5 Pages V  < 1 2 3 4 > »
I heart foo_dsp_delta!, Thanks ssamadhi97
SafirXP
post Mar 25 2005, 15:23
Post #26
this plugin's awesome! great for the crappy 128kbps files i have... makes them sound a lot lot better! smile.gif
i'm using this dsp config:
Gap killer
Equalizer
Noise sharpening
Channel mixer
Advanced limiter
is that ok?
everybody's a jerk. you, me, this jerk!
spived
post Mar 25 2005, 17:27
Post #27
Hi, how are you?
Because I'm behind a firewall and can't download DLLs and EXEs
Thanks in advance!
Rodolfo from Mexico
"don't gimme no lip" - pearl jam
hödyr
post Mar 25 2005, 19:02
Post #28
I set up a mirror. Hope you guys don't break my traffic limit unsure.gif. http://digitalfrost.planetzord.de/foo_dsp_delta.zip
Blubb
ev0|
post Mar 25 2005, 19:07
Post #29
Yeah, i love this thing too. I used to have it up at 125, but the transients were too clear (noise, hissing etc)
Reducing it to 60 gives a much better result. I've got some really nice sound with foobar now.
Funkstar De Luxe
post Mar 25 2005, 19:18
Post #30
30 was too much for me :-)
25 = perfection
http://www.animarecordings.com/
neoufo51
post Mar 21 2006, 03:38
Post #31
0.9 could really use this now that its out...
ssamadhi97
post Mar 21 2006, 19:35
Post #32
Group: Developer (Donating)
foo_dsp_delta for foobar2000 0.9 final
I'm glad to see that people are enjoying this plugin so much, even though it isn't much more than a little experimental boredom project.
Have fun!
PS: Special thanks to foosion for compiling as I don't have the necessary resources right now.
This post has been edited by ssamadhi97: Mar 21 2006, 19:36
A riddle is a short sword attached to the next 2000 years.
villiansv
post Mar 21 2006, 19:43
Post #33
QUOTE (ssamadhi97 @ Mar 21 2006, 02:35 PM)
Have fun!
A big thank you to both you and foosion.
djet
post Mar 21 2006, 21:20
Post #34
If I'm not mistaken, the result of this component output is similar to a linear frequency raise? Since dsin(2pi*n*f*t)/dt = 2pi*n*cos(2pi*n*f*t), the added signal is dependent from f and its amplitude is higher at high frequencies.
This post has been edited by djet: Mar 21 2006, 21:22
foosion
post Mar 21 2006, 21:34
Post #35
Group: FB2K Moderator (Donating)
Yes. This is also quite easy to see if you use basic rules about the Fourier transform (pictures from Mathworld):
Chaser
post Mar 21 2006, 21:59
Post #36
What effect strenght are you guys using?
PS: It really makes a difference 8)
skelly831
post Mar 21 2006, 23:03
Post #37
Group: Members (Donating)
QUOTE (Chaser @ Mar 21 2006, 12:59 PM)
From 15% to 25% depending on the HF content of the music I'm listening to.
we was young an' full of beans
Rash
post Mar 22 2006, 00:37
Post #38
QUOTE (ssamadhi97 @ Mar 21 2006, 03:35 PM)
What? Are you kidding? This an awsome plugin. Really! Thank you so much. wink.gif
Liberate tutemae ex inferis
ssamadhi97
post Mar 22 2006, 01:13
Post #39
Well, basically (and this is imo another interesting - albeit somewhat obvious - observation in the vein of what foosion and djet talked about) the operation this plugin performs is very simple: It's merely a convolution with (-a 1+a), where a, the effect strength (or the factor a in f(t)+a*f(t), see my description earlier in this thread), is in [0; 2]
If you apply this on an image, you will see that it's simply an unilinear sharpening filter - hence the name I picked for the dsp effect.
@Chaser: I use anything from 0-200, depending on how muffled the recording is. I have a lot of live music on my harddisk, and a considerable amount of these recordings sounds a lot better to me with the help of foo_dsp_delta.
This post has been edited by ssamadhi97: Mar 22 2006, 01:15
acedriver
post Mar 22 2006, 05:04
Post #40
Thx for the update.
http://www.last.fm/user/acedriver
markanini
post Mar 22 2006, 13:09
Post #41
Would it be possible to make a plugin that does the oppisite as well? I've got some recordings that sound very harsh. Preferably in a "passive" fashion to aviod clipping.
ssamadhi97
post Mar 22 2006, 16:15
Post #42
That aside, yes, I've been thinking about that. We'll see what happens.
markanini
post Mar 22 2006, 19:22
Post #43
Negative gain instead of positive to avoid clipping.
realdaguru
post Mar 23 2006, 02:04
Post #44
I had this awesome DSP before my computer got fried. Now, I'm trying to re-install it, but I'm having a problem.
I put the .dll file in the components folder.
I open foobar2000.
I get an error message that says:
"Failed to load DLL: foo_dsp_delta.dll
Reason: This component is missing a required dependency, or was made for different version of foobar2000."
Because of whatever this means, the noise sharpener doesn't appear in the DSP manager. Can anyone help me?
Chaser
post Mar 23 2006, 12:31
Post #45
realdaguro: First of all, what version of foobar are you using? 0.8.3 or 0.9?
realdaguru
post Mar 24 2006, 03:07
Post #46
QUOTE (Chaser @ Mar 23 2006, 06:31 AM)
I'm using v0.9. I can't find any other version.
foosion
post Mar 24 2006, 09:09
Post #47
Make sure you downloaded the 0.9 version of foo_dsp_delta (second link in first post).
Rogue`
post Apr 7 2006, 22:13
Post #48
Got this a few weeks ago, forgot to say thanks. So thanks for the nice plugin wink.gif
Ran Sagy
post Apr 7 2006, 22:21
Post #49
Same, pretty nice. Good work :]
gecko_mayhem
post Apr 8 2006, 01:15
Post #50
Awesome, I really like the way it works.
RSS Lo-Fi Version Time is now: 23rd December 2014 - 03:24
