasonWilley
post Oct 14 2010, 11:46
i dont know what abx is or meens
Ouroboros
post Oct 14 2010, 11:54
Try the HA WIKI, or Google, or Wikipedia........
dhromed
post Oct 14 2010, 12:00
QUOTE (JasonWilley @ Oct 14 2010, 12:46) *
ABX is a methodology to determine difference and/or superiority between two audio samples. Details here.
Lossy compression has no real objective measure of quality whereby you can scan a file and say for certain that X has greater quality than Y. You can assume that, for example, a 320kbps MP3 is of better quality than a 192kbps one, but you can only verify it by listening.
In other words, if you cannot hear a difference, then there is none, and it would make no sense to pick one compression type over another.
pdq
post Oct 14 2010, 13:32
QUOTE (JasonWilley @ Oct 14 2010, 06:46) *
Oh come on! huh.gif You've been a member for seven months and you didn't know the meaning of ABX?
dhromed
post Oct 14 2010, 14:14
Post #15
QUOTE (pdq @ Oct 14 2010, 14:32) *
Join date only loosely correlates with lurkingtensity, in my experience.
2Bdecided
post Oct 14 2010, 17:36
Post #16
ReplayGain developer
QUOTE (JasonWilley @ Oct 14 2010, 17:31) *
we not all geeks you know
No, but if you can reach Hydrogenaudio, then you can probably reach Google too.
And though I'm sure you didn't mean to, if someone wanted to seriously troll Hydrogenaudio, they'd probably start the way you are doing. ABX testing is the way we separate real improvements from imaginary bullshit - which is largely the point of this forum.
db1989
post Oct 14 2010, 17:40
Post #17
Never mind the fact that the Terms of Service—which you implicitly agreed to abide by upon registering, and thus probably ought to skim over—explicitly feature information on what ABX testing is and why it is important.
Ouroboros
post Oct 14 2010, 17:58
Post #18
In what sense does reading about ABX require you to be a geek, or require you to have a science degree? If, for example, you were being asked to understand how MP3 encoders use DCT then that might be a reasonable response, but there's nothing "geeky" about structured listening tests - as you have discovered if you'd done any reading as suggested. Also, you have already stated "i cant hear any obvious differences" (your lack of capitalisation and punctuation has been preserved losslessly in that quotation), so you are obviously happy to do a listening test, and ABX is just a formal method of making sure that your comparative listening tests are free from bias.
Zarggg
post Oct 14 2010, 23:00
Post #19
QUOTE (pdq @ Oct 14 2010, 08:32) *
I joined the forum back in 2004, but didn't REALLY start lurking/responding until sometime in 2008. tongue.gif
dhromed
post Oct 15 2010, 08:55
Post #20
QUOTE (2Bdecided @ Oct 14 2010, 18:36) *
No, but...
The deleted posts make this thread something of a talking-to-my-imaginary-friend one.
In any case, I think Jason's question has been adequately answered. Perhaps relative to his level of commitment and base knowledge, HA does require a "science degree". Structured testing is science, after all. wink.gif
hellokeith
post Oct 17 2010, 12:40
Post #21
QUOTE (lvqcl @ Oct 13 2010, 08:54) *
sounds identical to me, can you describe the issue?
For the OP topic, I am more of a fan of Windows Media Encoder and its command line vbs add-on than trying to rip/convert with WMP. That said, 192 kbps and higher is generally* where any lossy codec becomes transparent to the source.
saratoga
post Oct 17 2010, 18:32
Post #22
WMA Standard supports 24 bit audio FWIW. No idea if the MS encoder is particularly good at it (probably makes no difference anyway).
lvqcl
post Oct 17 2010, 19:55
Post #23
QUOTE (hellokeith @ Oct 17 2010, 15:40) *
I was talking about WMA STD quality-based VBR, not 2-pass & bitrate-based... lalala.gif
pdq
post Oct 18 2010, 00:15
Post #24
QUOTE (saratoga @ Oct 17 2010, 13:32) *
I have no idea what you mean by that, since lossy-encoded files have no inherent bit depth. Do you mean that the encoder accepts 24 bit PCM files as input?
hellokeith
post Oct 18 2010, 01:48
Post #25
QUOTE (lvqcl @ Oct 17 2010, 12:55) *
Hrmm well I ran it through WME on the default Quality VBR:
Audio encoding mode:    Quality VBR
Audience:     Quality-based
Audio codec:    Windows Media Audio 9
Audio format:    VBR Quality 98, 44 kHz, stereo VBR
and it still sounds identical to me. Maybe you are using a 3rd-party encoder with some issue?
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 2nd August 2014 - 01:23
