3 Pages V   1 2 3 >
foo_musical_spectrum, Musical Spectrum
fismineur
post Oct 10 2012, 15:08
A visualization component for the default UI.
Attached File(s)
godrick
post Oct 10 2012, 17:27
Very nice! It would be great if the tooltip could also display the amplitude. thanks!
romor
post Oct 10 2012, 18:49
Beautiful. Zero resource usage. Nice default colormap. Horizontal B is my choice
This definitely solved my UI dilemma and I added one more tab stack to my layout, to hold these great components foobar has happy.gif
scripts: http://goo.gl/M1qVLQ
Canar
post Oct 10 2012, 19:15
Installed.
2. Assume good faith.
dyermaker
post Oct 22 2012, 16:27
great work thanks fismineur
fismineur
post Nov 21 2012, 10:20
Musical Spectrum 0.9.1
  • Added support for Columns UI.
  • Minor improvements.
Attached File(s)
Chesteta
post Nov 21 2012, 18:37
Wow, I have been wanting this for quite some time now! Thank you for your time and work!
One suggestion/addition - would it be possible to change the legend to terms of 'frequency' as opposed to 'notes'?
EDIT: also, if there is a way to change the number of bars used that would be cool too smile.gif
This post has been edited by Chesteta: Nov 21 2012, 18:40
diypig
post Nov 23 2012, 16:57
Buratino
post Dec 2 2012, 19:46
Good component. I wont different orientation (for several chanals).
krazyclocks
post Dec 2 2012, 20:46
Having trouble to unzip , tried on two computers.
One says files corrupted other invalid directory.
Using Foobar 1.1.5 Win XP Winzip.
Other components unzip OK.
Can see zipped file in components folder but can not unzip.
Any idea what I could be doing wrong ?
THX
Brian
Buratino
post Dec 3 2012, 05:20
krazyclocks for unzip use 7zip
http://www.7-zip.org/
krazyclocks
post Dec 3 2012, 07:05
I tried using 7Zip to unzip folder in components folder.
Will not work as well says file types not supported.
Still stuck... Anymore ideas ?
marc2003
post Dec 3 2012, 12:04
you don't need to un-zip. file>preferences>components. drag zip onto window or use the install button to locate it.
the zip works fine from here so if you still have problems, try clearing your browser cache or use another browser.
krazyclocks
post Dec 3 2012, 20:29
Well , tried several things , explorer and winzip no go...
Firefox and 7zip worked !
No idea why but loaded.
ohcandy
post Jan 2 2013, 23:08
Post #15
QUOTE (Buratino @ Dec 3 2012, 01:46) *
how could you make it flip like that? in the option i can't find rotate to make it flip like your pic...
Buratino
post Jan 3 2013, 12:32
Post #16
ohcandy
It is only illustration my request. I hope it will in new version.
This post has been edited by Buratino: Jan 3 2013, 12:37
AndreaT
post Feb 6 2013, 21:01
Post #17
Hello Fismineur, you component is very nice and quite exactly what I was long looking for.
If possible, in your next release, add also the support of 64k FFT and even 128k FFT.
I know, are very CPU heavy-options, but are useful for time to time very low-freq check that the current best 32k FFT doesn't allow.
Many thanks and kind regards,
Andrea
deucalion
post Feb 13 2013, 12:38
Post #18
trout
post Mar 15 2013, 01:58
Post #19
Thank you, fismineur, for this very useful and well-made component!
andrew_berge
post Mar 15 2013, 22:44
Post #20
Bratman
post Mar 17 2013, 02:13
Post #21
Amazing, I too have been waiting for this a long time, kudos!
romor
post Mar 20 2013, 06:53
Post #22
I sampled default matplotlib colormaps at 6 and 12 points, and for fun sharing it as musical spectrum import "theme": http://db.tt/RPSyrACS
LUT:
EpicForever
post Mar 21 2013, 09:36
Post #23
I have a feature proposal. One checkbox dropdown list containing two options - "display signal before DSP/dsiplay signal after DSP". This will help watching correct spectrals for diferent channels while using active downmix or upmix DSPs. Currently everything is calculated after DSP chain. For my purposes I need option "before" smile.gif
bulletproof2k
post Mar 30 2013, 16:33
Post #24
http://victor-minin.tumblr.com
derty2
post Mar 30 2013, 17:02
Post #25
This is a very nice visualization component . . . thanks a lot ++++++
I noticed the download ZIP only contains a DLL and no readme.txt . . . therefore I took the liberty of creating one myself:
foo_musical_spectrum ("Musical Spectrum")
author:     fismineur
version:    0.9.1 (Nov 21 2012)
A foobar2000 component for Default UI & Columns UI.
Displays a visualization of the musical spectrum.
Features ======================================================================
  Adjustable frequency range display - from C0 (16.35 Hz) to A11 (56320 Hz).
  Comprehensive options - colors, styles, processing modes and effects.
Links =========================================================================
  http://www.hydrogenaudio.org/forums/index.php?showtopic=97404
Changelog =====================================================================
 1st release (Oct 10 2012)
  * foo_musical_spectrum.dll    (MD5: 418c6a7825e6b660ca456ba589658ff0)
  * Only works in Default UI
 Version 0.9.1 (Nov 21 2012)
  * foo_musical_spectrum.dll    (MD5: e26e703f42fd2ebddc33fbf04e422290)
  * Added support for Columns UI.
  * Minor improvements.
This post has been edited by derty2: Mar 30 2013, 17:22
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 28th April 2015 - 07:16
