6 Pages V  « < 4 5 6
foo_utils, plugin discussion
BelleAndZEK
post Mar 30 2011, 03:11
Post #126
With Text Tools, is there any way to find a specific string in a ripping log in the same foilder as my mp3s and return true or false if the string exists?
Also, is there a way to get the Width and Height in pixels from my Folder.jpg files?
If not, is it possible otherwise with Foobar2000?
foosion
post Mar 30 2011, 07:55
Post #127
Group: FB2K Moderator (Donating)
There are no functions that read data from text files or images in foo_utils. I do not know, if some other plugin can do this.
marc2003
post Mar 30 2011, 09:02
Post #128
WSH panel mod can do both those things.
http://www.hydrogenaudio.org/forums/index....showtopic=70363
if you get stuck, try asking in this thread for help
http://www.hydrogenaudio.org/forums/index....showtopic=77883
juglesh
post Jul 30 2011, 07:32
Post #129
howdy, Is it possible to get the functionality that I asked about in this thread:
http://www.hydrogenaudio.org/forums/index....&pid=668992
But I am now using foobar 1.0.3 or so.
QUOTE (juglesh @ Nov 21 2009, 11:59) *
Hi, in 8.3 i have a keyboard shurtcut to "send to playlist/temporary entry" This sends the song to the previous (left tab) playlist, and focuses the playlist.
is there something like this in 9.6.9? the thing i see is "send to playlist..." which asks you every time which playlist you want it sent to.
what i do in 8.3 is open a blank pl in a tab, then my 'all' playlist. i can easy make cd's or pl's by hitting S (to send it to the blank pl) and then W (focus back to the 'all' pl, via Previous Playlist)
thanks
Tanx,
J
juglesh B>{)}
www.RadioKDUG.com
Emerelle
post Dec 22 2011, 20:05
Post #130
I have a problem with the text tool and the encoding....I need to export the %lyrics% tag contents to text files in ansi, so I was using this TF:
Header:
$ansi(%artist% - %album% '('%date%')'$crlf()$crlf())
Body:
$ansi(%tracknumber% %title%$crlf()$crlf()
%lyrics%$crlf()$crlf())
I also tried to wrap the ansi function directly around the lyrics tag, saved text file is always UTF-8 w/o BOM sad.gif
Could some kind soul point me into the right direction?
foosion
post Dec 22 2011, 20:47
Post #131
Short answer: There is no option to make foo_utils use another encoding for the text files.
Long answer: The $ansi() function does not change the encoding of its argument. It replaces characters that have no ANSI representation with with an ANSI character, but the characters will still be encoded in UTF-8.
Emerelle
post Dec 22 2011, 21:06
Post #132
Okay, thanks. Will have to look for another solution then.
trinkner
post Dec 18 2012, 00:33
Post #133
Is foo_utils compatible with Foobar2000 1.1.16? I've installed 0.6.2 Beta 6. I'd like to set playlists to read-only, but I can't see how to do it. There is no "Playlists" option on my Foobar menu bar, nor is there any such option in the right-click context menu. I've tried using both Playlist Manager and Playlist Organizer, but I can't figure out how to access the Playlist Tools functionality.
Is there a newer version I should be using?
Thanks very much!
marc2003
post Dec 18 2012, 11:20
Post #134
you set it on a per-playlist basis from the main Edit menu.
trinkner
post Dec 18 2012, 19:45
Post #135
QUOTE (marc2003 @ Dec 18 2012, 03:20) *
LL25255252
post Jun 12 2013, 19:40
Post #136
foo_utils has a Collect to clipboard feature but Is there a simple way to clear this clipboard ?
QUOTE (foosion @ Jun 2 2006, 08:33) *
The command's description as shown in the statusbar:
Adds selected tracks to the system clipboard.
This command is part of the clipboard functionality in foo_utils. It works like "Copy Tracks" except that it appends tracks to the clipboard instead of replacing the clipboard contents when possible. So by using it several times in a row, you can collect tracks to be pasted elsewhere.
I have the latest foo_utils - 0.6.2 beta 6.
foosion
post Jun 15 2013, 11:21
Post #137
You can use the copy command to set the clipboard content to the selected tracks. There is no separate command to clear the clipboard.
LL25255252
post Jul 13 2013, 05:01
Post #138
QUOTE (foosion @ Jun 15 2013, 12:21) *
Thanks foosion.
I have seen your reply only now... Although I've "tracked this topic" after I posted my question I haven't got a mail notification to your reply. I had also "Email Notification by default" in my hydrogenaudio account's email-settings and had also "Enable email notification of replies" box checked ("post options" - above the "add reply" button)
This post has been edited by LL25255252: Jul 13 2013, 05:05
Kai_cologne
post Mar 16 2014, 20:23
Post #139
I just use "add to Playlist XY"
is it possible to see this direct in the context menu without the "legacy commands (unsorted)" "folder"
marc2003
post Mar 16 2014, 20:26
Post #140
no.
Forfit
post Nov 16 2014, 13:23
Post #141
Do it is possible to add a base64 function to convert cover art into img tag?
foosion
post Nov 16 2014, 18:40
Post #142
Sorry, I don't understand what the use case is.
Forfit
post Nov 16 2014, 18:48
Post #143
f.e.:
<td>$if2(%title%,%filename%)</td>
<td><img src="data:image/png;base64, $base64(%cover%)"></img></td>
lvqcl
post Nov 16 2014, 21:52
Post #144
Are you sure that titleformatting variable %cover% exists?
fbuser
post Nov 16 2014, 22:14
Post #145
QUOTE (lvqcl @ Nov 16 2014, 21:52) *
Why not? If he adds a tag COVER to his files, the variable automatically exists, like for any other abritrary tag too.
@Forfit: BTW, you could write $if2(%title%,%filename%) also just as %title%. It's the same.
Forfit
Post #146
not, fb2k could add
thiers.prive
post Jan 20 2015, 07:29
Post #147
I realy apologize I read all the subject, but I don't understand how to export a CSV file. I have 2 100 records on foobar and i want to export a CSV file. All my file are in Wav and on a Qnap nas.
I have install the foo_utils components on the latest version of foobar.
Thanks for your Help
foosion
post Jan 21 2015, 20:53
Post #148
Firstly you have to configure a suitable template to produce CSV output. You can do this on the "Text tools" preferences page. You will find three text fields for title formatting scripts there called "Header", "Body" and "Footer". Clear the header and body fields. Enter the following into the body field:
"%album%"','"%title%"$crlf()
If your files do not have tags you may prefer to use the following instead:
"$directory(%path%)"','"%filename%"$crlf()
Of course you can tweak this to output whichever columns you want. If you prefer a header row in your CSV file you can do that via the header field,. e.g.
"Album"','"Title"$crlf()
Note: The double quotation marks have no meaning in title formatting. They merely produce double quotation marks in the CSV file, which is useful if the values contain commas. The single quotation marks make sure the title formatting interpreter output the commas as literal text and does not interpret them as special characters. The $crlf() function produces a line ending. Otherwise all the output text would be contained in a single line.
Secondly you have to use the "Save text..." command from the context menu. In current versions of foobar2000 it is displayed in the "Legacy commands (unsorted)" submenu. This will open a dialog where you can select the file name and directory of the CSV file.
azertyxtra
post Feb 26 2015, 14:47
Post #149
QUOTE (foosion @ Jan 21 2015, 20:53) *
About that quote, would it be possible to bypass the dialog box by having a predefined path and file name stored somewhere?
I'm trying to save a custom playlist by pressing 1 button
6 Pages V  « < 4 5 6
RSS Lo-Fi Version Time is now: 29th March 2015 - 07:27
