How can I convert multiple tracks to image+cue if they aren’t 44.1/16?, [was “[…] files to single file or directly one file but read next”(?)]
thibs
post Aug 14 2012, 12:15
Hi to all (first post here).
The title says it all but I'll explain why this is a problem (as I think current utilities can do that, just not the way I need it).
I'm currently more interested into High Def music and I use my HDI Dune Prime 3.0 multimedia reader for this.
I use HDMI output since coax/toslink is very limited (won't transmit PCM 24/96 5.1 or better yet, 24/192).
The problem for me is that the Dune does an HDMI handshake between each file (maybe an HDMI spec requirement or whatever I dunno).
I won't change my reader because of that, really.
The only way for the reader to read FLACs gaplessly is to provide one file (image) + cue sheet.
Most tools however (and this is of course normal since cuesheets were intended to copy CDs) do not like files being anything else but PCM 16/44.
FooBar+plugin can create CueSheet for multiple (whatever bitness,/res) files but I need a cuesheet for one file, hence the need for conversion.
I can of course downsample all files just for creating the CUE but really, that'd be ugly and long.
If anybody has a brilliant idea (one I haven't got myself), please, enlighten me smile.gif
Rollin
post Aug 14 2012, 13:06
Foobar2000
Convert->Destination-> check option "Generate multi-track files"
This post has been edited by Rollin: Aug 14 2012, 13:06
thibs
post Aug 14 2012, 20:08
QUOTE (Rollin @ Aug 14 2012, 14:06) *
Foobar2000
Thanks but this won't generate a CUE file, will it ?
trout
post Aug 14 2012, 20:52
No, not a separate cue file, but the output FLAC file will contain an embedded cue sheet. And it looks as though embedded cue sheets should be supported - at least with the right firmware update.
- Also added support for built-in CUE-sheets in FLAC, APE and WavPack files.
If you want or need an external cue sheet then you would need to extract it manually.
- add the file to a foobar2000 playlist
- right-click on one of the tracks, select ''Utilities > Edit cuesheet''
- copy and paste the cue info to a file
Or use other another software / method to extract the cue sheet metadata.
Rollin
post Aug 14 2012, 21:37
QUOTE (thibs @ Aug 14 2012, 23:08) *
It must... maybe you are doing something wrong?
Select all track you want to merge->right click->Convert->...->Output format->select format, you want->Back->Destination->Generate multi-track files->Back->Convert
It must create one file in selected format and cue
thibs
post Aug 15 2012, 13:03
QUOTE (trout @ Aug 14 2012, 21:52) *
QUOTE ( [url="http://dune-hd.com/firmware/bdprime3/")
http://dune-hd.com/firmware/bdprime3/[/url] ]- Also added support for built-in CUE-sheets in FLAC, APE and WavPack files.
Wow, completely missed that part !
Many thanks !
I will test ASAP. Thanks again !
RSS Lo-Fi Version Time is now: 29th July 2014 - 14:31
