True FLAC or fake one
ladyred
post Apr 9 2006, 00:46
Hi there,
Does anyone know of a program that can verify the integrity of a flac?
How can I tell if it is a real FLAC or an mp3 file that has been converted into a FLAC?
Is there a program out there that will do this?
Cosmo
post Apr 9 2006, 07:45
A FLAC file who's source was originally an mp3 file is still, technically, a "real" FLAC file. So it's not really the integrity of the FLAC file that you want to check (in technical terms), it's the audio data contained within.
There is only one program that I know of that can make a reasonably educated guess at whether music has been transcoded from a lossy source like mp3. Tau_Analyzer. But if I recall correctly, you probably can't scan FLAC files directly with it.
Most of the time it's pretty easy to tell if an audio sample has originated from a lossy/mp3 source, just by looking at a the frequency spectrum. Lossy file compression like mp3 usually employs lowpass filtering at a frequency well below that of true CD audio. And the effect of such lowpass filtering remains apparent even after it has been transcoded. See: http://www.audiohub.org/get/fa/fa.htm + http://www.audiohub.org/get/fa/sa.htm .
Latexxx
post Apr 9 2006, 08:44
A/V Moderator
QUOTE (Cosmo @ Apr 9 2006, 09:45 AM) *
That isn't very reliable method. For some reason there are original cds come with a 16 kHz lowpass and according to cd specs the band between 20 kHz and 22.05 kHz should contain no meaningful information.
tgoose
post Apr 9 2006, 12:56
QUOTE (Cosmo @ Apr 9 2006, 07:45 AM) *
True enough, but the simple way to get around this is to burn the FLAC to an ISO file, then mount it with something like Daemon Tools. I'm pretty sure that works fine.
kjoonlee
post Apr 9 2006, 13:31
Eh? Why not just decode to .wav? If you're smart enough to burn an ISO, you're smart enough to use the command-line, IMHO.
flac -d input.flac
http://blacksun.ivyro.net/vorbis/vorbisfaq.htm
kritip
post Apr 9 2006, 13:48
Because it only reads from a CD, therefore you have to either burn them to an actual disc, or mount them as a virtual drive.
Kristian
//edit refering to Tau Analyzer of course
This post has been edited by kritip: Apr 9 2006, 13:49
Mr_Rabid_Teddybe...
post Apr 9 2006, 14:06
QUOTE (kritip @ Apr 9 2006, 04:48 AM) *
Kristian
auCDtect works directly on wav files.
"ONLY THOSE WHO ATTEMPT THE IMPOSSIBLE WILL ACHIEVE THE ABSURD"
- Oceania Association of Autonomous Astronauts
LaserSokrates
Take aucdtect then.
Edit: Ah, Mr_Rabid_Teddybear was slightly faster than I.
This post has been edited by LaserSokrates: Apr 9 2006, 17:54
kritip
post Apr 9 2006, 14:29
QUOTE (Mr_Rabid_Teddybear @ Apr 9 2006, 02:06 PM) *
Ah, i was aware of that, but for some reason thought it was not developed anymore, and Tau Analyzer had superceded it. Upon looking further it appears i was totally wrong about that, and it is what Tau Analyzer is based upon? Good news smile.gif and serves me right for not looking harder last time I looked into it.
Kristian
ghost note
post Apr 9 2006, 14:40
Tell me, if I am mistaken, but if [url=http://www.accuraterip.comAccurateRip[/url] was applied, the
AccurateRip check results actuall are also able to reveal, if a flac, or file was sourced by an original-CD
or by any other non-original-CD source.
Never_Again
post Apr 9 2006, 15:15
Group: Members (Donating)
You would have to burn an Audio CD from those files first to use AccurateRip. Then if AccurateRip reports the results as accurate, the source was lossless. However, if your results don't match those in the AccurateRip database, it could mean anything from a different CD pressing to the wrong write offset to lossy source.
EuMesmo
post Jun 30 2008, 06:02
QUOTE (ladyred @ Apr 8 2006, 20:46) *
Hi there,
There's a GUI for Tauanalyzer that decodes to wav directly.
Audiochecker Home.
djcarpediem
post Jul 1 2008, 09:18
I am having trouble decoding a flac file and I can't get it to work with many programs
flac, cog, etc.
I got an error message when I tried to decode it...
flac 1.1.0, Copyright © 2000,2001,2002,2003 Josh Coalson
flac comes with ABSOLUTELY NO WARRANTY. This is free software, and you are
welcome to redistribute it under certain conditions. Type `flac' for details.
Antonin DvorA├╔Č░k - Masterworks Disc 1.flac: *** Got error code 0:FLAC__STREAM_DECODER_ERROR_STATUS_LOST_SYNC
Antonin DvorA├╔Č░k - Masterworks Disc 1.flac: ERROR while decoding metadata
state = 4:FLAC__STREAM_DECODER_END_OF_STREAM
can anyone tell me what this means?
do i have a corrupted flac?
or just some program that can't decode it? it looks russian....I think......or czech....as the last characters are not coming up properly....could this be the issue?
anyway...thanks
dj
Jany
post Oct 8 2010, 14:18
Software: Spectro [FLAC is supported]
Homepage: http://spectro.enpts.com/
FLAC vs MP3[320kbps]:
MP3[128kbps <lol>]:
After analyze fake flac you will see same specro like on source mp3.
TIP: Not always you will have 22,1KHz but that don't means its fake.
When i spectred full quality human sound solo, spectro is low xP
This post has been edited by Jany: Oct 8 2010, 14:20
db1989
post Oct 8 2010, 14:43
Post #15
Why is the x-axis scale reversed?
Jany
post Oct 8 2010, 15:29
Post #16
QUOTE (dv1989 @ Oct 8 2010, 14:43) *
RSS Lo-Fi Version Time is now: 29th March 2015 - 17:16
